LED headlight halogen F30 2014 - Bimmerfest - BMW Forums
Old 12-09-2015, 02:57 AM
marvinzalamea marvinzalamea is offline
Mein Auto: F30
any suggestions on which brand is the best LED light replacement on stock halogen on my F30 ?? I didnt get to upgrade my headlight to LED itself because its still expensive. serious reply please thank you. much better if you can send or post a picture for comparison thank you guys.
Old 12-09-2015, 04:17 AM
kmersh kmersh is offline
Mein Auto: 2016 BMW 328i
A colleague installed LED Replacement Angel Eyes bulbs on his X5 from Precision LED and it seems to work well and he was able to do it himself and he openly admits that he usually goes to the mechanic for any sort of work, but this was basically plug and play.
Not really sure if that helps you or not as I do not have any pictures or first hand knowledge, just what he told me.
Old 12-09-2015, 04:43 AM
Mein Auto: F30
ohhh okay.. well on my 320i my headlight is like the old school one where you use halogen bulbs. I just want to know if I can upgrade the BULB to LED lights. "just the BULB" I wanted to change the BULB light but not the headlight itself. because I look around how much the LED headlight is, and it is $800 a piece which is of course expensive. that is why for now I just want to replace the BULB only to LED lights without changing the headlight to LED too. LOL I guess Im being redundant here trying to explain my side LOL
https://www.google.com/url?sa=i&rct=...49751265644175
look at the headlight of this car its the same as mine I jst want to change to bulb. thats it. cause with my stock halogen lights the visibility is poor can't barely see on wide open highway roads.
Old 12-09-2015, 04:53 AM
Mein Auto: F30
http://file.kelleybluebookimages.com...43_640x480.jpg
This is the exact same headlight I have but I only want to change the bulb to LED. would it be possible?
Old 12-09-2015, 11:59 AM
JOEYPDX JOEYPDX is offline
Mein Auto: 2018 330i
There is this bulb from JLevistreetworks.
https://jlevisw.com/Accessories-for-...og-Light-Bulb/
I bought it but I'm unsure of what the light pattern will do or if it will blind oncoming drivers. I had intended on putting them into my car to test them but for reasons I cannot understand BMW makes replacing the low beam halogen bulbs an act of god to complete. I tried recently to do this and could never get the bulbs back in - and I had to go to the dealer to have them reinstall my regular halogen bulb (thank fully they did it for free, but apparently the service tech has a special tool to help him get the bulbs in). I went with a high performance light bulb (BMW branded but I think it's Sylvania that makes one too for H7 bulbs) and it does help but still looks - well low rent.
If you want those LED bulbs I have (they are new in the box) I'd sell them to you as I have no desire to try to put them in again. I think the best way is to take off the front tires so you can access the openings to the headlights easier. You have to go through a wheel well cover and then remove the rear headlight access cover. It is sharp and not easy.
2018 330i
Old 12-09-2015, 02:28 PM
BMWMosi BMWMosi is offline
Mein Auto: 2018 440i, 2015 i3
I got the same ones as Joey and installed them a couple of weeks back. I struggled big time because the access is a pain, so I just said F it and removed the front wheels, which would have saved me a BUNCH of time if I had started that way. There are 3 metal tabs in the light housing that you'll really need to bend in an inward fashion to keep the new LED base in place, but it doesn't hurt anything by doing so.
They are a huge improvement over the crappy halogens and I can see a lot better when it's wet. I have yet to get flashed by any other drivers so I think they are good to go. One thing that is odd with them is that when the lamp switch is on auto or off/DRL, the lights will flicker at start up for a few seconds and will also flicker for a second or two every few mins. This is the cold/warm check signal that the computer sends out that causes it. It doesn't happen when the headlights are set to on when starting up, though. It annoyed me so I coded out the cold/warm checks and enabled the low beams for LED and they don't flicker anymore.
Old 12-09-2015, 02:41 PM
u3b3rg33k u3b3rg33k is offline
Mein Auto: e30, e60, R1100S
Aftermarket LED bulbs don't hold a candle to the OEM LEDs. you're kinda SOL there.
e30: '87 325i: MAF+WAR chip, long tube STAHL headers, 5MT swap, 4.27 torsen
e60: '08 550i M-sport, 6MT, ARC, Active Steering, 19" wheel delete
R1100S - oilhead FTW
Originally Posted by MeNoo View Post
Although I have nothing scientific to say, I can confidently say that it works.
Originally Posted by Burning2nd View Post
If you want to use the fuhrers snowmobile you gotta have das tires
Old 12-09-2015, 02:43 PM
Hmmm, this gives me hope. And you're a fellow Portlander too I don't have a jack or lug wrench but had ordered it (after the last fiasco) and think the package arrived today. I might try once more to install them and remove the wheels first since I wasn't able to before. I too have a lot of difficulty seeing the road well when it rains here - which is quite a bit as of late as you know.
I have a lot of other external LED lights on my car (blinkers, DRL, brake, etc) so have coded as well to get the flickering taken care of and I'm sure I can code these too.
2018 330i
Old 12-09-2015, 02:48 PM
Let me know if you need a hand. I've got a 3 ton floor jack and the necessary tools to get the lugs off. I'm in West Portland near St. Vincent Hospital.
Old 12-09-2015, 02:50 PM
Oh cool! I'm downtown but I know that area. Then we can yell expletives at the car.
2018 330i
Old 12-10-2015, 06:43 PM
Mein Auto: F30
So you're still using the OEM halogen bulb lights?? damn I should've bought add on LED lights when I bought my car. now Im having this problem LOL
so yea this halogen stock bulb is so poor in visibility specially when its raining.
Old 12-10-2015, 06:45 PM
Mein Auto: F30
can you post some pictures? I just wanna see it.
Mein Auto: F30
Old 12-10-2015, 08:07 PM
Mein Auto: F30
Do you have it installed in your car?? can you post picture? thank you
Old 12-11-2015, 07:05 AM
No I have adaptive xenon. I've seen the housing differences between the new cars with halogen, and the LEDs. changing the light source alone in a halogen reflector housing will not bring them on to the big boys' playing field.
you're comparing this:
to this:
Old 12-11-2015, 11:20 AM
Our X1 has adaptive Xenons and they definitely look a ton better than the LEDs in the F30 halogen housing. But compared with the stock halogen bulbs, the LED replacements (bulb only) is night and day. I'll more than likely swap out the entire lamps in the next few months for the Xenons or LEDs. Just have to save those pennies and get through Christmas.
Old 06-05-2017, 02:31 PM
amritanshukar amritanshukar is offline
Mein Auto: Florida
Hi everyone,
I went through the post a number of times. I have a couple of queries.
Firstly, I bought my 2013 BMW 328i recently, unfortunately with the halogen housings. I replaced
1. High/Low beams with H7 Phillips Diamond Vision - 5000k
2. PW24W Parking Bulbs with iJDMTOY 42-SMD - 6000k
3. 13-SMD-5050 DRLs with iJDMTOY 5050 SMD - 6000k
Its a much cheaper option, than to change the entire housing for sure. Now, I was quite happy with arrangement until I found out about the varying color temperature. Both my Parking bulbs and DRL's are at 6000k color temperature but I could not find Halogen H7's with 6000k, the Phillips ones are 5000k. Other way round, I could not find DRL's and parking lights of 5000k.
The parking lights and the low beams light up together and color difference looks so off between the two. I love the look of 6000k bluish white light.
Has anyone able to find 6000k H7 halogens online ? or maybe 5000k PW24W LEDS ?
My second question is I have 2 pairs of H7 Auxbeam F-S2 series LEDs lying around. They are good bright 6000k LEDs for both high beams and low beams, alas they do not fit the F30 halogen housings, given the fact that I can code warm and cold checks, is it possible for me to use a converter for the same, I tried two of the converters from amazon but none of them fit.
Does any one know a set of LED's or converters for the above H7's that fit F30 halogen housings ?
I know its a long post, but I just hope some one would reply ? Your help is appreciated.
Old 06-07-2017, 01:05 PM
Beholder Beholder is offline
Mein Auto: 2013 328i X-Drive
Originally Posted by amritanshukar View Post
Hi everyone,
I just ordered these 6000k LEDs from Bimmin
https://bimmian.com/Accessories-for-...og-Light-Bulb/
I also ordered A set of the Spektrum DRLs and A set of their Spektrum Fog lights since I saw mixed reviews regarding reliability on those iJDMTOY bulbs.
They are a little pricey but seem to be quality all have a lifetime warranty so I felt it worth the premium price.
If you signed up for their news letter and add them to your cart. Before ordering I got an email from Ed (a sales rep) with a code for 10% off. (Code was one time use or I'd give it to you). if you do the same I'll sure someone will reach out as well.
Old 06-07-2017, 06:28 PM
tturedraider's Avatar
Freedom isn't free!!
6000k will put out significantly less usable light than 5000k.
www.bmwcca.org
Old 06-12-2017, 12:41 PM
Mein Auto: Florida
Thanks for the response, let me check these out.
Old 06-12-2017, 11:14 PM
BimmerBoy328 BimmerBoy328 is offline
About 600 and is the best upgrade to halos matching the halogen connector plan to do this soon to my car.
Old 06-13-2017, 05:39 AM
2015msport 2015msport is offline
Mein Auto: 2015 328xi Msport
Here is what I did.
Very happy.
https://www.bimmerfest.com/forums/sho...ighlight=putco
Old 06-14-2017, 10:29 AM
So I just got my Lights installed (headlights, fog lights and DRLs.) I attempted to do the Parking lights but I apparently ordered the wrong bulb so will get those in next week.
The only problem I'm having is a momentary blink every min or so on the headlights- i coded the Fog lights and Blinkers per the coding cheat sheet but didn't see anything on how to code the headlights.
Does anyone know of the coding for those?
Old 07-24-2017, 02:56 PM
SIRI_F30 SIRI_F30 is offline
Mein Auto: BMW 328i 2014 Sports Line
This might help... they're great bulbs
Hi everyone,
I buy my H7 and H8 from this website, or from them through eBay, they're great bulbs and they carry multiple temperature colors.
http://www.gp-thunder.net/
