E65 svs voice language change - Bimmerfest - BMW Forums
Old 06-07-2016, 07:12 AM
Proel Proel is offline
Mein Auto: Bmw 7 e65 2005 fl
E65 voice comand language swich
Hello, it is posible to change voice commands language? Because my car now speaks to me in german language and o want to change it to english
Old 06-10-2016, 06:39 PM
rippjd rippjd is offline
Mein Auto: 07 530xiT
Looking at the SP-DATEN data there are no coding files. This tells me you cannot simply re-code it to change the language. There are however flash file sets containing 6 - 8 files, likely each one is for a different language. You could probably use WinKFP to flash your SVS (speech module) to a different language, but would have to first remove SA851 (German) from your Vehicle Order and add SA853 (English).
2007 530xiT
2010 X5 35d, 2005 745i, 2000 740i, 1999 540i, 1994 525i - all SOLD but not forgotten
E65/E66 Parts for Sale: Alpina Type 743 Front Spoiler kit (new in box) $1200
Old 06-11-2016, 01:24 AM
Hmm what i hearing its very hard to do, i just got bought the car and i am waiting for obd cable to arrive, but i want to learn programming
Old 01-14-2017, 04:09 AM
Hello, can someone tell me how to change the language to english? I have read that it is hard codes and you cant do that, but it is a true or not? If not so how to code it?
Old 01-14-2017, 11:36 AM
aak745 aak745 is offline
Mein Auto: 745i 2003
Hi,
In the technical training PDF, I saw this :
'The SVS will initially be available in three languages: German, U.S. English and U.K. English.
Other languages may follow in subsequent years. There are currently hardware differences
between language versions.'
I don't know how to do it, but the file 12_E65 Speech Processing System may help you use the svs
Old 01-14-2017, 04:27 PM
Thanks, i have read that, more opinions?
Old 05-21-2019, 09:16 AM
PIFOUBMW PIFOUBMW is offline
Mein Auto: E65 745I 01/2004
I was able to code french langage using WinKFP with SG-DATEN because it contains official firmware for ECU then it's hard coded but you can change the firmware (a little complicated) you can read the last pages of https://www.bimmerfest.com/forums/sh...=600318&page=9 and you will have some informations to do it (same actions than for a Bluetooth TCU or a mmi upgrade)
Old 05-21-2019, 02:06 PM
vibbelito's Avatar
vibbelito vibbelito is offline
Mein Auto: 2007 730i E65
Just for reference as I also thought about changing it until I found out how cheap they are used.
This is the inside of the German version from 2006
Skickat frŚn min SM-G955F via Tapatalk
Old 06-26-2019, 08:27 AM
I was able to program french language in my 2004 svs voice module but it doesn't work with upgraded tcu , mmi and ask modules (after 2005) then I will attempt to program a 2007 module bought on ebay to see if it works.
Old 06-28-2019, 02:43 AM
vibbelito's Avatar
Well I just bought a UK version for 18.77 Euro including shipping so I won't bother with my German version.
Or maybe I'll try to flash it when I get my new one just because I won't have any use for it so it won't matter if it breaks. I will make sure to open up my uk one so we can compare the hardware as well.
Old 07-11-2019, 08:21 AM
vibbelito's Avatar
I can now confirm that the UK and The German versions have exactly the same hardware. That however doesn't mean automatically that one language can be flashed on the other. There could be some checksums in the software preventing it still. Just like that the e90 and e65 ACC2 sensors share the same hardware but still cannot have the software changed to the other...
This is the UK version
Old 07-11-2019, 08:39 AM
Angry
I had a SVS HW09 UK flashed in French which was perfectly working before TCU and MMI and ASK upgrade.
I received a 01/2008 HWOC module ans I flashed it in French too but same problem no sound.
I saw in a BMW doc that SVS output is made by the ASK module which makes the GONG sound when you press the voice button. I have no GONG sound and no voice then may be the problem comes from my 2006 ASK flashed with the last version because when I select Top_HIFI , it add Top_HIFI_ab2005 option which is not installed in my 12/2003 745.
But I retrofit the original ASK unit to test the voice and no vice again then may be problem from the MMI ???
Old 09-22-2019, 04:46 AM
Talking
For information, the VOICE Module SVS can work with retrofit TCU but you have to disable the Voice Recognition with NCSEXPERT in the TCU module or it doesn't work. I accidentaly found this working solution and now my SVS is perfectly working !
Old 09-22-2019, 04:48 AM
Smile
I flashed a English SVS module with WinKFP with a french language and it's perfectly working
