New Full Featured OBD II Autoscanner - Bimmerfest - BMW Forums
Old 01-11-2007, 06:49 AM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
http://www.actron.com/whats_new_detail.php?id=6
Anyone know anything about these? Are they any better/worse than the Peak scanners?
It was one of the items featured at CES. According to the article you can update it from the web and its only $179. They say you can get it at local auto stores like Pep Boys and AutoZone.
Ken
Old 01-11-2007, 07:41 AM
Vinci Vinci is offline
DO IT YOURSELF.
Mein Auto: 98 M Roadster
Correct me if I'm wrong, but that style of scanner won't read the BMW-specific codes that the Peake tool reads.
Old 01-11-2007, 09:44 AM
Warning - Thin Air
Not sure, but their web site says:
"Use on all 1996 and newer OBD II compliant vehicles: North American, Asian & European."
Old 01-11-2007, 10:06 AM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
ODB II codes are universal
All readers will read ODB II codes, the Peake reader translates them to their own codes. The latest Bentleys manual has a chart of ODB II codes. I have used ODB II Explorer software to read codes on my Z.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 01-11-2007, 10:10 AM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Vehicle explorer and Auto Enginuity won't read my Z4 M Coupe or my friends E92.
Old 01-11-2007, 06:08 PM
I don't think a Peake will either
they only list cars to 2003. Z3's appear to be covered though.
Old 01-14-2007, 12:11 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Ron, do you have a close-up picture of the OBD-II connector in the car? Good enough to see which pins are occupied?
You could try what I'm using for my in-car PC project, which has thus far connected to everything I've tried it on. I haven't tried their software, since I'm writing my own. But for just reading DTCs, the terminal interface is sufficient. I haven't tried it on an E92 or a Z4M.
Elmscan5 from www.scantool.net
It's based on the ELM327 chip. Speaks ISO15765-4 (CAN), ISO14230-4 (KWP2000), ISO9141-2, J1850 VPW and J1850 PWM.
Daniel
2002 M roadster
Old 01-15-2007, 12:02 AM
Ron Stygar's Avatar
19,585 Miles
1, 4, 5, 7, 8, 9 and 16
Old 01-16-2007, 01:32 PM
dwm's Avatar
dwm dwm is offline
So by pinout it should be 9141-2 or 14230-4. I think you said it's 14230-4 in a previous thread.
I wonder what's on pins 1, 8 and 9.
What's the voltmeter say for pins 16 (should be ~ 12V) and pin 7 (K line)? Pin 4 is chassis ground, Pin 5 is signal ground (they should be about the same). Pin 7 is the K line, and from memory it should idle high (I'd have to dig through my SAE docs again to be sure).
Daniel
2002 M roadster
Old 01-16-2007, 04:50 PM
Ron Stygar's Avatar
19,585 Miles
Old 01-16-2007, 07:17 PM
dwm's Avatar
dwm dwm is offline
So pin 1 is additional power? What's on the other end of pin 8 and pin 9? I don't know what's hanging off of X183 and X243 and I don't have any electrical info for the E85 handy.
Daniel
2002 M roadster
Old 01-16-2007, 07:53 PM
Ron Stygar's Avatar
19,585 Miles
D_TXD1 and F_TD
TXD1 = Transmitt data 1 ??
TD = Engine speed signal
Old 01-16-2007, 08:36 PM
dwm's Avatar
dwm dwm is offline
D_TXD1 and F_TD
Looks like X183 is a bus connection. The WDS shows it going to the cluster, the steering angle sensor, DSC and EPS. I've no idea what protocol is on that bus. It looks like X243 goes to cruise control.
My WDS has very little info on E85 with S54. I've no idea how much of it is the same as the E46 M3.
Daniel
2002 M roadster
Similar Threads
A purist review of SMG II nate General BMW Questions 30 03-25-2013 05:47 PM
Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions EPBB E46 (1999 - 2006) 119 05-09-2010 04:09 PM
Comments please: Right fuel tank full and left tank close to empty yamato E46 (1999 - 2006) 19 01-18-2007 03:28 PM
