Transmission fluid - Bimmerfest - BMW Forums
Old 07-15-2018, 08:17 PM
marines122181 marines122181 is offline
Mein Auto:
Transmission fluid
What's the general consensus on transmission fluid change?
Yeah yeah, BMW says lifetime oil but I'm just not entirely comfortable with that.
Just hit 62k miles.
Do it? Wait until 70k? Don't do it?
If so, flush or full change?
Expected cost?
2006 330xi
2015 X1 xdrive28i
Old 07-15-2018, 10:52 PM
stonex1's Avatar
stonex1 stonex1 is online now
Mein Auto: 13' X1 35i
I would say it depends on how long you like to keep it.
I just today did a spill and fill on my X1 Transmission oil.
Not a fun job.
I only changed about a 1/3 out.
If you are a DIY, it's doable, but better if you have a high lift.
Only because you have to pump fluid into the fill plug while the car is running, and right
next to the exhaust pipe. Keep your hands safe!
The oil that came out was golden dark but smelled OK.
I have 52,000km (32K miles) on my X1 and do about 75% highway driving.
I'm no mechanic, but if you plan to keep it 100K miles plus, get it changed at that mark or a few miles earlier.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 07-15-2018, 11:41 PM
Mein Auto:
Not a fun job.
I've read a few say 100k. Also many at 75k. I wish BMW would ditch the "lifetime fluid" garbage and recommend a serious interval. As far as I'm concerned, any part with "lifetime fluid" should come with a lifetime warranty if they don't want us replacing what keeps them running smoothly.
2006 330xi
2015 X1 xdrive28i
Old 07-16-2018, 02:17 AM
Thermos Thermos is offline
Mein Auto: F01 750ix
Never mind what Bmw say, Just listen to them who make the gearboxes-ZF Friedrichshafen AG. They say you should change oil and filter at 100000 miles or at A maximun of 8 years, what ever comes frist. The gearbox spesialists here in Norways recommended oil and filter every 30-40k miles. I do both gearbox and transfercase every 30k but i keep my cars for 200-300k
At 62k i say do it now.
Old 07-16-2018, 10:29 AM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
Yeah, 100K km (or ~60K miles) is the max I'd go. My wife's X1 has 108K km on it and I don't know if the fluid's ever been changed before. Therefore, it will be done next year.
Not even sure if -40 degrees is cold anymore ?
Old 07-17-2018, 09:12 AM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
by the way the Zf fluid is expensive. but seem that there is a alternative made by Valvoline
Old 08-03-2018, 11:35 AM
tripman630 tripman630 is offline
Mein Auto: E39 530i 5m/t Sport
Sadly "lifetime" fluid isn't a thing for just BMW, other domestic brands like Dodge use it too.
Coincidentally they also use a ZF transmission.
Would I be able to get the car up high enough on ramps to do a spill and fill? Wouldn't do a complete flush.
An indy shop quoted me $700 for drain, refill and new pan.
Old 08-03-2018, 02:39 PM
Tommy D Tommy D is offline
Need for Speed
Mein Auto: '05 BMW 330i
What do you need a new pan? A transmission fluid change and filter should run you around $200.
Old 08-03-2018, 02:56 PM
the filter and the pan is all one unit.
the vehicle need to be level in order for the fluid to be read correctly. you would need to get the vehicle on 4 jack stand.
at the price of the labor that shop charges, it is cheaper fro me to use the money to buy a floor jack and jack stands and do it myself. unless the plan is to only changes once in the lifetime of your ownership
Old 08-03-2018, 05:09 PM
sayemthree's Avatar
sayemthree sayemthree is offline
Mein Auto: 2008 M3
Why does the engine have to be running when you refill?
For Sale 2014 BMW X1 xDrive2.8i 64,xxx miles, Le Mans Blue Metallic, Sand Beige Leather, warranty until 4/2022 or 94,800 miles PM me
Old 08-03-2018, 05:23 PM
https://www.bimmerfest.com/forums/sh....php?t=1262558
check this out.
engine on is to make sure the level is correct. fluid expands when hot
