BEST files for setting up DIS INPA ondow Window 8 ans 10 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 09-15-2015, 04:25 PM
wildcat1212 wildcat1212 is offline
Mein Auto: 2006 750Li
Hi
I have stumbled upon this treasure.
there are 13-14 files you need to cut and past web address , download them one by one
use 7 zip, to unzip/extract 1st file
it will automatically extract all files.
Its very simple set up works on any laptop, PC, even surface pro 3
only problem is is PC has SSD DIS hangs on black screen.
way around it is to put these downloaded files on external USB drive on incase of surface pro 3 I used 64 GB micro SD card and I works perfectly.
The guy has even enabled some of programming functions which were disabled with newer version.
here is the link:
http://cartechnology.co.uk/showthread.php?tid=2945
Enjoy.
Old 10-18-2019, 01:49 AM
Persuasive75 Persuasive75 is offline
Mein Auto:
Does this still work
dis, inpa, window 10, window8
HTML code is Off
