Cracked block - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 08-24-2019, 06:17 PM
Nasher16 Nasher16 is offline
Mein Auto: 97 328is
Cracked block
I was wondering since my head was cracked really bad(6 inches and you can fit a fingernail) if my block could be cracked too. Do the blocks crack easily?
Old 08-24-2019, 08:35 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
No. The block on your engine is cast iron. Only filling it with plain water and subjecting it to sub-zero temperatures will crack it.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 08-25-2019, 01:36 AM
dc_wright's Avatar
bimmerfest Supporting Member
^This^
I can't recall ever seeing a post where there was a cracked block from an overheat. Dozens (maybe hundreds) of cracked or warped heads.
Old 08-25-2019, 10:19 AM
Mein Auto: 97 328is
You got any ideas? Replaced everything besides rad hoses, tstat housing, rad, and heater core
Mein Auto: 97 328is
Boiling the coolant too
Old 08-25-2019, 10:26 AM
Doug Huffman's Avatar
Nuclear engineer
Nope. Steam is compressible, ice is not and ice is 4% bigger than an equal mass of water.
Old 08-25-2019, 10:51 AM
Mein Auto: 97 328is
I just put a different rad cap and new tstat and bled it and went and drove it a little bit then thrashed it and itís not boiling over or getting hot. Iíll let you guys know if anything else happens.
Old 08-25-2019, 03:14 PM
dc_wright's Avatar
Sounds like you didn't get it fully bled the first time.
Old 08-25-2019, 06:46 PM
Mein Auto: 97 328is
It still boils the coolant, just took more time now
Old 08-27-2019, 06:34 PM
Mein Auto: 97 328is
I used a block tester today and the results were fine. Still blowing coolant out the expansion tank when I stop. Iím thinking when Iím driving the water pump is spinning faster so that keeps the pressure down maybe? Any ideas would be greatly appreciated
Old 08-27-2019, 07:35 PM
Mein Auto: 97 328is
Maybe it blows coolant out when I shut it off it surges pressure and itís blowing it out to relieve it
Old 08-30-2019, 01:15 PM
nsguajiro nsguajiro is offline
Mein Auto: '99 328i Convertible
Is it running hot when this happens and how hot? When you cracked the head, were there any signs of oil ingress to the coolant system? Heater works?
Old 09-09-2019, 05:32 AM
Mein Auto: 97 328is
Cracked block
Not running hot, heater works great, no signs of oil in coolant system
