Rear Window Gasket Corners - Bimmerfest - BMW Forums
Old 08-13-2018, 12:42 AM
Joe-BMW's Avatar
Joe-BMW Joe-BMW is offline
Mein Auto: F10, E39, Audi Q7
It doesnít look like you can just buy the upper corners which are broken. Correct me if Iím wrong. I need to buy the whole upper trim?
This looks fairly straight forward with a nylon tool and a spray bottle.
Any words of wisdom? Hate to replace the whole thing just for the corners. Guess I could get a new one and just use the corners.
2003 540i|Jet Black|Gray Interior|M-Sport|WS NAV|Shades|PDC
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|745li|2007 750li|2006 750li|2001 530i|2012 535xi|
Old 08-13-2018, 02:38 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Ehm, not sure, you are talking about the power window section in the rear? This is one piece, you can see it on realoem just like everything else.
Be very careful when removing the outer small trim plate between the two windows, dont force it in any way or use any tools, its soft aluminum and bends easily, it lifts right up, but put a protective cloth on the outside top side to protect the outside chrome trim around the window when taking it off. It can be a bit tricky getting back, but again, dont start hammering on it, not even with a rubber hammer.
The small rear windows fitting is, after what I have read notoriously difficult to change but this is not what you mean....
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 08-13-2018, 02:55 AM
Joe-BMW's Avatar
Nope. Iím talking about the rear window outside weather seal rubber gasket that goes around the rear window. The window with the rear defroster just to make it more clear.
Part # 51318159785
Old 08-13-2018, 03:48 AM
Joe-BMW's Avatar
This
Old 08-13-2018, 06:29 AM
Realoem, vehicle trim, window covering upper and lower.
https://www.realoem.com/bmw/enUS/sho...diagId=51_2249
Your part number is covering upper, https://www.realoem.com/bmw/enUS/sho...49#51318159785
Old 08-13-2018, 06:56 AM
Joe-BMW's Avatar
Thanks. Yes, I just need the upper. I really just need the corners.
Old 08-13-2018, 12:29 PM
computiNATEor's Avatar
computiNATEor computiNATEor is offline
(oOO\(|||) (|||)/OOo)
Mein Auto: 01 M5
Not available as separate parts, unfortunately. The whole seal must be replaced.
My corners are missing entirely, not just cracked. I've not bothered to replace it; it won't cause any leaks, but might cause a tiny tiny bit of more wind noise at higher speeds.
I wouldn't worry about it.
Nate J. - (oOO\(|||)ļ(|||)/OOo)
Reliable P.O.S. - 1995 Camry V6. 260k mi+.
E39 M5 - TiAg/Schwarz Nappa (M1SW) 07-18-2001 M5 Heritage (BZ99672). 171,000mi and increasing daily.
Prior:
Black Sapphire/Schwarz 03-11-2003 530iA Sport (CK39185). T-boned 03-01-2017 at 155,861mi.
Toledo Blue/Sandbeige 04-25-2002 530iA Sport (CH98032). Sold 11-10-2017 at 147,743mi.
Toledo Blue/Grau 10-29-2001 530i5 Sport (CE92358). Sold 02-01-2019 at 217,600mi.
Old 08-13-2018, 03:16 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
as nate stated, the upper is a one piece gasket, top and sides. simple to replace, can be found around $80.
99 528i 5sp sport
be alert...the world needs more lerts
Old 08-13-2018, 03:55 PM
Joe-BMW's Avatar
Actually, it's under $50 on ECS, FCP, etc. of course to void the free shipping.
Old 08-13-2018, 11:00 PM
Mein Auto: 01 M5
Easily fixed, I'm sure
Prior:
Old 08-17-2018, 08:34 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Yep. Gently pull the old one out, clean the recess well, lube with some soap and/or 303 and gently work the new one back in.
2002 530i
Old 08-17-2018, 09:50 AM
mattmar1's Avatar
Wingnut
i used a 1/4" piece of wood dowel, with one ended carved on opposing sides to a taper, about 1/2 way to being a chisel shaped dowel end to install, dish soap diluted (probably 5% soap or less) in a spray bottle, was easy enough
99 528i 5sp sport
Old 08-17-2018, 06:55 PM
Mein Auto: 01 M5
I meant that itís easy to order more than $50 in parts for free shipping, but yes, itís not a complicated DIY either.
Prior:
Old 08-17-2018, 07:05 PM
bmw blue's Avatar
bmw blue bmw blue is offline
Mein Auto: 2000 BMW 528i Steptronic
I read a post long time ago regarding window seal rubber replacement and the best lubricant to use.
The poster used "Astroglide".... LOL.
Worked real well apparently.
Beisan Vanos Repair, EMP Stewart Water Pump, Aluminum Water Pump Pulley, Behr Electric Fan, Sachs Fan clutch,
18pc Lemforder Suspension Kit w/Koni Sports+H&R Springs,
E46 Intake Boot W/AFE Dry Air Filter, Conforti Shark Injector,
Liqui Moly Leichtlauf High Tech 5W40 Motor Oil, Pentosin Full Synthetic Transmission Fluid and 75-90 Motul Full Synthetic Differential Oil.
Michelin Pilot Sports (summer), Continental DWS (winter).
190,500 miles and counting.
