Heater cable adjustment on 2002 Z3 - Bimmerfest - BMW Forums
Old 10-26-2019, 10:54 AM
Z34TB Z34TB is offline
Mein Auto: 2002 Z3
Had to replace the control unit on my Z3 but now can't get it to change to heat. How do I get to the other end of the cable where it adjusts damper? The know turns easily so I suspect it came loose at that end.
Old 10-26-2019, 11:59 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
See if you can find what you need here, though I recommend going back to the home page, entering the last seven (7) characters of your VIN to get model-specific information.
You *might* get enough access from the rt footwell, but I expect you'll have to remove the glovebox to get proper access (that info is in the TIS too).
https://www.newtis.info/tisv2/a/en/e...ater-controls/
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black our first BMW
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2016 X5M Mineral White Metallic/Beige Dinan STG II (716hp/702 Lbs Ft)
Old 10-27-2019, 06:28 AM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
This post shows the far end of the cable at the damper (called a blend door):
https://www.bimmerfest.com/forums/sh...5&postcount=11
This post is about the near end of the cable, in case it has jumped out of the cam track:
https://www.bimmerfest.com/forums/sh...0&postcount=45
Old 10-30-2019, 01:04 AM
Mein Auto: 2002 Z3
Thanks for your help
Your guidance on the cable adjustment at the back end of the cable was just the trick. Toasty warm just in time for our first of winter.
