No sound from infotainment - Bimmerfest - BMW Forums
Old 06-19-2019, 04:09 AM
dirigo9871 dirigo9871 is offline
Had a 1978 320i for 14y
Mein Auto: 2014 F31 328xi Sport Wago
2014 328xi Sport Wagon; 75525; suddenly no sound of any kind from infotainment system; dealer says Amp failure and wants 2311 to "replace and program"; The dealer is the only one on the state (Maine) and I've always suspected they don't actually fix anything, they trend toward just replacing; I've never had an Amp of any kind fail. In general, lots of things have failed the most expensive so far being front suspension replacement. My old 320 went to 198,000 without major part failures. THOUGHTS?
Old 06-19-2019, 04:48 AM
Doug Huffman's Avatar
Nuclear engineer
I used to fix things at the individual component level, replace resistors on standoffs in six-sided circuitboard boxes. Then I learned to replace surface mounted device flat-packs with a $10K soldering station. Then I installed the first backfit microelectronics large scale integrated instrumentation system which manufacturer wanted to repair the subassemblies.
They days of fix it are quite over.
My VW diesel Jetta went almost 20 years and almost 200K with no 'fixing' required, only planned and preemptive maintenance and parts replacement. It never failed to start or run.
Old 06-19-2019, 02:07 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
BF member Technic owns a very high end car audio company, and is very generous with his time and advice. Why don't you hit him up and see what he says? You could also reach out to the folks at Bavsound. They are running a 15% off special through the end of the month, and I bet you could upgrade your system for less than what Bill Dodge wants to charge you. https://www.bavsound.com/
Current BMW's:
2018 340i RWD 6MT MSport
2017 540i MSport
2016 428 GC MSport
Prior BMW's
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 06-19-2019, 05:56 PM
Ziggy328xi Ziggy328xi is offline
Ziggy.
Mein Auto: 11 328xi N51
Ive had 4 cars come in with exact same complaint as yours and all 4 needed amps. if i were you id look into aftermarket amps and get a performance boost outta it stereo wise.
amp replacement, no sound
