2007 3.0d hesitant / sluggish at low revs - Bimmerfest - BMW Forums
Old 07-21-2019, 07:08 AM
X5-mark X5-mark is offline
Mein Auto: X5, 3.0 petrol, 2002
Hi
I've had a bad run with the X5 recently, turbo, rear diff, hand brake module, air bags...
Over the last couple of weeks it's been hesitant at low revs which is a nightmare pulling out of junctions and on motorways.
I've done a couple of things today;
Read codes with Carly ;
Glow plug cylinder control on 1,2,5 & 6
003FF0 - Air flow sensor
So ;
Unplugged the MAF - drives much better
Replugged MAF
Unplugged EGR vacuum pipe - drives much better
Replaced the EGR with one said to be good - issues still there
Currently I have the EGR vacuum pipe disconnected and capped to make it better to drive.
1. Could this do any damage?
2. What could be the reason for this issue?
If anyone has had (and fixed) the same issue or if you have any ideas please let me know.
Thanks a lot
Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old 07-21-2019, 09:15 AM
ard ard is offline
Resident Curmudgeon
On an otherwise unmolested diesel, no prior issues..noboidy hacking on it previously, I'd say replace the MAF, glow plugs AND controller.
You mention 'turbo'... What was done without that??
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 07-21-2019, 10:24 AM
Hi, thanks for the reply. Yes as far as I know all is standard and it's been well maintained.
The turbo was replaced around 7 weeks ago.
My first thought was as the car runs well with the MAF connected and EGR vacuum unplugged meant the MAF was good... but I guess the fact the car runs fine with the EGR vacuum unplugged means the MAF is getting different air flow so runs the car ok?
Old 07-21-2019, 11:23 AM
ard ard is offline
Resident Curmudgeon
..and people used to think we got sick due to 'bad blood'...hence leeches were used to suck the bad blood out.
Old 07-21-2019, 11:50 AM
Errr... ok
Old 07-21-2019, 11:56 AM
Doug Huffman's Avatar
Nuclear engineer
Still do, still are. See Hirudo Therapy.
https://www.ncbi.nlm.nih.gov/pubmed/12661792
Old 07-21-2019, 03:13 PM
Thanks for your help
Old 07-21-2019, 08:29 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Could there be something wrong with the new turbo or one of the connections to it?
Sent from my iPad using Bimmerfest
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 07-22-2019, 01:33 AM
Hi,
It's a possibility- but the car was working fine for over a month after the turbo... and after 2000rpm the turbo kicks in and it accelerates well with no hesitation etc, i think I read somewhere that the turbo doesn't kick in till 2k and it's only low revs this issue occurs.
And why would the EGR vacuum being unplugged make everything work well again?
