F30 Coding Videos - Features that can be coded for your F30 - Page 2 - Bimmerfest - BMW Forums
Old 08-25-2015, 06:17 PM
RichReg's Avatar
RichReg RichReg is offline
Mein Auto: '15 435Xi.GC & '00 323Ci
Check the lists here for your car. There's a LOT that can be coded:
http://www.codemycar.com/coding-lists/
Old 08-26-2015, 12:00 AM
kingcobra kingcobra is offline
Mein Auto: '14 335i M Sport
Added 2 New Videos!
Current: 14 335i Msport
PAST: '10 370Z Roadster, 06 G35coupe, 02 Mustang GT, 02 Focus SVT, 96 Probe GT
Old 08-26-2015, 07:46 AM
dwlink's Avatar
dwlink dwlink is online now
Mein Auto: 435i Gran Coupe
I originally coded my mirrors to fold with lock either via key fob or comfort access, but found it annoying. However, then I discovered that you can program in a delay for the mirror folding. Now, my car will just simply lock with a button or door handle tap (as it did before), but if I hold the button or my finger on the door for half a second, then the mirrors will fold. There is no delay on the unlock to unfold the mirrors.
Just a suggestion that you may find more convenient if you re-code your car.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 09-01-2015, 01:58 PM
Added Tire Temperature in TPMS Display Video!
Old 09-01-2015, 02:24 PM
Jetsurly Jetsurly is offline
Mein Auto: 2014 328i xdrive
I have a 2014 328i Xdrive sportline with a build date of November 2013.
I have tpms but not sure if I am able to code tpms pressure and temp or not.
How about the drivetrain chassis stuff as well?
Old 09-01-2015, 02:42 PM
Kafkaesque328 Kafkaesque328 is offline
Mein Auto: '16 328i M Sport
Frogman (Tom) is great and coded features in my car as well. Best ones were coding Sport+ programming for the transmission, the tire temp display, etc.
Current - 2016 328i M Sport | JB+ | Premium | Nav | Driver Asst | Heated Seats | 35% Ceramic Tint | Sportline All Weather Mats | Tons of coding
R.I.P- 2014 320i Sport Pkg | 2010 VW GTI |2010 Mazda 3 2.5
Old 09-01-2015, 03:45 PM
This is an answer from a diff thread regarding the tpms:
"There are two system:
If your tire valve stems are rubber, then you only have flat tire monitor which compares rotational differences with the ABS Sensor. As a result it won't display the tire pressure/temperature even you coded it.
If your tire valve stems are metal, then you have Tire pressure monitor system, so after you code it it should show the tire pressure and temperature (you might need to drive it for a distance before it shows)"
"TPMS does not work in every car. The car has to be equipped with Option S2VBA Tyre pressure control (TPC). If you do not have S2VBA, you will have FTMS. TPMS is Tire Pressure Monitoring System, aka Reifen Druck Control (RDC) and FTMS is Flat Tire Monitor System, aka Reifen Pannen Anzeige (RPA). FTMS operates on tire rotational speed and has no actual sensors to measure pressure and temperature like TPMS does."
For the chassis stuff, do you have the button to switch between ECO/Comfort/Sports/Sports+? I don't see why it couldn't be done if you do, but then again double check with the Coding experts on this.
Old 09-01-2015, 03:46 PM
Frogman is incredibly helpful! Definitely the person to go to in the LA area!
Old 09-06-2015, 04:47 PM
TheEricThomas TheEricThomas is offline
Mein Auto: 2014 328i xDrive
Thanks for that link. Okee is legit. Highly recommend.
Old 09-07-2015, 09:33 AM
raytec85 raytec85 is offline
Mein Auto: f34
Hello Wise list, i am driving f34 would like to code my car, can i ask where can i get the E-sys software ?
Old 09-07-2015, 10:59 AM
ktula ktula is offline
Mein Auto: 14' F31 328xi (ED)
Post your request here:
https://www.bimmerfest.com/forums/sho...d.php?t=638188
ktula
Old 09-07-2015, 03:26 PM
Hookster57 Hookster57 is offline
Mein Auto: 435i Grand Coupe
Anybody use Antonio Vernacchia to code?
Old 09-11-2015, 04:03 PM
I think you would get an answer if you posted in the local forums as I'm assuming its someone local to you?
Old 09-11-2015, 06:02 PM
No. He's a remote coder. Already made contact. Feel really good using him.
Old 09-11-2015, 06:07 PM
GranChris's Avatar
GranChris GranChris is offline
Mein Auto: '16 428i GC
Hook, what are you having coded?
'16 428i GC, EBII/Coral Red/Ash Grain, M Sport, Tech, Prem, Cold, Driver Assist, HK, Adaptive M, Side & Top Cam, Park Assist
Old 09-11-2015, 06:11 PM
Ha, what aren't I?
Old 09-11-2015, 06:38 PM
GranChris's Avatar
Ha, what aren't I?
Ha, should have known!
Old 09-12-2015, 02:50 PM
redrobin1977 redrobin1977 is offline
Mein Auto: bmw 328i
I would like digital speed showing.
Old 09-12-2015, 02:56 PM
It's called the HUD.
ktula
Old 09-12-2015, 09:26 PM
Dgt707 Dgt707 is offline
Mein Auto: 2015 320i
Any coders in Phoenix Arizona?
Old 09-12-2015, 10:01 PM
Mein Auto: bmw 328i
No hud
Old 09-13-2015, 07:34 AM
Faisalbhutta Faisalbhutta is offline
Mein Auto: BMW 328i M Spec 2013
Antonio is a very cool remote coder...... He did the coding on my car remotely!!!!!
Old 11-07-2015, 11:51 AM
leonmckee leonmckee is offline
Mein Auto: 2016 328d xDrive Wagon
Any chance you can share a "how to" link for this feature?
Leon McKee
Old 02-21-2016, 09:28 PM
Bump to help others see a lot of the cool features that can be coded!
Old 03-19-2019, 09:50 AM
donluis donluis is offline
Mein Auto:
Originally Posted by kingcobra View Post
Yes sir!
Surprised how easy it was to do compared to my old cars where they had to bypass a certain cable in the engine bay I believe
I coded my 428i GC with bimmercode to do video in motion and video from USB but it does not work. I put some mp4 files in the USB but it only plays audio and no video. Do you need to have navigation system in order for it to work? Does your car have navigation system?
