Fault Codes / Error Codes - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 05-11-2016, 12:44 PM
Sport_Coupe Sport_Coupe is offline
Mein Auto: F01 (730d)
Can anyone direct me to where there is a list of Fault/Error Codes for the F01?
I have the following two codes I would like to know what they mean:
e114a6
e12c3e
I found them using the instrument cluster error code option.
Many thanks in advance.
Old 05-12-2016, 12:39 AM
Robin750 Robin750 is online now
Mein Auto: 2013 750i and 2015 740i
E114A6 is no communication between KOMBI and JBE. E12C3E is invalid DSC signal.
You'll need ISTA/D and ENET cable to troubleshoot further, though it could also happen due to low battery voltage.
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 05-12-2016, 02:46 AM
Robin, thanks for that. Can you point me in the direction of a list so I don't have to keep asking?
Also is this any good for reading faults https://www.ebay.co.uk/itm/281674981119
Old 05-12-2016, 08:29 AM
There's no list, I looked them up in ISTA/D. That cable looks fine, but you'll need to look around for ISTA/D. It's >10GB.
delete pls 8K
*NEW* delete pls 8K
Old 06-21-2017, 10:00 AM
PrinceOfEgypt PrinceOfEgypt is offline
Mein Auto: 2011 BMW 535i xDrive
Hi Robin750,
sorry to revive an old thread but can you look up a few codes for me in ISTA/D? I would very much appreciate it!
these are from an F10 535i xDrive (2011) if it matters:
E12C32
E114A6
E12C24
E11420
Thanks a lot in advance!!
Old 06-21-2017, 11:48 PM
E12C32 - Signal (status brightness of surrounding area) invalid, transmitter JBE
E114A6 - No message (status, ambient brightness), receiver KOMBI, transmitter JBE
E12C24 - Signal (status, driving light) invalid, transmitter JBE
E11420 - KOMBI: ServiceCall cannot be executed
Seems like the JBE might be bad...what symptoms are you having?
delete pls 8K
*NEW* delete pls 8K
Old 06-22-2017, 05:15 AM
Thanks! I guess the previous owner fixed whatever this was.. the codes are from a much lower mileage (and I'm not seeing any issues)
Old 06-22-2017, 09:07 AM
Usually clearing the codes and seeing what comes back is a good start. These cars can throw and store a lot of random codes (and doing things like changing the battery can generate faults), so many times, faults don't need to be looked into.
delete pls 8K
*NEW* delete pls 8K
Old 06-22-2017, 11:59 PM
vien727 vien727 is offline
Mein Auto: f01 2013 750i xdrive
hi Robin, would you please help?
i have cel fault code p1435.
i did some search on the internet, and on one site they indicated that :P1435 is
Secondary Air Injection (AIR) Pump Relay -J299- Short Circuit to Ground (GND).
can you confirm if p1435 is the air pump relay error?
now im trying to find the location of the air pump relay, and it suppose to be here:
http://www.realoem.com/bmw/enUS/show...diagId=61_3766
however, when i open the plastic cover under the hood, i do not see the above configuration. i see this:
http://www.realoem.com/bmw/enUS/show...diagId=61_3752
where is the air pump relay? would you please help?
thank you very much.
Old 06-23-2017, 12:54 AM
P1435 - Tank ventilation system 2: Malfunction
Instructions say to check for leaks from the tank vent valve to intake pipe or replace fuel tank vent valve, and then reset mixture adaptation after the fault is fixed. Doesn't sound like a relay issue, but P-codes alone may not be sufficient to make a diagnosis.
delete pls 8K
*NEW* delete pls 8K
Old 06-23-2017, 07:43 AM
Robin, thanks for your help!
i was afraid you would say exactly that.
i've been to the local bmw dealers here for 2-3 times in the last 2 years over the same problem. they changed out the both left and right vent valves and did the smoke check to find leaks. after a few days of getting the car back, the cel would come back.
i was looking at this bmw cel code list here: http://www.bimmerboard.com/forums/posts/517875 and
i was hoping it would be something else. now im really lost.
vien
