Cooked headlight wiring - Bimmerfest - BMW Forums
Old 06-22-2019, 11:38 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Recently I had both wheelwell covers off to access the headlight bulbs for an LED conversion. While accessing the bulbs I noticed the insulation on the headlight wiring was quite brittle and was actually missing in several sections. I checked the other side and found the same story. It was bad enough that a couple bare wires were touching each other.This helped to explain why my "bulb out" warning light would come on at random, despite all bulbs working.
I believe the extreme heat generated by the halogen bulbs (and trapped under the air tight covers) cooked the insulation over time. I ended up rewrapping the wires in heavy duty heat shrink, and that took care of it. Hoping this helps someone.
[SIGPIC]
Old 06-30-2019, 10:41 AM
Patrick Gent Patrick Gent is offline
Mein Auto: 2007 M Coupe
I have noticed the same thing with the wires to my angel eyes. Have not paid attention to the headlight wires, but the insulation on the angel eye wires is dry, cracked and fallen away. It is not just near the headlights, so I don't attribute it to heat. My service guy tells me it is common and a bear to try to fix. Just one more thing where the Ultimate Driving Machine is no longer the super well built piece of German engineering. And yes, I love my M Coupe and wouldn't let go of it for the world, but I am regularly disappointed with the engineering.
Old 03-02-2020, 04:49 AM
GaryDZ GaryDZ is offline
Mein Auto: 2007 Z4
I have not seen this (yet). Just an idea that might work (patch). Maybe a liquid tape type product might work to restore the insulation. I have not researched the best one, but it might work. https://www.amazon.com/Gardner-Bende...153060&sr=8-20
Old 03-02-2020, 06:08 AM
Doug Huffman's Avatar
Nuclear engineer
Wires touching do not cause "bulb out" but short-circuit intervention as by FRM / LCM. "Bulb out" is caused by external lights circuit monitor for OPEN circuits like a burned out bulb or broken wire / connector.
Old 03-02-2020, 06:14 AM
Nuclear engineer
Gardner-Bender upper temperature limit 200F
