Rear stabilizer problem - Bimmerfest - BMW Forums
Old 07-13-2019, 11:48 AM
Dalplex's Avatar
Dalplex Dalplex is offline
Mein Auto: O6 750Li
Hello
Heard grinding noise while steering almost everytime after replacing the rear struts as it was visually fine at that time.
It is hard to say the causality since this was not noticed immediately after the test drive.
Only thing I can remember is the link was in the way of the bottom bolt of the struts. So it might be hytertensioned when trying to get the bolt off.
The top joint was dislodged with melting plastic bearing. The link itself bent down over the drive shaft.
The end of the stabilizer bar, the remaining ball of the top joint and the body of the link grinded off heavily.
Luck enough that the drive shaft seems harder than them. Only has slight grove on it. Otherwise can be split in half.
What was the problem in here? Is it possible the Hydrolic motor turning wrong direction? In stead pulling the link up as normal but pushing it down?
At this moment. The stabilizer bar can be turned easily by hand.
Thanks for your advice
06 750 Li, Clattering noise, suspect piston 2 hits head due to spun bearing.
03 760 Li,
Miss fire on #6
coolant leak from back plate.
Front vent is always hot
Acc only worked randomly
5D5C Rear stabilizer bar pressure low
4F53 Torque converter clutch slip
274E Missfire detect, checksum failure
2747 Cylinder 3 misfire
2748 Cylinder 7 misfire
286D Output HDEV9 cable 9
2914 Output HDEV5 cable 5
2915 Output HDEV3 cable 3
2918 Output HDEV4 cable 4
