oil level on 2002 325ci - Bimmerfest - BMW Forums
Old 05-19-2019, 01:41 PM
e46_lover e46_lover is offline
Mein Auto:
I got an oil change yesterday and I think they might have overfilled it.
the level is a bit over the second notch.
is that OK or should I drain some of it out?
the attached pictures are with the engine cold.
ID:	852451   Click image for larger version
ID:	852453   Click image for larger version
Old 05-19-2019, 02:22 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
I believe a little high is ok on the E46. Thatís what yours looks like. I think the E46 is more sensitive to low oil. Iím thinking you will get some others to chime in soon. You must have driven it home right? No issues?
Sent from my iPhone using Bimmerfest mobile app
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 05-19-2019, 02:42 PM
Mein Auto:
I took it out for a ride to warm up the engine waited the 5min as indicated in the manual and took another measurement.
Old 05-19-2019, 04:44 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2003 330ci (5 speed)
You are worrying about nothing. Slightly overfilled is a non issue. Even over a qt would be fine. These cars feature windage trays, so the chances of aeration are almost zero. Yes, 2 or 3 or more qts over, then Iíd worry. A minuscule amount over full is nothing.
Old 05-19-2019, 05:27 PM
All2kool's Avatar
All2kool All2kool is offline
Mein Auto: '02 BMW 325Ci Cabriolet
Agreed. When I change my Oil & Filter, I just add the entire 7 quarts even though the specification is for 6.9 quarts.
Old 05-19-2019, 06:02 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Which is the difference amounting to approximately two shotglasses full of oil. No need to lose any sleep over a tiny over-or-under fill....
The road goes ever onward....
(R.I.P. Jever)
Old 05-19-2019, 06:43 PM
Mein Auto:
Thanks all
e46 325ci oil level
Similar Threads
BMW uses pennzoil now?? s12512 E39 (1997 - 2003) 100 06-06-2019 05:17 PM
Wheels and Oil Pan ZaBumaFoo E36 (1991 - 1999) 1 01-19-2017 11:09 AM
Blue Smoke At Start up wjjklj 7 Series - F01 / F02 / F03 / F04 (2008 - 2015) 5 08-11-2013 08:00 PM
