2020 X5 Night Vision - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 G05 (2018 - Current)
G05 BMW X5 produced between 2018 to Current. Discuss the G05 X5 with other BMW owners here.
Old 12-14-2019, 07:19 AM
rjabend rjabend is offline
Mein Auto: 2020 BMW X5 40i
I ordered my 2020 X5-40i with the rather expensive Night Vision and wanted to solicit experience with that option to determine if it is worthwhile. Thanks for any guidance.
Old 12-14-2019, 07:36 AM
gregmorin gregmorin is offline
Mein Auto: 2016 M4 or 2016 750i x
It is if you live in deer country. We've had it in two BMWs well worth it. You don't even need it on to work (ie the screen doesn't need to be active). The car uses the infrared eye to warn you of people and animals in and near the road.
Sent from my iPhone using Tapatalk
Current: 2017 430i 2017 X5 xDrive50i 2016 750i xDrive 2016 M4 Convertible 2015 328i 2011 335d 2007 335i 2006 325i
Past: 2011 Z4 sDrive 35i 2011 335d 2013 X5 35d
Old 12-14-2019, 07:40 AM
Thanks. I live a little ways out in the "sticks" in FL so it sounds worthwhile. I hope it shows alligators as well as deer
Old 12-14-2019, 10:11 PM
Dolce Vita Dolce Vita is offline
Mein Auto:
Can't put my finger on it, but I believe there might be a problem with thermal imagers and reptiles.
Old 12-15-2019, 12:50 AM
jadnashuanh jadnashuanh is offline
Mein Auto: 535ix-drive GT; i3 BEV
Reptiles are cold-blooded animals, so, might not show up reliably...the system is looking for hot spots, not colder or ambient ones.
Jim DeBruycker
Old 12-15-2019, 10:04 AM
Mein Auto:
D'ya think?
Old 12-16-2019, 11:25 AM
n1das n1das is offline
Mein Auto: 14 535d Xdrive, 12 X5 35d
I have the NV system in my 2014 535dx and love it. Things at ambient temperature appear as middle gray color. Anything warmer than ambient by even a very small amount appears to glow. Anything in the display colder than ambient appears darker.
Aluminum highway signs are the best indicators of what ambient temperature looks like. A sign appears blank because it's all at the same temperature. I've seen fresh roadkill still glowing because it hasn't lost all of its body heat yet. Bridges and other concrete structures appear to glow as they are still warmer than ambient from the warmth they soaked up during the day. Same with large rocks sticking out of the ground. Trees and plants glow slightly because they are alive and give off some heat. I've seen dead trees blend in with the ambient gray color instead of glowing brighter. Basically if it's alive it will produce some glow.
I've played around when parked by a store window. I look at the screen after holding my hand on the store window for about 10 seconds and I can see a thermal handprint left behind from where my had was.
Utility pole transformers glow because they are warm. Thermal leaks from houses in winter are easy to see.
Cops hiding in the darkness on the highway are easy to see due to the heat from their vehicle. I am aware of them before my headlights light them up. The cops can hide in darkness but they can't hide the heat from their vehicle.
Dry cold nights produce the best imagery. Different layers of cloud cover in the sky are easy to see which would not be visible to the naked eye. I have also seen "thermal twilight" in the sky well after sunset.
The NV feature is well worth it for better awareness during nocturnal driving.
Sent from my XP8800 using Tapatalk
David Sterrett, N1DAS
2014 F10 535d Xdrive M-Sport
2012 E70 X5 35d
Why DIESEL is better: (from wxmanCCM)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
Old 12-16-2019, 12:31 PM
Thanks very much for the great rundown. Very helpful!!
