DVD player zone X to multi zone - Bimmerfest - BMW Forums
Old 06-29-2019, 07:43 AM
Peechangfr Peechangfr is offline
Mein Auto: 730 Li
Good morning all board members,
I m an european expat in Thailand and I bought a very nice 730 Li full options with DVD player and RSE. Problem is in SE Asia the dvd player plays only zone 3 dvd and in Europe we have zone 2. So I cannot play my DVDs. Is there a way to flash the firmware of the DVD player to make it multizone?Where can I find the flash?
Thanks for the help
Regards
Philippe
Old 06-29-2019, 09:02 AM
vibbelito's Avatar
vibbelito vibbelito is offline
Mein Auto: 2007 730i E65
You don't need to flash. You can code it with ncs expert
Note that it can only be changed a few times! according to some documents (like 3 times or something)
Edit: i just saw that you wanted multi zone and that is not possible from my understanding. You can only have one zone at a time unfortunately :/
Old 06-30-2019, 07:17 AM
Mein Auto: 730 Li
Ok thanks for thť info. Normally all dvd players should be able to be multizone I will try to dig
Old 06-30-2019, 07:44 AM
vibbelito's Avatar
Okay there is a slim chance that if you add a custom parameter in ncs dummy with data 00 it will set the player to region free.
But I can not guarantee that it will work. It might even brick the player, most likely it won't brick it but don't blame me if it does.
Like this.
And then just code the module.
Pleas tell us how it goes if you try.
Skickat frŚn min SM-G955F via Tapatalk
Old 06-30-2019, 10:30 PM
Mein Auto: 730 Li
Thanks for the info....
As my 730 Li is my first BMW I will have to dig into programming. I did the same with my former Audi A6... I guess I will have to look after ODB plugs. Do you know btw if they have all the same quality where is the best place to buy one?
Regards
Phil
Old 06-30-2019, 11:29 PM
vibbelito's Avatar
From what I've heard they are not all the same. I however was probably lucky then that my first one works flawlessly that I bought of Aliexpress. With software downloaded from internet. "Mike's easy bmw tool" one klick install on my 32bit windows xp laptop.
There are plenty of threads on what software and cables work the best for what purpose. So see if you can find one of them.
