1st gear hard shift in D - Bimmerfest - BMW Forums
Old 11-29-2016, 02:28 PM
Sid82RallyX Sid82RallyX is offline
Mein Auto: 2006 325i
Hi guys, first post in this forum. I have a '06 325i 4door. When coming to a stop, the transmission waits until the car is almost completely stopped and then shifts hard into first gear. Shifting up or down through all other gears is creamy smooth, hard shift does not happen when using the manual shift. If I shift into neutral and then back into D it shifts smoother, whether stopped or rolling. This condition is less noticeable while cold, but becomes harsh as the vehicle warms up. Also seems to be smoother when going uphill, but down hill and level feel the same. I've tried braking hard, soft, and coasting to a stop, but it made no difference. Also there is a slight hesitation when shifting to reverse. My first thought is low fluid. How do I check fluid level? If that is not it, what else might you suggest? Thank you all
Old 11-29-2016, 02:49 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Common symptom of bad mech unit seals or solenoids
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 11-29-2016, 03:51 PM
TurnerE90 TurnerE90 is offline
Mein Auto: 320D E90 AT
Maybe i'm way off, but the car "remembers" how you drive. Did you try resetting the gearbox(throttle adaptation)?
Old 11-30-2016, 10:03 PM
Is there a way to make a definitive diagnosis of that?
Old 11-30-2016, 10:04 PM
No, I'm new to BMW. Can you walk me through that?
Old 11-30-2016, 10:51 PM
aleks001 aleks001 is offline
Aleks
Mein Auto: 2006 BMW 325i
Skip that step you can't do it without software no matter what people will tell you.
Get your transmission fluid and filter changed + Mechatronic sealing sleeve you will need about 5.5L of fluid, use only ZF Lifeguard 6 if your transmission is ZF if it's GM any DEXRON VI is fine.
If this doesn't fix it, next step will be the transmission solenoids.
Old 12-01-2016, 03:12 AM
mokoboy1998 mokoboy1998 is offline
Mein Auto: BMW 328i
I'm not going to bash on bmw, but I really think they messed up on the new update. Since I got the update I've noticed my car will start in first, where it normally was second. Downshift into first going to a redlight etc.. and the most unusual thing I've noticed was my car going into neutral (NIC) a lot more than usual.
Old 12-01-2016, 08:13 AM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
Whelp, how many miles since last transmission fluid change? Whazzat?? NEVER??? Then [click here]
And even if it has been changed within last 50k mi, [do this] assuming you got one, which I don't not never know, being unfamiliar w/your engine config.
BUT before any o'that:
[click here]
Say, GM transmission?
Old 12-01-2016, 09:34 AM
You can't really diagnose seals in the trans without physically inspecting them.
The solenoids, if they are bad enough, will store shadow fault codes in the EGS module.
The "adaptive" driving profile is not as "adaptive" as people think it is. There are a few preconfigured driving profiles stored within the car. Depending on how you drive, different profiles will be activated. It does not really store unique shifting behavior for each driver. Resetting this will not help with the 2-1 shift, which is a common issue with the ZF 6HPxx transmissions.
Old 12-01-2016, 09:35 AM
Have a read here: https://sayyarti.wordpress.com/2015/...ission-issues/
Old 12-02-2016, 12:29 AM
I did the KOEO 30s flat throttle. It shifts smoothly some times and harsh others. Any thoughts?
Old 12-02-2016, 03:12 AM
Banned
Whazzat? To me, KOEO = Key On Engine Off.
Old 12-05-2016, 07:48 PM
Yeah. I found some instructions that said
Put in key
Without pressing brake to start engine, only press the On/Off button to turn on the power
Hold throttle all the way down for 30 seconds, may hear a chime(I didn't hear any noise)
Press On/Off button to turn off power
Start engine and drive normally.
I did that and it shifts better some times.
auto, automatic, fluid, hard, problem, shifting, transmission
