Rear door vapor barriers (part numbers) - Bimmerfest - BMW Forums
Old 06-21-2012, 04:52 AM
4thBMW 4thBMW is offline
4th BMW
Mein Auto: 2002 540iT Sportwagon
I can not seem to find the p/n for the E39 rear left and right vapor barriers on realoem.com Anyone know those part numbers? Thanks....yes I'm leaking!
Old 06-21-2012, 09:29 AM
194449 194449 is offline
Mein Auto: '99 5-spd
On realoem.com, look under
Vehicle trim > insulation
Appears that this part differs if the car has the optional rear side airbags.
Old 06-21-2012, 12:01 PM
4th BMW
Thanks. I am assuming that would be this:
06 SOUND INSULATING DOOR REAR LEFT 1 51488159937 $29.09
06 SOUND INSULATING DOOR REAR RIGHT 1 51488159938 $29.09
I was looking for "vapor barrier" ?? Long story short...dried out my rear floors and re-sealed the original foam "vapor barriers" with new butyl. I used a 15 foot x 5/16" roll from NAPA. My original seal was pretty tacky still except the rear bottom corners, one bottom ft corner and 2 spots on top where the original butyl was rolled flat and came loose. I had enough to go over those spots and along the outside of the existing, original seal that was still in place. about to get another inch of rain in FL today...So, we will see.
Old 06-25-2012, 04:52 AM
4th BMW
I let the wagon sit out for 2 days....8 inches of rain??....No water leaking from rear doors barriers ! Note: the original butyl in the doors was still tacky and stuck to the new tape. I added extra butyl tape to the outside of the bottom, bottom corners and top of foam barriers. no air bags, It did not take long to do.
Old 07-10-2012, 08:53 AM
ECSTuning's Avatar
Instructor of the Stig™
51488159937 and 51488159938 are listed as Sound Insulation in our system. Below are photos of them
51488159937
51488159938
Typically you can get away with doing exactly what you did to the plastic vapor barriers, a little tape goes a long way one them.
ECS Tuning your #1 source for all things German automotive
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
[email protected] | [email protected]
Old 07-10-2012, 09:07 AM
cn90 cn90 is offline
You don't need the VB, you need "Butyl Tape".
Old 07-10-2012, 10:20 AM
rwhipple1 rwhipple1 is offline
Mein Auto: 528i
Just re-seal with silicone adhesive unless it's really ripped
Old 07-10-2012, 10:35 AM
Despite the fact that people say Butyl Tape is not perfect (what is perfect in this life anyway?), the beauty of Butyl Tape is that: when one needs to replace the Window Regulator, one simply peels the VB from the Butyl Tape.
The problem with Caulking (whether it is Silicone or "Liquid Nail" from Home Depot) is that: when you peel the VB, the VB may be damaged!
Old 07-14-2012, 07:47 AM
4th BMW
I see. Thanks ECST.
I't been a few weeks since refreshing the butyl tape under the old 'sound barriers'. it had been pouring rain about an inch a day recently and *NO* leaks whatsoever. So, the reseal worked using lots of tape on the bottom, bottom corners and top. Not that big a job and a must do if leaks start.
