oil level will not read - Bimmerfest - BMW Forums
Old 02-04-2020, 10:01 PM
Ninamg7 Ninamg7 is offline
Mein Auto: 2014 BMW 435I M Sport
Good day all of you Bimmer Guru's.
I need a quick reply for my 2014 F32 Msport 435I, I can't get the oil level to read, it get up to 17% then it stops. Any Ideas as to a replacement part to fix this issue or maybe oil level too low? I have 8000 miles per BMW for next oil change and 61k on the ODO... thanks in advance,,,
Old 02-05-2020, 12:49 AM
namelessman namelessman is offline
Mein Auto: bimmer
Check out this thread, the issue may be oil level sensor:
https://www.bmwcca.org/forum/index.p...x-drive.10061/
Old 02-05-2020, 05:50 AM
carlson2005 carlson2005 is offline
Mein Auto: 2015 BMW 328i
I had a similar problem with my 2015 328i and it turned out to be a low oil level.
I had changed the oil recently, but not tightened the filter cover properly and it was leaking. Oil level showed normal right after changing it, but the leak dropped it down quickly to a point where the sensor did not work correctly.
Bruce
Old 02-05-2020, 06:04 AM
Doug Huffman's Avatar
Nuclear engineer
There is a PuMA document associated with replacing oil level condition sensors. Find your part number at RealOEM and likely the PuMA will be noted there.
Old 02-17-2020, 08:38 PM
[email protected] jcates455@gmail is offline
black msport
Mein Auto: 2013 328i msport
Mine did exactly the same thing at exactly 17%.....
Mine was about 150 miles after oil change I got a low oil pressure code .I stopped and tried to get a reading but it wouldn't go past 17%...I tried repeatedly but stopped at 17 each time.Then I remembered the oil change guy was in the car for an unusually long time,,he said he was trying to reset the oil change interval but that wasn't changed.
After a tow home I put a quart of oil in suspecting the oil place shorted me ..but that didn't fix it.Code for low pressure disappeared at rerstart.
I started checking for leaks or loose wires since no knocking or strange sounds like an oil starved engine would produce.I took the filter housing cap off and
GUESS WHAT???.......The dam oil change guy took the filter cartridge out and the oil bypass gizmo normally snapped into the cap came out with the cartridge.
He chucked them both in the garbage and dropped a new cartridge in without replacing the bypass tube. He must have just chucked the small o-ring you are supposed to replace and just closed the housing.
I went back in my wifes car and asked him by showing him a picture of what its supposed to look like with bypass installed.Amazingly,,,he admitted it (there is hope for this young generation) and we looked through the garbage and found it.
I replaced it when I got home and the oil level thing started reading just fine....
The weird thing is that I didn't get a code for low oil pressure until I had about 150 miles on it and not until I hit about 90mph on the freeway.I wonder if a code would have ever popped if I just drove it grampa style and never checked the oil level....It took awhile for pressure to drop to a level deemed dangerous by computer....Anyways....that's why my oil level gizmo wouldn't read past 17% If you wanna check..its easy...pull the top off off your oil filter housing (unscrew by hand ) and simply look to see if there is a black "tube" sticking out of the cap with a small o-ring on it.If the o-ring is missing it may behave very similiar
