E24 Sunroof Motor question. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 10-19-2017, 12:38 PM
ilouie ilouie is offline
85 E24
Mein Auto: 1985 BMW 635 CSi
Hi, I was wondering if someone can enlighten mew. I took the sunroof out the car, and tested it directly to the battery. The motor turns on. My problem is that the motor seems to be working but it's not moving the gear. I can't figure out a way to take motor apart. Should I take apart, if so, how?...Or, is the gears broken and in need of replacing entire motor?. Thanks in advance.
Old 10-19-2017, 01:55 PM
85 E24
Never mind. The motor is bad.
Old 05-23-2018, 11:17 AM
da750 da750 is offline
Mein Auto: 635,733,750
Can't believe I missed your post the past 2 months..
I've replaced my motor twice.
It's not the motor. It's the tracts. The cables that move the roof via the motor.
Now if I can only find a reasonable upholsterer to replace the ol' headliner.
BTW I re- used an old 3 series SR motor
Good luck
D
HTML code is Off
