Which bolt is this? - Bimmerfest - BMW Forums
Old 02-24-2020, 12:49 AM
manoweb manoweb is offline
Mein Auto: Z4
Which bolt is this?
I was changing oil the other day on my wife's Z4 and I noticed this bolt:
It's a 13mm head, I tried to tighten it but it was pretty hard to turn, so I started trying to lookup some information on what it is. I don't want to torque it down inside the aluminum block and strip something. Any advice?
Old 03-10-2020, 06:27 AM
impreza276 impreza276 is offline
Mein Auto: BMW Z4 3.0si 2007 AT
This is a guess but I vaguely recall seeing such a bolt used too assist in the adjustment of the alternator, and it was meant to stick out just like that. My advise is not to touch it for the moment, it probably is just fine.
Old 03-10-2020, 10:06 AM
Clearancediver's Avatar
Clearancediver Clearancediver is offline
Mein Auto: 2004 Z4, 2009 Nomad mc
Likely used to adjust the alternator to “line” up into the proper position for its pulley to be parallel with everything else when v belt installed.
If you look closely at what it “pushes” against... you will see that if you loosen off the bolt securing the alternator in position, you would be able to adjust the alternator backwards if you tighten “that bolt”... alternatively... backing off on “that bolt” in question will allow the alternator to move slightly forward.
I’d just leave it alone as suggested as it would have been a factory adjustment at time of assembly.
Sent from my iPhone using Tapatalk
