'08 e93 ground clearance - Bimmerfest - BMW Forums
Old 10-06-2019, 09:50 AM
rugguy rugguy is offline
Mein Auto: 2002 325i
Fifth BMW. First e93. Two questions:
1.) How low is your e93? Mine has the M Package and only has 5-1/4" (13.33cm) of ground clearance and scrapes coming into my driveway.
2.) What do you think is scraping under there? I don't have an easy way to jack the car up so I can't see if it's the frame or something more critical.
Thanks in advance for any help or advice.
ID:	867201   Click image for larger version
2002 325i Darn Near Mint with 195k on the clock
2001 K1200 LTE
Old 10-06-2019, 10:02 AM
Nachfolger Nachfolger is offline
beemlyfe
Mein Auto: 2009 335i
Probably the front bumper. If you feel under the bottom lip, you will feel the scrapes. That is usually the only place that scrapes on a car.
Genesis 3:28: "And next he proceeded to form the naturally aspirated inline six engine and place it in a 50/50 weight distribution rear wheel drive chassis. It was given the spark of life, and the exhaust note was good."
(-) 2016 S1000RR, Race Package, Dynamic Package
(-) 2011 535i xDrive
(-) 2011 335i, Automatic (), Convertible
(-) 2009 335i, M-Sport, Manual, Dinan Stage 2, Performance Package
(-) 2005 CBR600RR
(-) 2003 330I, ZHP, Manual (my pride and joy)
(-) 1997 CBR600
Old 10-06-2019, 10:05 AM
Definitely not the front lip. There is a peak in my driveway to divert water. Once the front wheel goes over it the driveway slopes down creating a fulcrum at the chassis midpoint. I'm trying to find out if the car has been lowered or if the current ground clearance is normal.
2001 K1200 LTE
Old 10-06-2019, 01:04 PM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is offline
Mein Auto: E93 335i, somewhat mod
Check [here], Appendex A
Old 10-06-2019, 01:10 PM
Great resource thanks. I did all my own work on my e30 and e46 and all my motorcycles. Will have to build the tool assortment to work in this beauty thanks
2001 K1200 LTE
Old 10-08-2019, 06:13 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK, Q5
sounds normal
Old 10-08-2019, 06:24 AM
Can anyone tell me what the ground clearance should be on a stock, non-lowered 2008 e93 with M Package wheels?
2001 K1200 LTE
Old 10-08-2019, 06:57 AM
Markst Markst is offline
Mein Auto: BMW 5
BMW doesn't specify standard ground height but wheel clearance. These are the numbers for the E93, measure from the bottom edge of the rim to the lip of the wheel arch, passing thru the middle of the wheel.
Old 10-08-2019, 07:07 AM
Black Valkyrie Black Valkyrie is offline
Mein Auto:
Last week I changed my dmtl pump. Discovered very quickly that the bilstein lowering kit meant that my low profile jack no longer fits under my car. No big deal. Just drove it up a portable ramp and then put the jack under it.
Old 10-08-2019, 07:25 AM
Thank you
2001 K1200 LTE
