2007 750li rough idle - Bimmerfest - BMW Forums
Old 02-23-2017, 10:33 PM
oleg_k oleg_k is offline
Mein Auto: 2007 BMW 750li
Hello,
I have 2007 750li... Recently I noticed it started having rough idle rpm... I found that intake (throttle) boot is cracked. I replced it but the car still idles rough... No matter when - cold engine or hot... Any ideas? Did someone run into the same problem? Please help!?
Thank you so much!
Old 02-23-2017, 10:37 PM
Alika808 Alika808 is offline
Mein Auto: X5
OBD scan it and you could get the fault code. Maybe misfiring........
Old 02-23-2017, 10:39 PM
No codes. Check engine light is off...
Old 02-24-2017, 03:19 AM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
One of these three things are most likely causing the problem:
1. Split diaphragms or plastic hoses on one or both of the Crankcase vent valves
2. Valve cover/timing cover gasket leaks or oil filler cap gasket.
3. IVM (Integrated Supply Module) starting to go bad. If it's more than 6 years old replace.
Old 02-24-2017, 07:01 AM
Thank you, Ltmax! Really appreciate your response. I will check all of that.
Old 02-24-2017, 07:13 AM
One more question, Ltmax... So, I all those cases engine check light wouldn't come up?
Old 02-24-2017, 07:35 AM
Ltmax's Avatar
Many times you won't get a check engine light for these issues unless the air leak is really big. IVM problems don't cause any codes at all but cause many problems.
This is a great little article about all the problems the IVM can cause.
http://www.bmwlogicseven.com/?p=3812
Old 02-24-2017, 07:37 AM
Thank you, Ltmax!
Old 02-24-2017, 06:19 PM
Ok, took it to the shop today... They did a smoke test and no leaks. Ltmax, does this cover your bullet points 1 & 2? Forgive my ignorance, please? I am not an expert in these things...
Going to buy that IVM module, hope this will resolve the issue...
Was driving home today, every red traffic light was pretty annoying. First 5 seconds everything is fine then it starts again to the point of the whole car shaking. The minute you touch gas pedal, everything is gone...
Old 03-04-2017, 01:53 PM
Hi Ltmax,
Just replaced IVM but still the same thing... did not help that erratic RPM... Anything else you could think of?
Old 03-04-2017, 02:34 PM
Ltmax's Avatar
Did they check the CCV diaphragms and hose that connects CCV's to the throttle body?
Old 03-04-2017, 02:37 PM
I am not sure... they run the smoke test and told me that was the check of those... Is it? Or they were not honest with me?
Thank you
Old 03-04-2017, 02:41 PM
Ltmax's Avatar
No, you remove the plastic caps on top of the CCV's lift out and inspect the orange diaphragm for splits. Very simple to do, wouldn't waste my time taking it to a mechanic.
Old 03-04-2017, 02:44 PM
Thank you very much! I will try that.
Old 03-04-2017, 03:19 PM
Well, both diaphragms are good... I cleaned them and put them back but the video shows some vacuum lines connect to the covers... mine does not have those hoses... but there are the fittings on those covers where you could connect those lines... Do I suppose to have those hoses or some engines come without them?
Old 03-04-2017, 03:49 PM
Ltmax's Avatar
No you shouldn't have the small vacuum lines that attach to the CCV's. Did you gently open up the diaphragms when you inspected them, most times the tear or split can be difficult to see until you fold it open all the way.
Old 03-04-2017, 03:50 PM
Ok, thank you! Anything else? Is there a way to check MAF sensor?
Old 03-04-2017, 03:58 PM
Yes, I folded them out and they were consistently soft and no tears / cracks...
Old 03-04-2017, 04:46 PM
Ltmax's Avatar
I think that's about all you can do without a decent scan tool to try and start nailing down what the trouble is.
If it were me, I'd pull all the spark plugs and see what they look like, they may give a good indication of where to look next.
Old 03-04-2017, 04:53 PM
Thank you, Ltmax! I guess, I'll start doing these steps one at the time. I am not sure how scan tool could help me because there are no codes come up...
Old 03-04-2017, 05:54 PM
Ltmax's Avatar
With a decent scan tool you can check the fuel trims on each bank, read MAF, O2, coolant temp sensors and a bunch of other stuff that may point you in the right direction.
Old 03-04-2017, 09:00 PM
Thank you so much!
Does this have to be the shop scanner only or I could buy something for home?
Old 03-05-2017, 04:12 AM
blink_ blink_ is offline
Car Nut
Mein Auto: 750LI & Opel Astra Turbo
you could disconnect one of the vanos solenoids on the front of the engine, it will run fine like that, try it and see if your rough idle stops but do it with a cold engine, and once you start it, drive it straight away and see what happens, dont start it then stop it on your driveway
Old 03-05-2017, 08:11 PM
Ok, I will try that. Thank you, blink_. If I disconnect it, would it throw some kind of code? Your warning at the end - if I stop it I won't be able to start the engine?
Old 03-05-2017, 08:17 PM
Davegsu Davegsu is offline
Mein Auto: 645 ci
Do you have any oil residue under the car? I had a six series thatched the same N63 engine as your seven. This engine is notorious for oil leaks than can be so bad that it causes misfires from unmetered air. You may need to shine a light down to the belly cover to see any pooled oil.
Sent from my iPad using Bimmerfest mobile app
2007, 71000mls, 750li, rough at idle
