Engine Malfunction - Bimmerfest - BMW Forums
Old 05-16-2019, 03:44 AM
Cnwakobi Cnwakobi is offline
Mein Auto: 535i
Engine Malfunction
On my 2008 535i: coils, fuel injectors, spark plugs, Low Fuel Pressure Pump have all be recently replaced. I use Chevron Premium. Cars runs ok on gentle takeoff. However, when I step on the pedal hard on some takeoff, I get the dreaded "Engine Malfunction" light. If I pull over, turn car off and On, light goes out. Any ideas what is wrong
Old 05-16-2019, 06:25 AM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Might get better responses from the E60 forums.
Old 05-24-2019, 01:07 PM
dewana421 dewana421 is offline
Mein Auto: 2012 535i
Engine Malfunction
Connect a BMW scanner and READ ERROR CODES. No one can tell you anything correct without reading codes. Get a ENET cable and ISTA+ and you can do it yourself.
Old 05-24-2019, 02:20 PM
Krynos's Avatar
Krynos Krynos is offline
Mein Auto: '14 F10 550 & '13 F10 528
I had a 2009 335i with the same engine, and it had the same issues. Dealer solution was to replace the coils and plugs, then do a walnut blast of the intake valves. Ran perfectly after that.
Similar Threads
HELP! 2011 X5 35D Engine Malfunction Hard Start Raspooch X5 E70 (2007 - 2013) 13 05-20-2019 07:21 AM
Deal or no deal? dmichaud03 E90/E91/E92/E93 (2006 - 2013) 10 09-27-2018 12:20 PM
2011 550 Oil Low indicator back again sathya816 F10 / F11 (2011 - 2016) 65 08-12-2013 10:57 PM
BMW News: BMW Model Year 2011 Fall Update tim330i BMW News 1 10-01-2010 10:00 PM
