How many quart for a drain and fill of the transmission? - Bimmerfest - BMW Forums
Old 08-10-2018, 01:00 PM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
to those DIY people that have done a drain and fill of the tranny.
about how many quart came out during the process?
just need to know how much to buy.
thanks
Old 08-10-2018, 01:50 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
thanks
I did a spill and fill of the "fill" plug only. It was just under 4 Liters.
If I drained everything out from the drain plug, it may have been another 4 liters.
I would have to check my laptop for the exact fluid capacities.
This DIY sucks. You have to do the final fill with the car running, and the exhaust is right there next to the fill plug.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 08-13-2018, 01:19 PM
my plan first is to just replace some of the old fluid with new fluid, i made a pretty good pump with a home depot sprayer. I am think i will do it cold and measure how much came out and replace it with the same amount.
Old 08-13-2018, 08:44 PM
stonex1's Avatar
This is the pump I used.
Bought from a local auto store, not from amazon. I believe it's also the same pumped used by the FCP Euro guys who make very nice youtube videos on BMW powertrain fluid changes.
(by the way, the smaller hose attachment works well for sucking fluid out of the rear diff and transfer case.)
The main problem with the transmission fluid change is that for some reason the car needs to be running. I guess a pump somewhere will draw fluid from the main pan and bring it up into the gear box.
If you drain the whole thing, you could be looking at close to 8 liters. I think the spec sheet is around 9.
Anyway, you can do a cold spill and get most of it out, but it's the fill part that is scary. You can only get so many liters in cold before it starts to drip out the fill plug. The rest has to be done with the car running.
And it's a strange experience to start a car with the fill plug out of the transmission.
I think I even remember my iDrive going nuts about low transmission oil or something before I crawled underneath and starting pumping in the last 4 Liters of oil.
If I were to do it again, I might have a beer buddy helping that can start and stop the car for me.
2013 X1
Old 08-14-2018, 10:41 AM
thank you for the tip !!!
anyone else that has done this please let us know, the more tips we have the more it helps everyone
