Tip to all: Adjust your E39's door latches for fresh German feel! WUHU! - Bimmerfest - BMW Forums
Old 03-18-2009, 09:07 PM
synenergy52's Avatar
synenergy52 synenergy52 is offline
Send a message via AIM to synenergy52
Mein Auto: 2016 Lexus Hybrid
I bought a Torx T-40 bit today at Autozone for 3/8" drive. Easy as pie, take your ratchet, extension and your T40 3/8" bit and loosen both bolts on the latch. Shouldnt take much effort to loosen them. Don't be afraid or intimidated. These latches are nothing fancy. Then carefully slide the latches backwards towards the center of the car just a wee bit. I'd say 1/2 a millimeter or millimeter at most. You can see the outline of where it used to be. Hand tighten each bolt at small increments being sure to take turns keep switching back and forth. Then take your ratchet and tighten away. Don't turn too tightly. Just enough to be Extremely snug. Then test it out! Close your door. Shouldn't take much effort to close--think showroom cars. If done right, all gaps UP and DOWN, left and right will be even and the door will open and shut with the firmness it did when new. My doors now feel great.
Again pay attention to the gaps and make sure the doors line up with eachother. Adjust accordingly. Don't be afraid to keep readjusting the latch til you get it right.
oh my gawd, I can't believe I wrote "DOOT" latches in the subject. I complain about people who do that sort of thing the most too. Bah. Mods can you fix? OCD OCD.
Complete BMW E46 Cooling System Guide
Shop at FCPEuro.com and use code MangoFCP5 at checkout for 5% off your order!
Old 03-19-2009, 07:04 AM
POof540i's Avatar
POof540i POof540i is offline
^^^Worst Username Ever!
Mein Auto: '01 540iA
I'm a visual learner soo....
PICS!
"The more you know, the more you don't know," Dave Chappelle
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content"-Durant
WTT: Black Comfort Seats for Black Sport Seats. PM for info.
Old 03-19-2009, 07:20 AM
Muddy4DSM Muddy4DSM is offline
Mein Auto: 2002 540i
Sounds like a good thing to adjust. It probably moves from repeatedly shutting doors on these parts. I'm going to check the car when I go out for lunch to see if they've moved at all.
Old 03-19-2009, 07:35 AM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
why would you adjust the latch?
The more you complain, the longer God makes you live. SPHOBA #00002
Old 03-19-2009, 08:36 AM
ketchup's Avatar
ketchup ketchup is offline
Wrenchin'
Mein Auto: E46 M3
i just like looking at pictures
PICS!
Old 03-19-2009, 09:30 AM
Sorry are you guys confused as to what part to adjust? There's nothing much to look at its just a door latch and looks the same before and after... It's the thing the door latches onto when shut. It's on the B-pillar. By where the stickers/vin# are on the door jamb. I can take a pic if you guys want. its simple... and I did it because my doors felt sloppy and my drivers door would actually rattle around when driving over bumps! WTF! now its super tight. If you look closely you can see where the door seals against the car body and the outline of where the door seals USED to sit. The door is now pushed in ever so slightly.
Old 03-19-2009, 10:02 AM
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Nice tip really, if the panels have never been off then these bolts have just been being pushed away from the center for years with no re-adjustment. It really can make a difference.
Old 03-19-2009, 10:12 AM
Yes it does. Ive always been intimidated cause to me the latches seem like a "don't F with me" type of item... but they're really easy to work on.
Old 03-19-2009, 10:50 AM
ganesht's Avatar
ganesht ganesht is offline
(oOO)\(lll)°(lll)/(OOo)
Mein Auto: 98 528i 5 speed
My passenger door does that, and its been pissing me off!!! i kept taking off the door panel thinking it was something inside moving... I cant wait to have a silent car again!
Old 03-19-2009, 11:36 AM
Tony E! Tony E! is offline
Mein Auto: 2002 e39///
lol....
ok thanks for the tip.
Old 03-19-2009, 11:53 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: Smart/Volvo
Great idea. I just repaired a botched replacement door handle install (didn't put the wire in the groove) and it made the car feel almost new . My door's been rattling for a while and hopefully this fixes it. It didn't occur to me as a problem :\
SOLD! '99 528i ('98/12 build). 293,000km BY29428/Royalrot
SOLD! '99 540i
Breaking My Wallet since 2005
Old 03-19-2009, 12:45 PM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2015 M4, 2015 i3
I tried it on my DS door, have yet to drive with it though--previously only Gummipflege had taken care of what noise did exist...
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmos/Beige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Silver/Beige*
2006 330i/man./SP/PP/CWP/Sirius/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2*
2015 i3 Capparisweiss/Solaric
2015 M4/man./Mineralgrau/Schwarz
*retired
Old 03-19-2009, 12:54 PM
Yeah it seemed like a creak in my frame or maybe a bad weld or something. it was just the door rocking around because it was loose due to 12+ years of opening and closing. It still doesn't feel AS new as the other 3 doors as the other doors never get used but still a BIG improvement. My drivers side exterior door handle doesn't seem to operate smoothly. Kinda dry. Sprayed WD40 and helped with the sticking but its still not perfect. Anyone know of any other components/rubber i can replace to make the door handle feel new?
Old 03-19-2009, 12:56 PM
You must have a lot of passengers... maybe you should stop picking up so many women jk
Old 03-19-2009, 01:31 PM
spydrz's Avatar
Sandlapper Chapter
WD40 is good as a water repellent but not so good as a lubricant. Get some spray white lithium grease and use that on the hinges, etc.
*retired
Old 03-19-2009, 01:42 PM
fadetogrey fadetogrey is offline
Software Engineer
Mein Auto: 2003 540i 6-spd
I second that - solves noisy metal parts in one swoop but white lithium is messy. Be sparing and wipe off excess delicately.
2003 BMW 540i 6-speed
Black M-Sport with Navigation + DSP
DICE Silverline | E60 Short Shfter and CDV Removed | 12" JL / Rockford Amp
Old 03-19-2009, 02:06 PM
spydrz's Avatar
Sandlapper Chapter
Very true, it can run and drip.
*retired
Old 03-19-2009, 02:31 PM
lild's Avatar
livin the 'Fest
and you haven't read the winter help my door won't close threads. lol
each has it's pro's and con's.
Old 03-19-2009, 07:12 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Graphite lube would probably be even better. Works incredible on older door locks. Seriously. I had to read about 5 posts into this thread to even figure out WTF it was about!
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 03-19-2009, 07:28 PM
lild's Avatar
livin the 'Fest
lol, i couldn't understand why either. the only time we mess with a latch is when a car was wrecked in the door. i never heard of a latch just loosing up, from opening and closing the doors.
Old 03-19-2009, 07:31 PM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
D00t latches! w00h00!!
Old 03-19-2009, 10:14 PM
Think of it as an alignment for your door. Metal bends. Adjust latch. Door realigned!
Old 03-19-2009, 10:46 PM
lild's Avatar
livin the 'Fest
true metal bends. but not in this case. something was lose, why i don't know. but it's a good thing you fixed it.
Old 03-27-2009, 07:43 AM
pilotroger pilotroger is offline
Mein Auto: F83 M4
My doors have now been restored to their original solid Dingolfing 'THUD'. Great tip, thanks!
Old 03-27-2009, 07:53 AM
spydrz's Avatar
Sandlapper Chapter
Oh I didn't know there was an issue with frozen doors...rarely gets cold enough here for something like that to happen. So no I've never had a reason to look at those threads...
*retired
