LED conversion update - Page 12 - Bimmerfest - BMW Forums
Old 09-15-2008, 09:51 AM
Vinci Vinci is offline
DO IT YOURSELF.
Mein Auto: 98 M Roadster
Originally Posted by nicoloryan View Post
Ps: if the only solution at the moment is are aluminum resistors i've tried but it doesn't work on my car.
What value of resistor did you try? A resistor is a fool-proof method for correcting the quick flash that the LED lights trigger.
Old 09-15-2008, 10:58 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
A resistor defeats the purpose of the LEDs which use much less energy than the regular bulbs.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 09-29-2009, 03:38 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
6 ohm works for me. This combined with the flasher mod of replacing the metal strip with a schotke diode completes the LED conversion for the car. Whew that took a while to solve all the problems.
http://www.mouser.com/Search/Product...5cBTgQJ4Xsw%3d
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit, 1-touch lane change,
UUC Stage 2 flywheel/M5 clutch,
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler,
Trafficpro, A-pillar gauge kit,
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 09-29-2009, 04:04 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
Bob, I want one, would you consider making one for me?
Dave
Old 09-29-2009, 10:29 AM
A Clean Windshield
Dave
I could mod yours if you can't do it yourself. Can you solder? Its a matter of unsoldering that metal strip and replacing it with a diode. Let me know.
Old 09-29-2009, 11:29 AM
fastpat fastpat is offline
Gentleman farmer
Mein Auto: '98 Z3 1.9L, '90 325i Cab
I can see the use of of the Schotky, what controls its flash rate, that's unclear from the Schotky data sheet I downloaded from Mouser?
Are you going sans inline resistor with the Schotky?
Pat
1.9 liter M44, mods to come are mostly suspension and wheel/tire changes
Click thumbnail to enlarge
Old 09-29-2009, 04:28 PM
EOD Guy's Avatar
I can solder, what parts and where can I get them?
Dave
Old 09-30-2009, 03:42 AM
A Clean Windshield
Dave
this link is how to.
https://www.bimmerfest.com/forums/sho...t=38677&page=2
this link is the part
Old 09-30-2009, 06:56 PM
EOD Guy's Avatar
Ordered two Diodes- Schottky 8A 45V, thanks
Old 09-30-2009, 10:28 PM
cruisingdog cruisingdog is offline
Mein Auto: z4 2.5i roadster
OK, so I don't get how using a Diode is more efficient than a resistor. BOth devices will have a voltage drop across them an both devices will dissipate power. What am I missing here ?
2005 Z4 2.5i
Old 10-01-2009, 03:34 AM
A Clean Windshield
I really didn't care about the specifics. The stock flasher will not work with LED bulbs, this setup does. And its cheep.
Old 10-01-2009, 08:34 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
The diode only has to dissipate something like 0.4 Volts times the lower LED current. For sake of argument, let's suppose the LED lights draw a full 1 Ampere which is likely much too high. The diode only has to dissipate 0.4V x 1A = 0.4W which is more than an order of magnitude less power (and heat) than the 21W of a 6.8 ohm load resistor. The diode's low voltage drop, in series with the load, is the solution's charm. With LEDs, I bet you'll barely notice the diode is there.
Old 10-01-2009, 07:09 PM
OK, so I understand power etc. However I don't understand how the 'light blown' detector works. Does it need a voltage across it ? And if so is the resistor in parallel with the lamp or in series with it ? (ie a current sensor or a voltage sensor - or thermal ?). Just curious.
2005 Z4 2.5i
Old 10-02-2009, 03:00 AM
johnf's Avatar
John Firestone
The flasher unit resistance strip is in series with the load and produces half the usual voltage drop when a bulb burns out. The substituted diode introduces a higher voltage drop, above the threshold that triggers fast flashing, even when you hook up LEDs that draw less current than a single 21W bulb.
Old 10-05-2009, 10:58 PM
Got it! Thanks for explaining.
2005 Z4 2.5i
Old 10-06-2009, 03:38 AM
EOD Guy's Avatar
Got my diodes, took longer to get the cover off than fixing it!
Old 03-14-2017, 01:16 AM
dwonda's Avatar
dwonda dwonda is offline
Insane in the membrane!
Mein Auto: 1996 328iS
Hi am I missing something in this old thread? Everyone seems to be talking about ordering resistors (plural) more than one. I only need one correct? Thanks.
............_____\_(+)_/_____
Andrew /|O| [||||][||||] |O|\
1996 328iS OEM Frankenstein
Old 03-14-2017, 04:17 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Since the stock flasher circuit depends on the current through the turn signal lamps, and since LEDs draw so much less current than incandescent bulbs, installing LED turn signal bulbs usually results in hyper-flash. The resistors are needed in each turn signal circuit. They go in parallel to the LED bulbs. It's often easiest to put one at each corner, or you can sometimes just install one on each side.
Old 03-14-2017, 04:37 PM
dwonda's Avatar
Sorry I think you misunderstand, I am asking about modifying the relay.
Old 03-14-2017, 05:46 PM
This thread talks about a lot of ideas. It starts with the idea of load resistors. You need two of those (one on each side, 6 to 10 ohms each) to make the stock flasher work right. By the end of the thread, they're talking about modifying the flasher. To do that, you don't need any resistors, just a Schotky diode.
Old 03-14-2017, 09:38 PM
dwonda's Avatar
Cool, thanks!
