What Type Of Engine Does It Have? - Bimmerfest - BMW Forums
Old 02-23-2017, 05:37 AM
JAY11 JAY11 is offline
Mein Auto: 2000 BMW z3
2000 Z3 2.3 LM92549 (last 7 of chassis) produced in Spartunbaurg.
I can't find in the owners manual what type of Engine I have. From correlating different information I thought it had the M52 but I can't tell with a certainty. The door labels don't have this info. I have read that this car is actually a 2.5 but BMW wanted to differentiate it from the 2.8 so they named it 2.3 yada yada. The closest matches on Cararac are 2.0 but with M54226S1 & 2.8 with M52B28TU. Other places list 2.5 -with M52 and 2.8. So is there a way to look on the car for confirmation?
Old 02-23-2017, 07:53 AM
SLOZ3 SLOZ3 is offline
Mein Auto: 2001 Z3 2.5i
Go to bimmer.work and enter the last seven digits of your VIN #. That will give you the production info.
Old 02-23-2017, 08:37 AM
alcofribas's Avatar
alcofribas alcofribas is offline
ZSCCA Asheville volunteer
Mein Auto: 2004 330ci
What type of engine?
Most likely M54.
Old 02-23-2017, 01:26 PM
NZ00Z3 NZ00Z3 is offline
Mein Auto: 2000 Z3 3.0i
You have a M52TUB25 engine. 2.5 L, twin VANOS. Its the same engine as fitted to the BMW 323 around 2000.
While it is a 2.5 L engine it produces power similar to the a 2.3 L engine.
There is not much difference between a M52TUB25 and the later M54B25 engine used in the BMW 325. The later having about a 21 HP increase in power. The differences are the M54 has larger valves, a better designed inlet manifold and a different DME/tune.
Old 03-24-2017, 08:22 AM
Originally Posted by alcofribas View Post
Most likely M54.
Thank you guys! Great info as I continue to learn more about this car.
Old 03-24-2017, 01:55 PM
Most likely M54.
Hey guys I thought I was settled on this or may be the engine type is, but I see this ///M sign (pic 1) on the steering wheel and a Roadster (pic 2) emblazoned on the door frame sill. What is the significance of this, is this car a convertible 2.3 Roady or an ///M Roady? Why do they put the ///M sign on the steering wheel?
I have owners manual but it's general and covers all Z3's. Unless it's listed somewhere I haven't seen yet?
Old 03-24-2017, 04:18 PM
Allan Parsons Allan Parsons is offline
Mein Auto: 2001 Z3
Factory simply eliminating "excess" M branded parts. I never seen a really good explanation, I do see the "occasional" Z3 on craigslist listed as an "M" based on the steering wheel,shifter,etc
Old 03-24-2017, 05:11 PM
OK makes sense. Thanx.
