Fault Codes - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 07-19-2014, 03:08 PM
TL2E90 TL2E90 is offline
Mein Auto: 2018 BMW 750Li
Fault Codes
Hello
Can someone help me to understand what these codes mean? I have replaced already all sparkplugs and injectors and still have this problem. After I shut down the engine and restart, everything runs fine for about 10 to 15 minutes then the Drivetrain malfunction message comes up. Thank you for your help
Name:	Fault Codes.jpg
Old 07-19-2014, 09:05 PM
mikey2u mikey2u is offline
Mein Auto: 2011 750i
have them check if your turbo is leaking OIL. i had the same problem as u, Replaced spark plugs and a few coils and injectors and come to find out it was one of my turbos leaking oil thats going in the engine had to replace the plugs and coils again. costly job bro.
