Parts diagram/list Halogen Headlights - Bimmerfest - BMW Forums
Old 02-20-2020, 05:31 PM
darkslyde darkslyde is offline
Mein Auto: 2006 Z4 3.0i
I've searched all over google and I can't find a parts list for the halogen headlights assembly. Specifically, I'm looking for the part no of the middle park light bulb holder. It's similar to the turn signal bulb holder/socket except its shorter. The turn signal and the amber corner one's work but whoever owned my Z4 destroyed both left and right side middle bulb holder/socket. I rather not buy two headlight assemblies if I can just replace those parts.
Thanks for any help. Also, please be gentle, I'm new in the forums and new to BMWs.
Old 02-20-2020, 07:07 PM
Lunas72 Lunas72 is offline
Mein Auto: 2003 2.5i Z4
If you haven't, try realoem.com.
Sent from my SM-G973U using Tapatalk
Old 02-20-2020, 10:10 PM
first place i went to. i've tried messing with the years, production dates, different size engines, etc and it just shows me the HID headlight assembly every single time.
Old 02-20-2020, 10:37 PM
shaohuiclub333 shaohuiclub333 is offline
Mein Auto: 328
maybe it's need replaced the headlight assembly. i guess, some guys could dispatched the light for retrofit!
Old 02-20-2020, 11:10 PM
Yeah, sorry about that, can't help you. I have th bi-xenon. Realoem is the first place I usually check.
Old 02-20-2020, 11:12 PM
One more thing. Did you try entering the last 7 of your VIN?
Old 02-21-2020, 08:54 AM
@Lunas72 yeah, i did but the HID headlight is an option so its not tied to the vin.
@shaohuiclub333 I rather not buy brand new/used or aftermarket headlights. The parts should only be $14/each, the turn signal socket/bulb holder is only $12. I have no use for a whole assembly when I only need 2 small individual part for a fraction of the price.
I guess I'll contact the parts department of my local BMW dealership... and spend hours trying to figure it out.
Old 02-21-2020, 09:19 AM
Good luck! Hope you get it resolved.
Old 02-22-2020, 07:35 AM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Is item 8 what you're looking for?
http://bmwfans.info/parts-catalog/E8...non_headlight/
https://www.ecstuning.com/b-genuine-...t/63127158748/
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-24-2020, 07:55 AM
@dc_wright: so i'm waiting for some downtime at the shop so i can put my z on the lift and double check that it's the same exact part. it's stuck couldn't pull it out of the assembly so i couldnt verify that it's the same thing.
on the TIS, it shows that there are two turn signals, one in the middle and one next to DRL.
https://imgur.com/bONL1KQ
(LEFT SIDE)
On my Z4, the bulb holder labeled #1 is destroyed, so i'm planning to take it out without breaking the mounting on the assembly. i'll order the turn signal bulb holder (63 12 7 158 748) and hope its the same part as mine. i'll take pics and when it's all said and done, i'll post it here so the next dude with the same issue doesn't have to stress as much as i did.
Old 02-28-2020, 10:39 PM
I posted something earlier but I guess I did something wrong and it didn't work so here we go.
TL;DR - There are two "Bulb socket, turn indicator" (part# 63 12 7 158 748) in the halogen headlights of '06 E85s. Also, don't use other bulbs other than what's in the manual because they will melt inside the headlight.
I wanted to replace the busted turn signal bulbs in my Z4, but for some reason, I was having a hard time getting them out. The bulb holders look like crap, like it was forced back in or something. So I contacted my awesome BMW parts guy and I bought some replacements.
Finally got some free time so I threw the car on the lift and went to town with it. I took some pics for anyone who's interested on how to replace your own.
https://imgur.com/a/t97flzE
Again, if it says H21 bulbs, ONLY USE 21 WATT BULBS. Even 2 watts over that matters...it was such a pain removing it without damaging the headlight assembly.
2006 BMW Z4 3.0i
