Trunk gas pressurize spring - Bimmerfest - BMW Forums
Old 04-20-2008, 07:47 PM
bmw7833's Avatar
bmw7833 bmw7833 is offline
Mein Auto: Year 1997 E39 M52B25
How to change the trunk gas pressurize spring? I had try to search but found nothing to help me DIY..
Anyone try to DIY before??
Live the e39..!!
Old 04-20-2008, 08:08 PM
Raymond919 Raymond919 is offline
Mein Auto: 1997 BMW 528i
Are you referring to the gas cylinders which hold the trunk lid open? I'll have to change mine also but haven't looked into that yet.
Old 04-21-2008, 02:28 AM
bmw7833's Avatar
Yes..the small size absorber..
Live the e39..!!
Old 04-21-2008, 03:01 AM
E36 Phantom's Avatar
I Am The Machine
Try searching for trunk shocks. I know that "gas pressurized spring" is BMW's official name for it, but no one calls it that. It should be a simple matter though, just unbolt it, and make sure to support your trunk in the process! I'm assuming you already have the part?
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 04-21-2008, 04:07 AM
bmw7833's Avatar
Thks guy..
I saw a small white pin on the top of the shock, how to unpin it?? Can i re-use the pin after i install the new shock??
Live the e39..!!
Old 04-21-2008, 04:11 AM
bmw7833's Avatar
But i still can not find any with 'trunk shock'..
Live the e39..!!
Old 04-21-2008, 07:30 AM
BorisKV BorisKV is offline
Mein Auto: 98 528i 5spd, 08 X5 4.8i
Some people call them trunk struts. I replaced mine couple weeks ago. Very easy to do.
1. Support your trunk in open state and do one side at a time (it is very heavy).
2. Remove retaining semi-ring on top - just push on its ends with flat screwdriver on the opening side. Just make sure you will catch it when it will pop out.
3. On the ball joint side of the strut - you have to use thin flat screwdriver and stick it under that metal flat spring clip and either pull it out or slide it to the side. Basically you have to move it enough so that it will not hold to the ball. Once you will try it you will understand what you need to do.
4. Remove your strut by sliding top portion to the side and wiggling bottom ball joint away from the ball.
5. Installation is in reverse.
Old 04-21-2008, 06:57 PM
bmw7833's Avatar
Ok, will try to DIY later..
Live the e39..!!
Old 04-23-2008, 12:53 AM
bmw7833's Avatar
Hahh, changed it!! Simple as ABC..
Live the e39..!!
Old 04-23-2008, 01:11 AM
I Am The Machine
Congrats man, glad you got it. Sorry no one knew what to search for.....lol.
// Chad //
You're a derbanana
Old 04-23-2008, 01:50 AM
bmw7833's Avatar
Thanks guy..
Live the e39..!!
Old 04-23-2008, 01:37 PM
You are welcome. Told you, it is very easy that's why no writeup.
Old 07-01-2015, 01:33 AM
eburnz's Avatar
eburnz eburnz is offline
30FF <3
Mein Auto: 2007 335i sport
sorry to bump old thread, but are the little ball struts removable ?
like can you unscrew just that part?
2007 BMW 335i Sport
Gone but not forgotten:
2007 550i SMG AMRTuned (Prod. 10/2006)
2004 BMW 530i (Prod: 7/2004)
2001 BMW 525i (Prod: 10/2000)
"Call it what you want, it's a BMW"
Can you beat this?
Old 07-01-2015, 07:54 AM
flyride flyride is offline
Mein Auto: 530i, 330i, M3
As mentioned there is a circlip that holds the strut to the ball. Pry off the circlip and the strut will pop right off. Don't let the trunk hit you in the face the first time you open it with new struts.
Old 07-01-2015, 08:11 AM
I typed /trunk f3 in the bestlinks and this came up
- How to replace your trunk shock absorber struts (1)
Old 07-01-2015, 10:47 AM
eburnz's Avatar
30FF <3
Both of you misunderstood me...
I'm asking if the little ball strut comes off the entire pump I'm trying to add some die springs to it but cannot get over the "ball strut"
2007 BMW 335i Sport
Can you beat this?
Old 07-01-2015, 12:19 PM
All I did was point folks to the DIY that cn90 wrote.
If the answer isn't already in that DIY, I'd be surprised because cn90 does good DIY writeups.
Are you saying cn90 didn't cover this topic in his DIY I pointed everyone to?
Old 07-01-2015, 01:27 PM
No, he wants to rig it with a supplemental spring so he doesn't have to buy new struts.
Stabilus is the BMW OE manufacturer, you can get a set for $50.
https://www.fcpeuro.com/products/bmw...13-51248222914
Old 07-01-2015, 01:59 PM
eburnz's Avatar
30FF <3
Cant say, but ill have a look at his DIY, thanks for the info bluebee....
Actually, my struts works perfectly fine, I want to mod mine to auto open.
2007 BMW 335i Sport
Can you beat this?
Old 07-01-2015, 04:38 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
What's a "die spring?"
Can't imagine why you'd want to kludge it when the struts are so easy to replace.
Old 07-01-2015, 07:01 PM
Good information for this thread:
- What brand is the OEM part original equipment manufacturer for your BMW (1) & what parts & supplies are best to buy OEM (1)
Old 07-01-2015, 07:39 PM
Ah, like the JB Weld threads, I missed the point entirely!
Mea culpa.
As I explained in a VANOS solenoid check valve thread today, since almost all questions have detailed answers already and it's just that the OPs don't look for them, my MO, as of late, has been:
> E39 (1997 - 2003) > M62TU vanos solinoid check valve
... stuff deleted...
I don't see anything clever in what I wrote.
A question was asked, and all I did was look up the question.
Since I found that answer in the same spot anyone would look, I had wondered if the procedure was missing a step or three (it happens).
Nothing clever whatsoever.
Let me tell you my M.O. for most threads:
a) I skim them (if it takes me more than about five seconds to skim the entire thread, that's too long).
b) I decide what the basic question is talking about
c) I type the keywords and provide the link
d) I move on to the next thread.
Since I skim threads, I can easily get the specific question wrong; but, I generally have the general topic figured out in those few seconds.
In most cases (99% of the time lately), the answer to the question has been well documented (as it appears to have been in this case), so, my MO should work if the person clicks on the links.
In this specific case, I had known (from the way the OP was written) that the OP had already said they had clicked on the links, so, I clicked on them myself, to see why they hadn't answered their question.
When I saw the answer as plain as day, I questioned my assessment of the problem set (which sometimes I get wrong).
In that case above, the OP simply didn't read the (very detailed) Besian DIY before asking the question; however, in the case of the thread here on the shock ends, the OP knows about the DIY and the OP is asking a specific question that is apparently not covered in the DIY.
For that, I'm no good, and I pass.
Kudos to the OP for asking how, and thanks to you for explaining that I missed the point, but, I can't help here, since I've never done the job.
I can only reference the OP to those who did (and I've done that).
Old 07-01-2015, 07:53 PM
eburnz's Avatar
30FF <3
Mea culpa.
Thanks bluebee u know I appreciate any and all the info u give here, you're like the wiki for bummerfest lol no lie...
But yes this mod isn't covered in none of the DIYs here of course before making this thread I searched and didn't find anything.
I also am replacing my old struts with new OEM struts and is on its way... Thanks to the given reference in this thread hopefully these new struts the ball joints can unscrew so I can begin my mod.
Thanks again
2007 BMW 335i Sport
Can you beat this?
