2004 bmw e60 no communication with dme - Bimmerfest - BMW Forums
Old 12-14-2019, 03:20 PM
skets skets is offline
Mein Auto: 2004 bmw 530i!
i have a 2004 bmw e60 (530i) and the car does not start , the enging will tumble only once and will not tumble again unless i disconnect the battery and reconnect it , multiple mechanics told me the dme went bad and i bought a new dme together with the keys and cas but am still getting the same problem , the car has been down for the past 4 months any help or suggestion will be welcomed
Old 12-15-2019, 10:57 AM
SunglassesGuy SunglassesGuy is offline
Mein Auto:
Buy one of these, or similar, plug into socket by foot kick panel and see what it tells you. If there is no comm to DME it will let you know.
http://www.foxwellmall.com/wholesale...scan-tool.html
Jim from Austin
2004 BMW E60, N62, GA6HP26Z, Dynamic Drive, Sport Pak, Logic 7, Bilstein B8's, Ti Silver
1990 Pontiac Firebird Formula, T-Tops, 305 TPI, Maui Blue
Old 12-15-2019, 11:14 AM
i have a maxisys 908 but still no communication with dme , i even tried a launch and same thing
Old 12-15-2019, 11:46 AM
Mein Auto:
What is the error code?
Jim from Austin
Old 12-15-2019, 03:21 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
lol there will be no error codes with a DmE communcation problem..
you need to get your self the bentley manual and learn to read prints..
your going to have to go thru the harrness, the fuses all the connections
trouble shoot your OBD2 port
DME very very very rarely go bad.. So i cant get down with that.. more then likely you have wiring issues that look like a bad DME and no one took the time to actually confirm it
The 2nd dme doing the same thing would have been the big indicator.. PUT back all the original stuff you swapped out and start the diag process
your also going to need a Good meter and some electrical skills... Im intrigued i dont get to see a whole lot of these problems : there might be something here for me to learn..
Id like to learn with you on this one
get your self a Bentley service manual set so we can go over the prints together (we are going to have to troubleshoot the CAn first)
Specializing In Breaking Things Professionally
15486372<-----
Old 12-15-2019, 04:05 PM
Mein Auto:
That has been my mission to instagate discussion. I'm still waiting for an expert to answer my question
https://www.bimmerfest.com/forums/sh....php?t=1359357
Jim from Austin
Old 12-15-2019, 07:52 PM
bartelbe's Avatar
bartelbe bartelbe is offline
Mein Auto: 2xe39,e34,e32,e36
Jesus,,if multiple mechanics told you the dme is bad all over a no crank / start complaint then there idiots yes absolutely moronic idiots. Computers as burning 2nd mentioned rarely fail , in 20 yrs 15 at dealerships I have only seen 1 ecu well 2 but the 2nd the pins corroded off so technically the internals where ok. Also were going to need a little more info, what have you done so far ? Fuses, grounds,? Do you have a service manual, ? Any stored faults? Any relevant history? Can you communicate with others modules on the canbus?
Old 12-16-2019, 04:35 AM
I had a misfire and no codes , everything was fine but just a misfire and the car shut down and now not starting , the ignition comes on and the radio works , the ac fan blows , the lights work and am getting a set of error on the dash (transmission fault , abs fault , cluster fault but no engine light ) and when I try to start the engine turns over only once and it doesn't turn over again until I disconnect the battery pole and reconnect it and it will turn over once again. I have a brand new battery I changed the positive power cable .
Old 12-16-2019, 04:42 AM
Where do I get a Bentley service manual for it ?
Old 12-16-2019, 06:13 AM
Mein Auto:
both Pelican and ECS carry it.
Jim from Austin
Old 12-16-2019, 08:20 AM
Can u post a link
Old 12-16-2019, 08:31 AM
Mein Auto:
https://www.ecstuning.com/BMW-E60-545i-N62_4.4L/
https://www.pelicanparts.com/BMW/index-SC.htm
free over here
https://www.newtis.info/tisv2/a/en/e60-545i-lim/
Jim from Austin
Old 12-16-2019, 11:02 AM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
I can tell when it happened to me what it was, just something to check.
The sealed box it sits in had broken the seal then had water intrusion which basically fried it all.
Old 12-18-2019, 02:49 AM
ok today am friend is coming to check the kan lines using a oscilloscope will keep y'all posted with the info
Old 12-18-2019, 06:03 AM
mjchecko mjchecko is offline
Mein Auto: 535i
what is a kan line?
mjchecko
Old 12-18-2019, 05:18 PM
wires that transfer info to and from the system
Old 12-18-2019, 05:21 PM
Burning2nd's Avatar
Under the lift arms
K Can d D Can
the can is the wireing
Its spelled CAN not kan
Do you have more technical information ?
Im not sure scoping is the way to go at this point
15486372<-----
Old 12-18-2019, 05:24 PM
even better news , my friend got the car started today , apparently the some wires in the harness was fried so he replace them and the car started , there is a misfire and the number 6 coil misfiring so i am currently trying to source the part in new york will keep u posted ....
thanks for all the help thus far i really appreciate it .
Name:	WhatsApp Image 2019-12-18 at 12.19.13 PM.jpg
ID:	875905   Click image for larger version
Name:	WhatsApp Image 2019-12-18 at 12.19.14 PM.jpg
