Z3 Temperature dial broken - Bimmerfest - BMW Forums
Old 05-31-2011, 01:42 PM
wfbinder wfbinder is offline
Mein Auto: BMW Z3
Question Z3 Temperature dial broken
I have a 2001 Z3. I tried to force the temperature dial from cold to warm and something broke. The dial now turns freely and does not adjust anything. I removed the radio to access the back of the dial but could not see what was broken. Does anyone know how to repair the dial. It looks like if this is broken then the entire heating and cooling dial housing would need to be replaced.
Old 05-31-2011, 02:40 PM
kostverloren's Avatar
kostverloren kostverloren is offline
Mein Auto: DINAN Z3 3.0,18 330I,MINI
This one is a first for me. I have never seen this asked before, not because it hasn't happened probably, but because no one wanted to put it out there. Buy a new or used unit.
'02 Z3 3.0,'11 535xi,MINI
Old 05-31-2011, 03:26 PM
Ron Stygar's Avatar
19,585 Miles
https://www.bimmerfest.com/forums/sho...58&postcount=1
Old 05-31-2011, 03:54 PM
Mein Auto: BMW Z3
Thanks Ron for the info. I can reach in a move the air blending flap by hand and it doesn't stick so I don't know why the temperature control rotary switch was so hard to turn when it snapped. Just so I'm clear on kostverloren's response, I will need to replace the entire rotary knob housing. If so, does anyone have instructions on how to replace it?
Old 05-31-2011, 04:30 PM
Ron Stygar's Avatar
19,585 Miles
Did you look at the link on the top?
Old 05-31-2011, 06:39 PM
Mein Auto: BMW Z3
Yes Ron I read through it all. I'll have to check and see if the temperature control cable is attached to the bend flap lever. When I looked in I didn't see the cable end so I need to take another look at. I assume that is what you are refering to. That goes to my original question of how to repair it. I'm sorry if I'm a newbie but I was expecting more guidance than RTFM. Other forum answers were pretty specific on how to go about things. Even pictures were provided.
Old 05-31-2011, 09:42 PM
Ron Stygar's Avatar
19,585 Miles
https://www.bimmerfest.com/forums/sho...5&postcount=72
https://www.bimmerfest.com/forums/sho...7&postcount=78
Old 06-01-2011, 08:02 AM
Mein Auto: BMW Z3
Thanks Ron. That is exactly what I was looking for. I'm sure I'll be able to fix it now. I appreciate your patience and quick response.
Old 06-01-2011, 09:28 AM
Ooops. I read temperature guage instead of dial.
Old 06-02-2011, 09:22 AM
Mein Auto: BMW Z3
Thanks to Ron and the picture of the HVAC control backplate I was able to fix the temperature control arm. I took a small threaded eye lag and cut off the loop leaving a threaded post. I then screwed it into the temperature control arm and it works fines.
Old 06-04-2011, 05:00 AM
Randy Forbes's Avatar
Investigative Tinkerer
Similar situation here:
Randy Forbes
1999///M Rdstr Cosmos Black our first BMW
2001///M Rdstr Steel Gray
2016 X5M Mineral White Metallic/Beige Dinan STG II (716hp/702 Lbs Ft)
Old 11-01-2019, 01:50 PM
novagolfer novagolfer is offline
Mein Auto:
Hi, I am new to this forum and have the same issue. I can see that the nipple is broken off of the control arm for the heat. I am confidant that I can fix it if I can get it out - I was wondering if anyone can tell me how to remove the control arm?
Thanks in advance!
Old 11-01-2019, 03:39 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by novagolfer View Post
... the nipple is broken off of the control arm for the heat... how to remove the control arm!...
This may help:
https://www.bimmerfest.com/forums/sh...9&postcount=56
Be careful that this detent pin does not fall out:
https://www.bimmerforums.com/forum/s...9#post30045549
cooling control, heating control, temperature gauge
