Fuel Filler Door Peculiarity - Bimmerfest - BMW Forums
Old 06-18-2019, 08:56 AM
gkski gkski is offline
Mein Auto: 430i xdrive cv
I have noticed with my F33, that if the vehicle is locked and someone depresses the fuel filler door, it doesn't open all the way, but it does open a little further than the closed position.
Then when I get in and start the car, the fuel filler door opens even further and it is easy not to notice that the door is open. So, if someone should accidentally or intentionally depress the filler door walking by, and I get in to the driver's side of the car and start the car, my fuel filter door will now be pretty much open, even if I lock the vehicle.
Can anyone confirm this peculiarity?
Old 06-18-2019, 09:14 AM
Our BMW Our BMW is offline
Mein Auto: 328xi GT
I've noticed the same thing on my F 34.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
Old 06-18-2019, 09:22 AM
Thanks. Seems like they should have disabled that first detente when the vehicle is locked. It has already happened to me more than once and it wouldn't be so bad if the car notified you that it was open.
Old 06-18-2019, 11:19 AM
namelessman namelessman is online now
Mein Auto: bimmer
To OP, the fuel door is held with a latch pin that is engaged by locking the car.
At the same time, the door has a toggle mechanism for "OPEN" and "CLOSE"
When the car is locked, the door can be pushed once and toggled to "OPEN", but the latch pin still holds the door.
When the car is unlocked, the latch pin will disengage hence the fuel door pops open.
My usual habit is to take a quick glance to see if fuel door is ajar or not while walking up to the car.
Old 06-18-2019, 11:36 AM
Yes. That is exactly how it plays out. I guess I just don't think it should have to be that way. I have had other cars where this was not an issue, even with a similar fuel door release.
Old 06-18-2019, 06:21 PM
tex2670's Avatar
tex2670 tex2670 is offline
You Don't Need to Know
Mein Auto: '14 328xi Sport Line
The fuel door is locked when the car is locked. If you press it, you are releasing it from the spring loaded mechanism to push it out--but the lock is still in place. So when you unlock the car, the spring pops the cover out.
It's working normally.
2014 328i xDrive | Black Sapphire / Black Red Dakota | Sport Line | Premium Pkg | Lighting Pkg | Cold Weather Pkg | Driver Assistance | Nav | Sport Automatic Transmission
Old 06-18-2019, 06:42 PM
Just because it is working normally does not mean it's right. I had a recent model VW with the same setup and the fuel door was never sitting there unlocked at it does in this scenario after unsecuring the car.
Yes, once you know how it behaves you can account for it, but I should think they could implement a solution where the door does not toggle open at all without the key.
Old 06-18-2019, 11:24 PM
Mein Auto: bimmer
Other cars probably have basic spring load hinge mechanism that open/close without push-to-toggle. My recollection is that my old E39 does not have such push-to-toggle feature for its fuel door.
Old 06-19-2019, 08:55 AM
luckstr luckstr is offline
Mein Auto:
Or, at the least, give you a message that fuel filler door is OPEN !
Sent from my iPad using Bimmerfest mobile app
