Clock keeps resetting - Bimmerfest - BMW Forums
Old 03-23-2020, 12:00 PM
Gregory_tolson Gregory_tolson is offline
Mein Auto:
Has anyone had an issue where their clock keeps resorting back to --:-- on the gauge cluseter/radio when turning their car back on after it sits off for a while? Ive tried setting it while the car is running but itll always clear when i turn the car off for a while and turn it back on. Its just been an annoying problem.
Old 03-23-2020, 02:14 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
how old is the battery ?
Old 03-23-2020, 04:49 PM
Mein Auto:
Not sure, bought the car last year, its got a BMW battery with the indicator showing black which means its not fully charged. Ive been trickle charging it during the winter no problem though and starts right up.
Old 03-24-2020, 06:26 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Indicative of a weak or failing battery. Fully charge the battery (a trickle charger doesn't necessarily fully charge) and see if the problem continues, if so a new battery is in order. Trickle charging is good to maintain a healthy battery but not to revive a failing one,
Old 03-24-2020, 07:14 AM
Doug Huffman's Avatar
Nuclear engineer
Just like your VCR? I suspect that half of the VCR display clocks in the world are blinking.
Old 03-24-2020, 08:00 AM
HoppysZ4 HoppysZ4 is offline
Mein Auto: 2007 BMW Z4 3.0SI
When I first got my car the clock memory was doing the same thing. I replaced fuse number 24; 5 amp; no problems since.
Old 03-24-2020, 09:03 AM
Mein Auto:
I looked up the fuse #. Says its the instrument panel and steering angle sensor. Would i be having steering angle sensor issues? Was your fuse blown?
Old 03-25-2020, 05:10 AM
It was 4 years ago, so I'm going by my notes I wrote down; I replaced both fuses number 24 and number 9; I believe fuse 24 was blown and since I replaced #9 I'm guessing that was blown too. My OBD port wasn't working which had something to do with #9 fuse. I would check #24; you have nothing to lose.
Old 03-25-2020, 09:30 AM
MileHighZee MileHighZee is offline
Mein Auto: 2007 BMW Z4 3.0Si
perhaps check for loose connections at the battery terminals? Just enough wiggle to lose power for a moment could reset the clock.
-J
'07 Z4 3.0si
Old 03-27-2020, 08:15 AM
fauxauditor fauxauditor is offline
Mein Auto: 2005 Z4 3.0i
I've had the same thing. These cars are Uber sensitive to voltage fluctuations. They eat batteries, especially if they are not driven routinely.
Old 04-19-2020, 05:04 PM
Mein Auto:
Just checked both fuses, none of them were blown; making me think the battery in car is the culprit.
Old 05-31-2020, 08:08 PM
Jay Arras's Avatar
Jay Arras Jay Arras is offline
Casual Fanatic
Mein Auto: 2007 530xi 6 speed manual
Had the problem on my car today. Started the car, reset the clock. Shut the car off and the problem returned. Then drove the car, reset the clock again and it was fine. Just one of the unexplained electrical gremlins I experience from time to time. Another one is the driver's window or sunroof refusing to open/close. Stop/start the car and it's okay again. The passenger seat belt warning chime is a third. I've just learned to live with them.
2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
