Why is premium gas recommended in a 320i? - Bimmerfest - BMW Forums
Old 02-08-2014, 08:32 AM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i (F30)
This thread isn't the many about which gas is better or if one should use premium.
The topic is why the 320i recommends premium gas. For the 328i, I can see. Hypothetically, maybe the 328i produces 240 hp with 93 octane and 231 with 89. These figures are made up. If so, why wouldn't BMW just make a 320i that produces 180 hp with 87 octane?
FYI, my paperwork says the car has 181 hp but the sales literature says 180. The owners manual states that premium is recommended but doesn't specify which octane. It states that 89 is required. The fuel filler door states 91 is recommended, 89 required. In Vancouver, 94 is sold. I haven't used it yet since it's more than $2/gallon more than 92 just across the US Canadian border.
Old 02-08-2014, 09:30 AM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
Let us know if you notice slower performance with regular gas on 320i.
Old 02-08-2014, 09:36 AM
HELLR0T HELLR0T is offline
It means bright red
Mein Auto: 96 E36, 14 F30
I put premium in all my car, required or not.
Old 02-08-2014, 10:42 AM
cleaver cleaver is offline
Mein Auto: 2014 328xiT
I suspect it's to combat premature detonation or "ping." As with all turbo cars, the effective compression is much higher leading to higher chance of pre-ignition. The cooling effects of direct fuel injection helps to alleviate this (hence the high 10:1 compression ratio), but the higher octane of premium will help more. The lower octane rating is a minimum, beyond which I suspect the computer's timing parameters may not be able to compensate.
Premium fuels also usually have higher levels of detegents, but whether that will do any good when the fuel still doesn't contact the valves to clean them is debatable (although I still use it).
Old 02-08-2014, 10:47 AM
gkr778's Avatar
gkr778 gkr778 is offline
Novice driver
Mein Auto: 2014 320i ZSP ZMT
Maybe because BMW calibrates F30 gasoline engines - N13, N20, and N55 - with RON 91-95 fuel, which generally corresponds to U.S. and Canada AKI of 89-91?
What the world needs is a few more rednecks - Charlie Daniels
Tell you about rednecks. They’re probably the only people in the whole country that ain’t unfit. - Fred Reed
God and guns keep us strong. That's what this country was founded on. - Lynyrd Skynyrd
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
I would think that with DI, higher detergents would keep the injectors clean(er).
https://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 02-08-2014, 11:06 AM
tturedraider's Avatar
Freedom isn't free!!
Then you're wasting money.
^ this. High compression motors require higher octane gas to avoid premature ignition and thus knocking.
www.bmwcca.org
Old 02-08-2014, 11:59 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less (again)
N20 compression ratio is no higher than the n52 which could run on regular. Both are not that high.
I suspect that BMW assumes that US premium gas is cleaner and has a problem with ethanol.
http://www.minotdailynews.com/page/c...id/575433.html
Old 02-08-2014, 12:13 PM
In the U.S. BMW calls for premium/91 octane in the N52 motor also. As they did for the M54 motor in the E46.
www.bmwcca.org
Old 02-08-2014, 12:20 PM
Saintor's Avatar
BMW recommends premium but 87 is the minimum required.
As for the N20 if I understand what I read above, 89 is required.
Old 02-08-2014, 12:32 PM
It means bright red
Great article in the topic
http://lifehacker.com/5846880/should...-gas-in-my-car
Old 02-08-2014, 01:27 PM
Dave 20T's Avatar
Super Moderator
I think I've figured out the answer, thanks to this and other fine bimmerfest posts. I don't have any laboratory proof, though.
My theory:
The N20 in the F30 can obviously be calibrated for different output. In the 328i, it's advertised as 240 hp but actually is (numbers made up) 240 hp/91 octane and 235 hp/89 octane. For the 320i, it's (again, numbers made up) 180 hp/91 octane and 176 hp/89 octane. For both cars, it's optimized for 89-94 octane. Putting 96 octane won't increase output. For this engine, they could have calibrated it to accept 87 octane but then it would only have benefited from 87-92 octane because the range of acceptable octane is limited.
Again, this is only a theory. Makes any sense?
For some drivers, it would have been better if the car were calibrated to accept 87 octane, especially in those areas with only 91 octane.
Contrary to many people's claim, using slightly higher octane gas can result in better gas mileage. I've noticed it. The EPA tested it and found the same to be true. However, the improvement in gas mileage was often only 1 mpg, not enough to offset the higher cost of premium gas.
Around here, there's 87, 89, and 92. 91 and 94 are available in Vancouver. I choose 92 because I don't want to pay a huge amount more for 94 and likely see little or no difference. Any experience with Chevron 94?
I've seen 85.5 in some Rocky Mountain states.
I once put some Aral 102 octane in the car while in Germany. I think 102 is about the same as 97 on the octane scale used in the U.S. and Canada.
