2001 BMW Z3 3.0i - Harman Kardon Subwoofer Repair Worked! - Page 5 - Bimmerfest - BMW Forums
Old 10-22-2017, 08:50 AM
gwmed gwmed is offline
Mein Auto: 2001 Z3
Kick panels
Any instructions for removing kick panel speakers??
Old 10-22-2017, 10:19 AM
LT1 LT1 is offline
Mein Auto: Z3 3.0L
in my neck of the woods you can get a replacement unit, box and all from the local BMW parts recycler for $50.
I chose to buy a Kicker woofer and cut it to fit the standard box. the"'popping" noise turned out to be a bad amp that was clipping so I also bought an aftermarket amp, works great
it gets very hot so i mounted a standard computer fan scrapped from an old computer, using epoxy and it stays cool.
Old 11-20-2017, 05:24 PM
Mein Auto: 2001 Z3
Ok, pulled the sub and kick panel speakers, all 3 are trashed. So before I order the foam rings, are the speakers in the door conventional build also? Do I need to pull the doors apart and check them too???
Old 10-09-2018, 07:18 PM
brentwhitney brentwhitney is offline
Mein Auto: BMW Z3 & 330ci
Speed Sensor issue?
DSC not working & Cruise Control works sometimes.
The DSC in my 2000 Z3 2.8 does not work. The dash light does not come on as it should when I push the DSC button and when driving on snow or ice the rear wheels lose traction easily. I've had 7 BMW's so I know what it's suppose to do.
Also, the cruise control only works about 70% of the time. I have to stop the car, remove the key, and restart it to get it to engage.
I've been told it could be a wheel speed sensor. Should that show up as an OBD code. Any comments are welcome.
