ACC retrofit-Active Cruise Control - Bimmerfest - BMW Forums
Old 11-04-2014, 11:06 AM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
ID:	474064 Click image for larger version
ID:	474066 Click image for larger version
ID:	474068 Click image for larger version
ID:	474070 Click image for larger version
ID:	474072 Click image for larger version
ID:	474074 Click image for larger version
ID:	474076 Click image for larger version
INSPI
Old 11-04-2014, 12:19 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Wow, this is amazing to see! I spent a long time looking for my 7 with ACC. How hard was the retrofit? Cost?
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 11-04-2014, 08:01 PM
hugo_za hugo_za is offline
Mein Auto: F12 650i
+100. Please could you explain the wiring. Been mulling over doing this retrofit, but there is very little info available.
Old 11-05-2014, 02:17 AM
I just follow instruction for this retrofit. Wiring-2 wires to CAN bus-connector in FR Wheel arch, 1 wire to the Fuse box in glove compartment, 1 wire to CAS and ground
Take me about 4.5 hour and cost me $250, because i get ACC for free
INSPI
Old 11-05-2014, 02:18 AM
Mein Auto: F12 650i
Could you share the retrofit instructions? Pretty please?
Old 11-05-2014, 07:29 AM
Instruction for preFL:
6138en.pdf
same for FL, just wiring is different:
INSPI
Old 11-05-2014, 08:54 AM
CarFanatic CarFanatic is offline
Mein Auto: BMW 750LI 2006
nice job man shows dedication , however it costs $$$ for the acc unit, im guessing you found a scarp 7 and ripped it apart and took the parts you needed ... LOL
Old 11-08-2014, 02:51 AM
And final adjustment
ID:	474747 Click image for larger version
ID:	474749 Click image for larger version
INSPI
Old 12-16-2014, 08:47 AM
Mein Auto: F12 650i
Question, did you car have a open grey black connector on the left (from the front), behind the bumper and below the lights? It is the one in the green block on the photo. I think my car is pre-wired for ACC.
Old 12-16-2014, 10:15 AM
2FASTFURIOUS 2FASTFURIOUS is offline
Send a message via MSN to 2FASTFURIOUS
Mein Auto: '03 745LI
inspi, i am planning for a retrofit of ACC at the same time, what a coincidence i am after ACC 1 tough. Because ACC2 is more complicated with brake sensors and other stuff. Your is ACC1 right? without brake version
Old 12-17-2014, 12:26 AM
fishmaker fishmaker is offline
Mein Auto: e66 745Li '02
Pls can you specify problems with ACC2 retrofit ?? I read technical instructions which inspi posted...and it looks there are some modifications inside radar....but other stuff is same
First EX: BMW e38 740i 6/95
Second Car : BMW e66 745Li - DP80552
Old 12-17-2014, 06:03 AM
You need SRRs and a dsc unit with acc , lots of wiring, maybe front bumper support for SRRs, too many things to list, possible but not worth i think. I will stick to original and retrofit ACC1 for my car
Old 12-17-2014, 07:22 AM
Mine is ACC2 and I don't have any connector behind bumper
INSPI
Old 12-17-2014, 10:59 AM
So you dont have stop&go function, right?
Old 12-17-2014, 11:58 AM
correct
INSPI
Old 12-17-2014, 02:17 PM
e65 can't get stop&go function....it's on F models....
ACC works over 30km/h in e65
Old 12-17-2014, 10:19 PM
Inspi, just to clarify a few points, i see that you didnt change your DSC unit, so your car is braking when the distance gets closer?? I know that DSC unit should be changed and brake sensors should be added to the axles for braking functions. I am searching for parts for retrofit, and if so i may consider adding ACC2 as you do. Thanks in advance
Old 12-18-2014, 06:46 AM
Yes, I didn't change DSC and car braking, when need it
INSPI
Old 12-20-2014, 10:40 PM
Mein Auto: F12 650i
My car is pre-wired. All i need is the front end wiring, sensor and stalk. The wiring that goes into the car is already in place.
Old 05-18-2015, 11:52 AM
Inspi, my car is at my mechanic for ACC retrofit. We finished connections however on the coding side, which changes did you do? i coded kombi and szl but i get an error as ACC failure. Can you explain the coding progress please? Did you FA write ACC?
Thanks in advance
Old 05-19-2015, 07:17 AM
I did it with ISTA/P. Just add ACC retrofit. Otherwise You have to add code for ACC(I thunk 541 and remove 540) to FA/VO and then code ECUs
INSPI
Old 05-20-2015, 12:35 AM
Thank you Inspi, I added 541 and FA/VA and coded. Now there is no ACC Failure error. But the car is in the shop without bumper now so when the car is standstill there is no vehicle sign or road sign in the cluster. Is that normal as it appear when you activate ACC on the road?
Old 05-20-2015, 07:36 AM
You can activate ACC after 30 km/h
INSPI
Old 05-20-2015, 02:27 PM
I will try to find hex numbers for lowering the min limit like 10km/h, to up around 200km/h ,I will share info if i succeed...
Old 05-27-2015, 09:30 PM
Mein Auto: F12 650i
The system is not made to operate at those speeds. At high speed the computer may not have sufficient calculating capacity causing the car to not react to changes in time and ultimately leading to an accident.
You have ACC working so why not leave well enough alone.
Sent from Tapatalk, iPhone 6 Plus.
