Oil in air coolant - Bimmerfest - BMW Forums
Old 07-16-2017, 12:54 PM
wgomez28 wgomez28 is offline
Mein Auto: BMW 335i XDrive
Oil in air coolant
I took my car in for an oil change just to find out that they found some oil in the air coolant,
How serious is this & how much will this cost me?
Thanks in advance!
Old 07-16-2017, 01:22 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
What the heck is air coolant???
Sent from my HTC 10 using Bimmerfest mobile app
Current BMW's:
2017 540i MSport
2016 428 GC MSport
Prior BMW's
2018 340i RWD 6MT MSport
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 07-16-2017, 01:34 PM
acoste's Avatar
acoste acoste is online now
Mein Auto: 2010 550i MT
intercooler I guess so there is an oil leak near the turbo
2010 BMW 550i MT
2003 BMW 325i @216k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 07-16-2017, 01:37 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2018 440M-Sport MPPSK/THP
Mein Auto: 2018 440M-Sport/MPPSK/THP
Can't be the inter-cooler because they are Air to Air on the 335, not air to water like the 340. Description makes no sense as stated.
If they are garbling up the air to air FMIC which has no coolant in it showing some oil inside its not all that unusual so it depends on how much oil & how old the car is.
Oil can come from blow by with a not to great PCV valve. One solution for that is a new valve & or an Oil catch can. All inexpensive. Turbo going bad is the other but should be a high millage car. Expensive fix.
Are you adding much/any oil between oil changes? If not forget about it. Why did they open the inter-cooler connections in the first place?
Kevin
CURRENT:
2019 Chevy Suburban 4X4 RST
2018 BMW 440M-Sport MPPSK/THP 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Yamaha V-Star
1998 Ford Ranger 4X4 Splash 5MT
1965 COBRA 550BHP FORD Racing COYOTE TKO-600
FFR Cobra Mk-IV COYOTE 5MT Build Thread
480 WHP of BURBBLES
I LOVE THE SMELL OF BURNT 100 IN THE MORNING
Old 07-16-2017, 01:46 PM
acoste's Avatar
air coolant => air cooler => intercooler
op just didn't know the name of it
2010 BMW 550i MT
Old 07-16-2017, 01:58 PM
Took that into account when I posted. That said, if that is exactly what he was told I would be a little concerned about the mechanic who said it.
Kevin
CURRENT:
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 07-16-2017, 02:46 PM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
If turbo's leaking oil....maybe.
Old 07-16-2017, 03:39 PM
I swapped FMIC on the old car pretty early in its life & there was trace oil in the cooler. If you remember the valves were cokeing up due to oil in the air stream at that time requiring a Walnut blast. A pretty good chunk of the 335's that were pushed had the problem. Solution was the catch can.
With the OP's car age, mileage & oil usage should tell how serious it is.
I am just not a happy camper with mechanics that can't clearly tell people what is wrong, why & what the alternatives are. Would hate to see a guy get new turbos when a new PVC valve was good enough.
Kevin
CURRENT:
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 07-18-2017, 11:27 PM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
Thanks in advance!
Please tell us exactly what the service rep said.
What you wrote makes no sense. There is coolant in the radiator. There is refrigerant in the air conditioning system. And the refrigerant has oil suspended in it.
No air coolant though.
Old 07-19-2017, 07:52 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK, Q5
Thanks in advance!
? need a better description of the issue
Old 07-19-2017, 08:12 AM
Our BMW Our BMW is offline
Mein Auto: 328xi GT
You'll get oil in the inter cooler and tubes also if car has been over filled at an oil change.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
Old 07-20-2017, 07:49 AM
This is what the bmw service department sent me, maybe this will make a little more sense.
Old 07-20-2017, 08:05 AM
acoste's Avatar
Yes it does. Those are the oil filter housing gaskets.
Gaskets failed and the oil leaked into the coolant.
http://www.realoem.com/bmw/enUS/show...65#11428637821
2010 BMW 550i MT
Old 07-20-2017, 10:01 AM
Banned
Yep, there it is.
OP, you was way off.....waaaaaaaaaaay off! Why? A-cause your Service Advisor didn't explain it to ya.
Now, that's just wrong - you should complain, and detail your pain and suffering right here at Bimmerfest, having titled your thread misleadingnessly. Possible: You can sue!
BMW Service Advisor when asked to show his qualifications:
Old 07-20-2017, 10:02 AM
`118513 is the timing chain cover gasket.
Wondering where the leak was & what it leaked into. Is there a connection to the oil filter housing & the cooling system?
Kevin
CURRENT:
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 07-20-2017, 10:06 AM
acoste's Avatar
that's the intake manifold gasket. I guess it needed to be removed to access the ofh.
http://parts.bmwofalexandria.com/pro...52d242%29.html
2010 BMW 550i MT
Old 07-20-2017, 07:16 PM
Great, I'm glad it makes sense now & I appreciate all of your feedback.
Now can someone tell me how serious this is & if it is an urgent thing to fix, thank you!
Old 07-20-2017, 08:19 PM
Rebound Rebound is online now
Mein Auto: Toyota Prius
Please tell me more!
I have a 2014 with the 6-cyl N55 engine and I've been thinking about a pre-emptive catch can install. The dealer mechanic told me that the PCV is integrated into the valve cover (mother-f*****), so the only sensible thing to do with the PCV is clean it. But a catch can is downstream of the PCV... can you please share what you know?
Old 07-21-2017, 10:17 AM
http://www.burgertuning.com/instruct...tall_guide.pdf
Kevin
CURRENT:
2009 Yamaha V-Star
480 WHP of BURBBLES
