BMW-Z3 EEP-1 Code - Bimmerfest - BMW Forums
Old 08-11-2006, 02:56 PM
JG-BMW-PA JG-BMW-PA is offline
Mein Auto:
BMW-Z3 EEP-1 Code
I keep getting a EEP-1 code on my milage display.
What is it and how do I fix it?
Old 08-25-2007, 02:39 PM
mjuhl2003 mjuhl2003 is offline
Mein Auto: BMW F01 730D
Hi
I have the same Error. How did you fix it.
Mjuhl2003
Old 09-18-2007, 03:45 PM
60manoa 60manoa is offline
Mein Auto:
Eep-1
[QUOTE=mjuhl2003;2599776]Hi
60manoa
Old 06-15-2008, 05:46 PM
digit_ill digit_ill is offline
Mein Auto:
Gauges don't work "EEP-1" error displayed where odometer is...
I am getting the same error "EEP-1" as well. It seems like when my car is out of the shade on a hot day this happens. Sometimes after I drive it for awhile and then turn off and on my car the error goes away and I regain use of my gauges. I saw a "PDF" that is available on the internet that appears that this could of occured from a possible diagnostics tool, used by the engineer where I take my car, frying the instrument cluster.
http://www.distools.com/PDF_manuals/...nual%208.0.pdf
I had a downing atlanta supercharger installed in my Z3, which is advertised in Bimmer magazine. This lead me to have my EMU customized, which is standard procedure for performace tuners. Dinan, a more popular name with BMW performance, also has an EMU upgrade avaialble. I first thought that it had something to do with me getting these modifications but now I think I may need to replace the instrument cluster.
I see everyone asking about how to fix this issue but I haven't seen an answer. I now know I'm not the only one out there with this issue and I have suffered through it for two seasons and want it fixed. My mechanic apparently has no clue and I could realy use some feed back from someone.
Thank You,
Eric Nelson
Old 07-16-2008, 09:12 PM
Martin335xi Martin335xi is offline
Mein Auto:
Question me too!
I am having the same problem on my 2000 z3. If it sits in the shade I get the EEp 01 error code and my gauges do not work. If it is in the sun for a while everything works. Has anyone had this repaired or diagnosed?
I appreciate the help.
-Matt
Old 04-05-2009, 06:56 PM
moringe moringe is offline
Mein Auto:
Thank You,
Eric Nelson
Did you finally get a fix for your EEP error code on your Z3?. Mine has the same problem...
Old 04-05-2009, 07:29 PM
Monolith Monolith is offline
Mein Auto: 1997 Z3 1.9L DASC Auto
I'll take a stab at this just for information's sake and to see if anyone can add to or clarify:
EEP-1 seems to indicate that position one of the EEPROM is ready to be read/written to for a mileage change/update. One tach update manual indicates to access two pins internal to the cluster to initiate this condition ("EEP-1"). Because it seems that it appears for you and others when a severe heat cycle occurs, I would guess that you have some bad solder joints, etc. that are expanding and contracting with the temperature.
If, this is the problem, it would be very hard to diagnose. Typically, in electronics work, a heat gun and/or cold air can be concentrated on suspected joints to see if the problem occurs. Seems you would need someone fairly well versed in the above topics to find the faults.
If it's just a one time thing, I would not pursue a fix. If it's actually stuck in that mode, the dealer should be able to help with the true meaning of the "EEP-1".
Some info links:
http://forums.bimmerforums.com/forum...&highlight=eep
http://www.bimmerwerkz.com/forum/3-s...lin-62674.html
http://bimmer.roadfly.com/bmw/forums/z3/7272700-1.html
As some of the above links indicate replacement of the cluster to fix the problem, I would, at a minimum, remove the cluster and clean all of the contacts and then insert, remove, insert to improve the contact. This would help if it was a bad external connection but not if it's a bad internal connection.
Mention of a BMW Service Bulletin here:
http://bimmer.roadfly.com/bmw/forums/z3/610365-1.html
BMW tech here mentions it's an internal fault code:
http://www.justanswer.com/questions/...ode-eep-2-2001
Old 03-25-2011, 08:16 PM
Kency Kency is offline
Mein Auto: Mercedes Benz E320 CDI
Solution for eep-1
Hello Community
I am not a BMW Fan, I am driving a Mercedes Benz E 320 CDI, my English is not so well and I live in Germany.
The problem that you have is a critical error in the Database of the Brain of Speedometer.
Solution:
1. Go to the next Company or Call a professional Person for manipulating of speedometers.
2. The Company/Man have to connect his Mileage correction Item with the Mainboard of the Speedometer via solder or clip.
3. Now he must set the clip on the EEPROM Chip who locted on the Mainboard.
On the Chip you can see the label "93CS56".
4. Now he must read the EEPROM and he HAVE TO take a backup of the EEPROM Data.
5. Next Step is RESETING all the EEPROM Data. (0000 0000 0000 0000 0000...)
6. Now he have to send the reseted EEPROM on the Chip via Clip. (93CS56)
7. When he finished this, he have to put together the Speedometer.
8. The last step is to programming the Mileage over the Item with a Cable.
9. Blue Connector of Cable in the Blue port in the back of the Cluster.
10. And holding the 3-PIN Connector in the 4-Hole port at the back of the Cluster
on the left side.
11. Software Connecting with the Speedometer - Changing Mileage.
12. FINISH
I hope everyone are happy now
PS: The same technique you can do on a BMW E36 Year: 1992 - 1994, but read EEPROM without Clip, but spring the encoder on the left side of Cluster. Put the Encoder in a adapter that is connected with the Mileage/Eeprom Item:
Backup - Reset EEPROM - Write Reseted EEPROM on the Encoder - Remove Adapter - Put the Encoder back in the Cluster - Cable of Mileage Item have to connected with cluster - BLUE Connector in Blue Port - 3-PIN Connector in 4-Hole Port - Software Connection with Speedometer - Changing Mileage = FINISH!
Best wishes from Germany and the Benz driver
Old 03-01-2018, 03:51 PM
LT1 LT1 is offline
Mein Auto: Z3 3.0L
eep-1 code
my Z3 also started doing this but with different circumstances. I only use it on weekend drives and each "fresh" start I have only the tripmeter and and speedometer. If I now drive it up and get gas for the trip, it will be correct upon restart, and everything returns.
Conversely if someone were unscrupulous, they could drive the car all day, knowing I have a 250 mile range, and then top off the gas upon return, I have now saved about 200 miles off my odometer each trip. then repeat next week the same way.
Old 04-18-2018, 08:36 AM
loliver loliver is offline
Mein Auto: 2000 M Roadster
I had the same issue on my 2000 M Roadster. It got progressively worse and I had to have a new instrument cluster installed. I use a highly qualified independent shop that only works on Mercedes and BMW. He had to send the new one off to BMW to have the odometer set to the current mileage reading. Part was $888.00 and labor was $275.
Old 07-04-2019, 03:25 PM
LT1 LT1 is offline
Mein Auto: Z3 3.0L
eep-1 error code finally fixed
this may not apply to everyone, but after 2 tears of stressing how much to fix this dead dash, I got it fixed by a mechanic who reset the speedometer (by means of diagnostic tool), and now it all works fine and speed is even accurate again. this guy didnt even charge me ( he was unaware of this problem and was just running a diagnostic check for a safetey inspection), I got a free fix!!!!!
Old 12-08-2019, 07:49 AM
JimZBim JimZBim is offline
Mein Auto:
First post for me... I got this code on my newly purchased 2002 Z3 3.0, when it was cold yesterday, 32F. Gone after driving to and parking at the store. Same dead tach, fuel, water temp gauges until restart.
Other potentially relevant details: previous owner installed LED headlights, I have read if not done correctly they can cause instrument cluster issues. Also, car had sat a long time prior to purchase, so yes I'm concerned about electrical/ humidity induced issues.
Hey, LT1, first time I read anyone potentially linking this with speedo cal problem, which I also have (reads about 20% high all speeds).
Do you have any details on how the speedo was "reset"? Maybe I could kill both of these at once also?
Similar Threads
6-cyl double vanos problem assessment (from Roadfly) chivas General BMW Questions 34 03-08-2011 02:29 AM
"The 1 Series will diminish the brand in the eyes of 7 Series buyers." Alex Baumann General BMW Questions 86 05-28-2008 01:43 PM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
Bmw Team Ptg Names M3 Drivers For 2006 American Le Mans Series tim330i Motorsports, Racing & Track 4 01-30-2006 02:41 PM
