Two Mobil 1 Gear Oils-Is There A Difference? - Bimmerfest - BMW Forums
Old 03-15-2018, 07:47 AM
JAY11 JAY11 is offline
Mein Auto: 2000 BMW z3
In prep for Diff oil change, 2000 2.5 Z3 76k miles
1-Is this the recommended oil - 75w90?
2-What is the quantity required?
3-I see the second one has "L.S. Friction Modifier Included." Does this make a difference? Is there really a difference betw these two, what is it, and will either one be just fine?
Mobil 1 104361 75W-90 Synthetic Gear Lube - 1 Quart
and
Mobil 1 75W-90 Synthetic Gear Lube LS
Old 03-15-2018, 04:55 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
You do not want the Limited Slip friction modifiers.
Your newer-model differential is certainly a Torsen Limited Slip Differential (LSD) design, so it would do no good. In fact, older BMW differentials with clutch-style LSDs don't seem to benefit from friction modifiers either.
