How to Retrofit a OEM Bluetooth TCU to your car - Page 28 - Bimmerfest - BMW Forums
Old 02-22-2018, 01:25 AM
cimdahers cimdahers is offline
Mein Auto: BMW e65 730d
Originally Posted by cimdahers View Post
Have You tried Prog.ZB Update?
Sent from my HTC One M9 using Tapatalk
My ZUSB number is greater. Therefore I thinkt it is upgrade not downgrade
I am not specialist, but I can assume that there can be different ZUSB numbers for different chassis. Therefore if You select VIN number which is yours from e65, the WinKFP will know what exact ZUSB is needed for e65. If Your TCU prevously was updated for e60 reighn, then it could be quite logical that e60 firmware cannot match coding and network of e65.
Just for interest, please select update function,and write down numbers which will be provided by WinKFP.
Old 02-22-2018, 01:27 AM
Don't try to find ZUSB manually, try automatic update function
Old 02-22-2018, 08:00 AM
PIFOUBMW PIFOUBMW is offline
Mein Auto: E65 745I 01/2004
I found the ZUSB 9205893 only in the SP-DATEN Tele15 history files for E60 then I should be able to update but only for a E60/E61. I found the 9171347 in the SP-DATEN for E60 too then this module was originally fit in a E61 and updated but is now too new for a E65 :/
What I can do is only select TELE15 in upgrade with E65 SP-DATEN but I have always the same message Wrong ECU hardware number : 9205893 (BSU not possible) and same result If I choose manually the ZUSB.
I tested with NFS too and same error message "9205893 (BSU not possible) "
I still blocked with this TCU :-(
Old 02-22-2018, 08:19 AM
Is it even after You enter Your long VIN number? And then hit Prog.ZB Update?
Old 02-22-2018, 08:28 AM
Once I read that adding into HIS file necessaey ZUSB number allows use it manually.
Change HIS file of e60 by adding mine zusb number. Make backup of course...
I think WinKFP will find the accordant 0pa file.
Old 02-22-2018, 10:07 AM
See this.
https://r.tapatalk.com/shareLink?url...8&share_type=t
OLD BMW TCU 1.5 Telematic Bluetooth Module flash software
This info was from HIS file from e65. AndI do not see the 9205893...
Maybe mine 9171347 also is different which I extracted from Programm v28? From Yours...
I will be back at home in 9 days. I can share that 0pa then.
I am still wondering does really Prog.ZB Update function with Your VIN not allow to update Your TCU...
Old 02-22-2018, 11:08 AM
FINALY I HAVE FOUND THE SOLUTION !!!!!!!!!!!!!!!!!
I downgraded successfully the TCU to 9206778 with fake history files
"Wrong ECU hardware number : 9205893 (BSU not possible) " was displayed because this number was not recognized as an existing TCU in the TELE15 E65 SP-DATEN but exists in the E60 SG-DATEN then :
I opened the SP-DATEN\E60\data\TELE15\TELE15.HIS file which contains the line :
9205893,9213318,00,UB
and added this line in the NFS\data\TELE15\TELE15.HIS file in my PC which contains E65 SG-DATEN in WinKFP
Similar action for the second history file :
I opened the SP-DATEN\E60\data\TELE15\TELE15.HWH file which contains :
9205893A F
and added this words in the NFS\data\TELE15\TELE15.HWH file in the first line of numbers in my PC but I had to modify the F letter because upgrade only proposed to write the same ZUSB 9205893 and because I thought it was probably a letter to explain if ZUSB has to be updated or not, I tried to change the letter with E (as some others numbers in the file) and this permited to update ZUSB to 9206778
With this downgrade I was able to open the .C13 configuration file with NCS and modify it with NCSDummy and as soon I modified the first parameter from E61 to E65, the pairing was immediately working and now I can connect my phone to my E65
Then the conclusion is that it is possible to downgrade ZUSB with minor actions in notepad
But since I installed the 1.5 TCU , my voice recognition SVS is not working anymore (but it has the last update firmware version then should work) but works if I install the previous TCU for internal handset phone $638 and I don't find why :/
Old 10-11-2018, 06:13 AM
Phone board not working
Has anybody solved phone board problem after retrofit?
Some of retrofitters have already claimed that phoneboard is not working after TCU retrofit.
SO is mine. I have even changed ASK with FL phone board.
Even connected directly. The weird thing that both of mine phoneboards do not even light up. Checked currents; all are running through the wires... at connectors to phoneboard... weird
Old 10-16-2018, 01:52 PM
Phone board working
Bought older TCU with part number matching e65.
Installed, changed VIN with Tool32, encoded, and phone board is working.
After swap INPA does not show error on bluetooth antenna as well.
Well, newer TCU (or programm in it) possibly was not compliant with the phoneboard I guess... Weird that when I tried to update the latter TCU with WinKFP, it proposed to update ZUSB with the newer number which is in my previous newer TCU, to which phone board was not responding. Did not flash, just changed the VIN, and everything works...
Old 02-21-2019, 03:04 PM
mikael12 mikael12 is offline
Mein Auto:
How to resolve the A37C error.. ?
Old 04-12-2019, 04:46 AM
Cicicok Cicicok is offline
Mein Auto: e65, 730d, 2004
The phone board light is controller by the TCU, not by the light switch.
Old 04-12-2019, 04:51 AM
mareks mareks is offline
Mein Auto: BMW E65
Check You have coded phone board in ASK and MMI
Maybe is not aktiv also if Your TCU 1.5 Most ece
If is from E60 or others will be not coded so not aktiv
If connected must work, just coding.
Old 04-12-2019, 04:56 AM
Don't know, but maybe it is a problem with fakra plugs, antenna wire or connection?
Old 04-12-2019, 06:38 PM
Mein Auto: BMW E65
I have also fault about antenna but don't care about it
All work well
Old 04-13-2019, 04:06 PM
Mein Auto:
A37C
It was the passenger site antenna, this with gps and 1 of 2 gsm.
I have changed it and no error now.
GPS works anyway but the gsm part has been broken I guess.
Old 04-19-2019, 05:27 PM
I can confirm this method! Finally I'm using bluetooth as well.
Because I can't code the TCU to default values (empty MAN), can anybody post the values for TCU_POWER_SOURCE and POWER_MONITOR_TYPE? (in this thread is a dump from mareks TCU, but I'm not 100% sure, that he uses the correct values)
Old 04-28-2019, 03:00 PM
TRACK_WIDTH
standard
DSP_ACOUSTIC_PROFILE
wert_12
BACKUP_ANTENNA
nicht_aktiv
SIM_IN_TELEMATIK_READER
aktiv
TELEMATIK_SIM_ENABLED
aktiv
TELEMATIK_ENABLED
aktiv
E_CALL_COUNTD_DELAY_TIMER
wert_01
AIRBAG_TRIGGERED_E-CALL
aktiv
SPRACHE
englisch
japan
koreanisch
china_trad
russisch
TIMER_SMS_NACK
wert_01
WAKE-UP_BY_E-CALL
nicht_aktiv
E-CALL_HARDKEY_FITTED
aktiv
NON-TELEMATIC_E-CALL
aktiv
ACK_2_AIRBAG
aktiv
ALIVE_SIGNAL
nicht_aktiv
CAS_KEY_DATA_METHOD
wert_01
PAY_TMC_CONTROL
aktiv
GATS_SMS_DESTIN_BACKUP
atxeu_prod_d1
atxeu_prod_prefit_sim_d1
atxeu_tvs_d1
GATS_SMS_DESTIN_DEFAULT
atxeu_prod_d1
atxeu_tvs_d1
NON_TELEMATIC_E_CALL_NR
nummer1
RDU_CONTROL
nicht_aktiv
SVR_CONTROL
nicht_aktiv
PHONEBOOK_PRIORITY
wert_02
ENABLE_UNICODE
aktiv
MINIMUM_PULSE_FREQ
standard
SORTING_VARIANT
standard
AUTO_SRVC_CALL
aktiv
BORDNETZ
e65_bordnetz
BT_ENABLE
aktiv
CCM_FILTER
wert_03
INTERNAL_GPS
nicht_aktiv
INTERNAL_NAD
aktiv
MOST_CHANNEL
most_async_channel
USED_MICROPHONES
wert_01
AIRBAG_COMM_TEST_DELAY
wert_01
AIRBAG_INTRFCE_ERROR_DUR
wert_01
FIRST_POLY_COEFFICIENT
null
SECOND_POLY_COEFFICIENT
null
THIRD_POLY_COEFFICIENT
null
WSPEED_SIG_ERROR_DUR
wert_01
WSPEED_SIG_TEST_DELAY
wert_01
BACKUP_LOUDSPEAKER
nicht_aktiv
VR_EQUIPPED_TCU15
nicht_aktiv
A2DP_AUDIO_STREAMING
aktiv
AACN_DATA_SEND
aktiv
AVAIL_SERVICES_REPORTING
short
BEAMFORMING
aktiv
ECALL_TERMINATE_REDIAL
nicht_aktiv
GATS_SMSC_BACKUP
GATS_SMSC_DEFAULT
HANG_UP_E-CALL
aktiv
HIGH_POWER_MAX_TIME
5_minutes
IN_BAND_MODEM
nicht_aktiv
KEY_DATA_FETCH_BCALL
aktiv
KEY_DATA_FETCH_HOTLINE
aktiv
MAX_RS_ACTIVATIONS
wert_30
MOST_WAKEUP_LINE
nicht_aktiv
MULTIPLE_CALLS
aktiv
NAD_ALWAYS_ON
nicht_aktiv
NAD_ALWAYS_ON_MAX_TIME
3_weeks
PARK_CONSUMER_TYPE
wert_01
POWER_FLLW_UP_THRESHHOLD
5_minutes
POWER_MONITOR_TYPE
none
POWER_SUBNETWORK_TYPE
nicht_aktiv
RINGTONE
ringtone_1
TCU_POWER_SOURCE
kl_30
TELEMATIC_AKD
aktiv
TELEMATIC_B-CALL
aktiv
TELEMATIC_DEALER_CALL
aktiv
TELEMATIC_E-CALL
aktiv
TELEMATIC_FCD
aktiv
TELEMATIC_HEATING_CONTROL
nicht_aktiv
TELEMATIC_HORN_CONTROL
nicht_aktiv
TELEMATIC_HOTLINE_CALL
aktiv
TELEMATIC_LIGHT_CONTROL
nicht_aktiv
TELEMATIC_MY_INFO
aktiv
TELEMATIC_RDL_CONTROL
nicht_aktiv
TELEMATIC_TRFFC_BY_VOICE
nicht_aktiv
TELEMATIC_VENT_CONTROL
nicht_aktiv
VCARD_OVER_MOST
nicht_aktiv
SMS_TCU
aktiv
GET_POSITION_TIMEOUT
0_minuten
INBAND_MODEM_TIMER
nicht_aktiv
Old 06-26-2019, 09:17 AM
Smile
Because my 2004 SVS was not working anymore since the MMI, TCU and ASK upgrade, I just ordered for 27$ a 2007 English voice module which should be compatible with the other upgraded parts. I hope it will work.
Old 07-07-2019, 10:17 AM
Unhappy
Finally it does not work better with this new module !
Probleme comes from my TCU 1.5 module.
With Voice Recognition ACTIV : when I press the voice button on the streering wheel, radio is muted (as to hear a sound) but no sound, and if I press again, radio play again.
With Voice Recognition NOT ACTIV : when I press the voice button on the streering wheel, nothing happends.
My production date is 0605 because if I choose a more recent date, NCS-Expert display an error message about $216 option ( HYDRO STEERING-SERVOTRONIC) not possible.
Does anyone which has a SVR working can copy his TCU 1.5 configuration file for me to check If I found a solution ?
Old 07-11-2019, 09:41 AM
I had a SVS HW09 UK flashed in French which was perfectly working before TCU and MMI and ASK upgrade.
I received a 01/2008 SVS HW0C module and I flashed it in French too but same problem no sound.
I saw in a BMW doc that SVS output is made by the ASK module which makes the GONG sound when you press the voice button. I have no GONG sound and no voice then may be the problem comes from my 2006 ASK flashed with the last version because when I select Top_HIFI in NCS-Expert , it add Top_HIFI_ab2005 option which is not installed in my 12/2003 745.
But I retrofited the original ASK unit to test the voice and no voice again then may be problem from the MMI ???
Old 07-11-2019, 05:45 PM
B11NOV B11NOV is offline
Mein Auto: E65 730D
I believe the problem is with the new TCU. I did the retrofit a few years ago, and have lost SVS since. Nothings else was changed, ASK and MMI are facelift models, only TCU is new. I bought a newer SVS module but still the same.
Strangely, with the car on, if you do the MOST bus reset, SVS would work perfectly until the car is off. When it's not working, I still have the gong, but nothing else.
Old 07-12-2019, 12:05 AM
Smile
I suppose you correctly activated Voice Recognition in the NCS-Expert configuration of the TCU as I made too ?
Originally Posted by A4427 View Post
You can try to "reset" the MOST by turning the key on and disconnecting/reconnecting the jumper plug."
Very interesting, I will test this reset !
Old 07-12-2019, 04:27 AM
Try looking for a 'save MOST configuration' menu or similar.
In INPA under ASK selection, however I never done it INPA. In DIS in service functions. I use DIS after adding a MOST component, but don't remeber exact path by heart. Probably similarly also in ISTA.
However, I personally never had such problem without registering most configuration, Try it.
Sent from my LYA-L29 using Tapatalk
Old 07-13-2019, 12:21 AM
Unhappy
Disconnecting MOST plug with contact on was unsuccessful, I will test with DIS.
Old 08-15-2019, 09:44 AM
simkard simkard is offline
Mein Auto: BMW 740d (e65)
TCU 9334433 from a E91
Hello all,
I recently bought a Bluetooth TCU to replace the one I initially coded to my E65 because it did not allowed me to answer from the steering wheels button (and that was totally tiring me).
Actually the new TCU part reference is 9224422 and comes from a E91.
I checked the wiring which was the same as the one I initially did in the past, so I connected the TCU without changing anything.
The only thing which did not worked in the past was the phone keypad on the side of the ASK module ... which seems to act the same with the new TCU too.
I managed to successfully access it from the MMI (which is a latest version too coded by myself).
I then tried to acces the TCU using Tool32, but I couldn't write the VIN inside replacing the one existing inside (A603811).
Tool32 refuses to write my VIN inside the new TCU no matter what using the job "c_fg_schreiben".
I tried all these various possibilities :
- 7 digits UPPER case and LOWER case
- full length VIN
- HEX values (using a ASCII to HEX converter online)
Nothing changes, it keeps giving me the same error message which is : "ERROR_NUMBER_ARGUMENT".
I'm totally lost in this mess, I read somewhere that there might be possibilities like :
- changing the BMW model it was coded too for "E65" (as this module comes from a E91)
- Flashing the firmware inside the module to something else ?
- SPDATA files too old / too recent ?
Well, any ideas/solutions/guidelines will be greatly appreciated
Screenshot of Tool32 while running the job "c_fg_schreiben" :
