How do I fix this without adhesive? - Bimmerfest - BMW Forums
Old 01-05-2020, 12:56 PM
FabioSuave FabioSuave is offline
Mein Auto:
This frame on my passenger side won't stop falling down. It's the vibrations of me driving. Quick fix that doesn't involve glue anyone? I just don't want it to be messy or look bad.
ID:	877577   Click image for larger version
ID:	877579   Click image for larger version
Old 01-05-2020, 12:59 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Probably a thermoset plastic. Reheat it and bend it back to its original dimensions. I believe that the radius of the large curve must be smaller so that the edges hooks hold it in place.
Old 01-06-2020, 06:05 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Outside of the scientific answer, the use of heavy duty Velcro or lighter load for ease of removal
Old 01-06-2020, 06:45 AM
BimmerBoy3 BimmerBoy3 is offline
Mein Auto: 2005 BMW 645ci Vert
I think this happens to most e64s. I fixed it with a little bit of gorilla glue. It wasn't messy at all and you can't even tell it's been glued.
Old 01-06-2020, 07:06 AM
Nuclear engineer
What do you do when you must remove that trim piece now glued? OPie said "without adhesive."
Old 01-06-2020, 07:07 AM
ImTribble ImTribble is offline
Mein Auto: 2008 650i Convertible
I fixed mine with black gasket seal. Remove the old stuff from the peg then add the new gasket adhesive on it. Hasn't fallen down in 2 years in the Texas heat.
Old 01-06-2020, 07:43 AM
I used two thin lines of glue, just enough to stop it from falling on its own. It can still be removed with any real effort.
Old 01-06-2020, 08:29 AM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Double sided type will also work, just make sure the bottom of the piece is slid all of the way down in the front of the dash. Remember that there is also an airbag located on this piece, so be careful. Disconnecting the negative side of the battery would be a good idea.
Old 01-06-2020, 08:37 AM
I don't understand why you don't want adhesive. The little clips come off. If I recall correctly, you push them down and towards the front windshield.
Old 01-06-2020, 08:42 AM
Super Moderator
I was also thinking there should be clips, but I can't remember since I have not removed that piece of trim in many years. Most all car makes have snap in clips, but this is a BMW!
Old 01-07-2020, 03:52 PM
carsbillz4 carsbillz4 is offline
Mein Auto: Z3 3.0 Roadster, X3 30si
Good answer Doug. Reheating is not that difficult and the best answer unless you use an adhesive
Bill
Old 01-08-2020, 04:43 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
This would really get to me! But anyways try the adhesive e6000... when dries (and it dries quickly) it can stretch. And removes with a little rubbing. Good stuff a little goes a long way.
Sent from my SM-J727T using Tapatalk
[FONT="Arial Black"]
Old 01-12-2020, 02:11 PM
msa9167's Avatar
msa9167 msa9167 is offline
Mein Auto: 2009 BMW 650I
They are held in with clips and a screw behind the SRS sign for coupes. For convertibles there is no SRS sign and held in by push clips.
Coupe
https://www.realoem.com/bmw/enUS/sho...diagId=51_6839
TIS
https://www.newtis.info/tisv2/a/en/e...mrests/E0gcJZj
Conv
https://www.realoem.com/bmw/enUS/sho...diagId=51_6779
TIS
https://www.newtis.info/tisv2/a/en/e...mrests/DxYoiN7
Sent from my iPhone using Tapatalk
Old 01-13-2020, 06:48 AM
roseng's Avatar
roseng roseng is online now
Mein Auto: 2016 528i + 2007 650 Vert
Same thing happened to me. I removed the piece and re-glued the clips on with gorilla glue. Worked fine and that was over a year ago.
07' E64/Black....14' F10/M-Sport White
Old 01-13-2020, 09:29 AM
Super Moderator
I thought I remembered some clips on mine, not that they would come loose.
Old 01-13-2020, 12:26 PM
Maui530 Maui530 is offline
Mein Auto: 2006 530xi AWD SW
Glue one or two small but strong magnets to the inside of it where it would come in contact with the frame of the car.
