x1 28 oil change questions - Bimmerfest - BMW Forums
Old 07-12-2013, 02:26 PM
zooz3 zooz3 is offline
Mein Auto: 2000 z3 coupe 2.8
Decided to do early oil change. Small little hatch to access drain plug. Drain plug is plastic. Need Allen wrench to remove. Oil filter comes with new Plastic plug and two O rings. We used strap wench to remove oil filter cover. Everything was pretty easy but need to find cap type tool to remove oil filter cover. Also, i would prefer a metal drain plug with magnet. Anybody know if cap tool and metal drain plug is available? Also, would like hood insulation. Is there a part number for that? zooz3
Old 07-12-2013, 04:03 PM
floydarogers's Avatar
Pedant and Curmudgeon
I've seen the oil filter cover tools at O'Reilly's and Autozone. Definitely can buy from Tischer or any other online BMW parts retailer.
Look at realoem.com to see if the pad is listed.
Old 07-13-2013, 01:38 PM
DCC DCC is offline
BMW Fan
Mein Auto: '02 Z3 M Coupe
I do not recommend switching to a metal drain bolt, the drain pan is plastic as well and the metal bolt may not work out...
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 07-13-2013, 03:43 PM
pan plastic
Thanks, did not know pan is plastic,
