The NEW official E36 OT Thread!! - Page 18 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Closed Thread
Old 03-03-2014, 03:38 PM
E36 Phantom's Avatar
I Am The Machine
I disagree on the auto as well. You can always use a higher gear to start to avoid spinning the tires, compared to autos that usually max out at 2nd.
C:\>Sent from my 386 using MS-DOS__
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 03-03-2014, 03:39 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Solution: Get good snow tires, with an LSD or locking diff. Drop the clutch, proceed and ain't care.
-CJ
  #428
Old 03-03-2014, 03:40 PM
dwonda's Avatar
dwonda dwonda is offline
Insane in the membrane!
Mein Auto: 1996 328iS
That doesn't make sense from a physics point of view. Tires are the only thing connecting your car to the road, and we are not talking about tires, therefor grip is the same. But with that said I don't mean to argue or get on your bad side, and I apologize for taking this further than it needed to go. You know what works better for you, and I know what works better for me.
............_____\_(+)_/_____
Andrew /|O| [||||][||||] |O|\
1996 328iS OEM Frankenstein
  #429
Old 03-03-2014, 03:41 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Higher gears don't make a difference most of the time. If you're in snow and have zero grip, the tires will spin whether it's in 1st gear or 5th gear.
Take this from a guy who actually drives in the snow.
Turbo Build Here
  #430
Old 03-03-2014, 03:50 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
Mein Auto: A redhead E90
Originally Posted by cj.surr View Post
solution: Get good snow tires, with an lsd or locking diff. Drop the clutch, proceed and ain't care.
qft
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '14 GMC Sierra SLE Z71
  #431
Old 03-03-2014, 03:52 PM
Needs Boost
Mein Auto: Red Sled
Or you could drive a RWD manual 540 with summer tires and no LSD. Thing is literally the worst vehicle for the snow lol.
Turbo Build Here
  #432
Old 03-03-2014, 03:53 PM
I Am The Machine
No need to get aggressive. Not living in the snow doesn't mean I don't drive in the snow. If auto works for you that's fine, but my experiences mirror dwondas. Making a blanket statement that auto is always easier in low traction situations just doesn't make sense.
Edit, just saw the summer tires post. There's your problem.
// Chad //
You're a derbanana
  #433
Old 03-03-2014, 03:55 PM
Kdoherty's Avatar
Hence why my E36 is buried and the E90 is the DD
  #434
Old 03-03-2014, 03:57 PM
dwonda's Avatar
No such thing as zero grip. Sorry I know I'm an ass.
  #435
Old 03-03-2014, 04:07 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
Been stupid busy lately. From a recent photoshoot:
E46 M3 CSL Stateside by Meritus Photography, on Flickr
Old 03-03-2014, 04:10 PM
Needs Boost
Mein Auto: Red Sled
I'm not being aggressive. I have simply driven cars with a manual in the snow, then 5 minutes later the same car with an auto and it's a noticeable difference.
Most people haven't had that comparison that's all.
Stating that on such and such day in such and such snow in such and such car I drove just fine isn't very factual. Ya know?
Turbo Build Here
  #437
Old 03-03-2014, 05:05 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Originally Posted by B1MM3R View Post
Ken!!!!
Is adjusting the valves and easy job to do also?
df and that video covered it, but I have a suggestion: put the feeler gauge between the cam and rocker, instead of the rocker and valve stem tip. You have to drop the gap a tiny bit (0.009" instead of 0.010") due to the uneven length of the rockers. The valve stem tips get mushroomed and the eccentric adjusters get grooved, making and accurate adjustment difficult. Unless the cam face is pretty worn it will be easier to get an accurate adjustment using that end of the rocker.
Super easy job. Rolling the engine over is the hardest part.
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
Amateur Extra ham radio operator KO4AXN, see you on 40 meters!
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
  #438
Old 03-03-2014, 06:23 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
to roll the engine over i would suggest using a test light between pins 11 & 14.
connect to 1 pin with the clip, and then tap the other pin with the point of the test light. it hould put power to the starter only. just a touch, though. you aren't trying to crank the engine over.
iirc this will work with the key off, sonodraining of the battery....
df
Old 03-03-2014, 06:42 PM
dc_wright's Avatar
Let's move to a different setting. I've pulled many manual tranny 4WD trucks AND their attached boats up slippery boat ramps with my 2WD auto tranny truck. They couldn't modulate the clutch well enough to keep from spinning the tires (both ends of the truck) and sliding backwards where the torque converter in the auto tranny gave me much more control.
  #440
Old 03-03-2014, 06:45 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
That's a good point Don. My way of looking at it isn't initial grip, but where I like the manny tranny is in downshifting opposed to most braking, and in having the gear I want selected opposed to having it change gears on me during say a curve, or on a hill.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
  #441
Old 03-03-2014, 06:51 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
A real CSL? :O That's flippin sweet James.
Facts about auto's stated in this thread is untruthithfull. Even the e36 has a nifty m/a button to help an auto start in a higher gear to reduce wheel spin. I've driven both in the winter as well I agree with Matt 100%. Even my Camry has a feature to upshift or downshift with a button ( no it's not failtronic). Driving auto in the winter is easier period. No worries about wheel spin unless you're hooning the throttle, can use features to upshift/downshift as needed. Gear shifts aren't aggressive enough to break traction, no worries about starting on a hill ( this is the worst in a manual.)
For what it's worth I probably drive through more snow then pretty much anyone here.
Lots of junk.
  #442
Old 03-03-2014, 06:56 PM
dc_wright's Avatar
Absolutely agree with you there Ed! What about a Tacoma Quad cab? Then you'd have an actual truck chassis to handle the rugged roads instead of a souped up car body on bigger springs (SUV). You could get a topper and have lots of cargo room too.
  #443
cj.surr's Avatar
some kid
I think the real fact of the matter is that auto vs manual will not make a significant difference in anyone's driving ability with the proper snow tires and drivetrain. It's just a preference thing.
I definitely like an auto better in a truck. Way easier to start on hills or pull a car out when you don't have to modulate the clutch.
-CJ
  #444
Needs Boost
Mein Auto: Red Sled
Yea autos are better offroad for sure.
Yea. Another way to think of it is:
Your car is on jack stands with the wheels in the air. Can you modulate the clutch and slip it? And it's the same for 1st through 5 or 6 gears,kinda like when you have no traction in the snow.
My .02
Turbo Build Here
  #445
Old 03-03-2014, 06:57 PM
Needs Boost
Mein Auto: Red Sled
To clarify I still prefer a stick, just because it's soo much fun in the snow.
Turbo Build Here
  #446
Old 03-03-2014, 06:59 PM
dc_wright's Avatar
Suuuwwwweeeeettttt!
  #447
ZeGerman's Avatar
ZeGerman ZeGerman is offline
BMWCCA HPDE Instructor
Mein Auto: 1998 BMW 328is
The XV Crosstrek starts at $28699 cash price here. (With a 60 mos term of $440/month w/ 15% down).
The Legacy wagon is down to a 2.0 (base model), and is just too bland for my tastes. (I spent a bunch of time in a buddies '06 2.5 RS similar to yours IIRC, and it was so numb to drive, mind you, his is autotragic).
Holy toledo, your prices are crazy up there. I totally agree that the older Subarus like mine are a complete snooze fest, though. At least in 2.5 auto trim, anyway. That said, I do get an odd sense of pleasure driving in the snow in a car that I know will probably never break down. That's the thing about Subarus - they're kinda like Porsche in that they're so evolutionary that they've become quite reliable. They have stuck to what they know how to do for decades, and it has paid off. You'll never have an AWD failure, ever. But yeah, it would be pretty hard to pony up nearly $29k for an XV Crosstrek.
'Sup James! Glad to see you're still producing awesome photography! How are things?
1998 BMW 328is
1966 Pontiac GTO
  #448
Santa
Mein Auto: 95 M3
This / End argument. Well put sir. If you have legitimate tires that's all you need.
Lots of junk.
  #449
Old 03-03-2014, 07:09 PM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 01 325xit
I've pulled three vehicles out of ditches with my 325, twice on gravel and once in the wet, clutch wasn't ever a problem. In the truck... Well, let's just say the list of things that can keep that thing from moving is very, very short.
How do you outcrazy a dude that lifts his engines without a hoist?
  #450
Old 03-03-2014, 07:30 PM
Needs Boost
Mein Auto: Red Sled
I was sad to hear your safe adventure was a dud
Turbo Build Here
Closed Thread
rip e36 ot, sir chadley broke bimmerfest
