Signs of a failing ignition switch? - Page 3 - Bimmerfest - BMW Forums
Old 04-19-2014, 08:05 AM
Libryum1 Libryum1 is offline
Mein Auto: 2002 525i
Originally Posted by QSilver7 View Post
You "read that it could be the ignition switch"....so, did you watch the video in post #1 & post #19 (the follow up video)? And if you did...were you able to replicate any of the odd electrical gremlins?
Hi QSilver7 - I did watch both videos and I even tried the visor thing to see if I would replicate the electrical gremlins, and I had no luck using the visor approach. However, when I pull down the visor, the light automatically comes on which is strange because it should only come on when I slide the mirror cover to the left. On the driver side visor, this does not happen. But I am experiencing all the other gremlins you mention: steering wheel moving up and down, radio shuts off or sometimes does not work, steering wheel control buttons don't work at times and same with the horn and airbag light is on, etc.. And right now it feels as if my car is driving in another gear. Do you think this is still the ignition switch? Thoughts? Your input us much appreciated.
Old 05-01-2014, 07:31 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Another failed ignition switch today:
> E39 (1997 - 2003) > Spinning Key ignition ( tumbler )
Originally Posted by Bmw e39 prob View Post
Hello guys,
I own a 1997 e39 and when i got home and removed the key the car stayed on. Now I've dealt with this problem only a week ago with my other 1998 e39 and successfully removed the tumbler fairly easy.
However, this case is different as the tumbler acts as if its the wrong key (trust me its not). It rotates freely and I can remove the key in any position id like. So I'm not sure how to tackle this I've tried over 4 hours with the pin but no luck.
I place the key where position 2 would be but nothing. Any ideas ??
Old 05-14-2014, 10:02 AM
bluebee's Avatar
For the record, this failing ignition switch thread was updated today;
> E39 (1997 - 2003) > Help- Can't remove key from the ignition
Old 06-03-2014, 01:54 PM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
Originally Posted by shenecke View Post
Un-foking believable! I had the same symptoms radio turning off, steering wheel raising and none of the buttons on the steering wheel working. Did the passenger mirror trick and radio off, wheel raises! Bad ignition switch. Cost me about $80 for the switch, 1 hour and it fixed all the problems. Took the old one apart and it did'nt even look that bad. No pitting on the contacts, just a little black carbon on them. I never would have guessed it was bad just from looking at the contacts.
Kudos to whom ever first diagnosed this problem and the cure!
Same exact problems (although no trainy light like some others here). Will replace. Was going to rebuild the switch, but for the money, I'll just buy new for peace of mind. I rebuilt my instrument cluster because that was too costly to get new, but for $70 for a new switch, I'll buy new.
Old 06-06-2014, 07:39 PM
Replaced today in about 45 minutes, including dropping the lower part of the dash under the steering wheel. Note. be sure to align the white plastic end that inserts into the steering column. I installed mine initially but the key wouldn't turn. I didn't have it aligned right, but it installed like it did. I had to take apart, align the new part, and reinstall. Good to go!
Old 06-07-2014, 08:32 AM
freeboy freeboy is offline
Mein Auto: bmw 528i
hi
Old 06-07-2014, 08:34 AM
Mein Auto: bmw 528i
my e39 is given me hard starting
Old 02-22-2015, 12:40 PM
1SRS7886X5 1SRS7886X5 is offline
EMPR"X5"ARIO
Mein Auto: e53 X5 4.4i
Great input Qsilver7 shed sunlight on this dark situation!
Old 02-22-2015, 12:47 PM
EMPR"X5"ARIO
Thank you for input
Old 02-22-2015, 04:13 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Mein Auto: 2006 X5 4.4/2013 650ix GC
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 02-22-2015, 08:05 PM
brc5 brc5 is offline
Mein Auto: 535i, X5, 911
For me, cruise control kept cutting out and airbag light came on. Fixed with new switch.
Limiters limiting the fun
Old 02-23-2015, 11:26 AM
for me, several electric gremlins, steering column acting out on its own/sticking in a position, or going in/out non-stop. Intermittent hard starting/no starting. Replaced (OEM) and all good.
Old 02-23-2015, 04:42 PM
540 M-Sport's Avatar
Mein Auto: M550i, 540M-Sport, Scud
I replaced my ignition switch (oem) in summer 2009, and a few months ago, it started the intermittent problem of continuously cranking when starting. I have to return to position "0" to get it to stop. When I start again, all is well. This happens about once per month. Bought a new oem switch, have not had time to install it...may just give it to my tech to handle...
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 04-20-2016, 08:29 PM
ID540i ID540i is offline
Mein Auto: 2002 BMW 540i
Thanks to bobdmac and bimmerfest. Would never have look for faultyy ignition switch with issues we were having. Video in thread was invaluable. $55 and an hour or so and all is well. Thanks again
Old 04-20-2016, 09:20 PM
Sroor9001 Sroor9001 is offline
ALGhoul
Mein Auto: Bmw 525i 2002
For me I've added push start button with RFID for the push start button so Iam playing with wires so no more failing ignition switch which is crazy in our e39
Old 04-21-2016, 06:32 AM
QSilver7's Avatar
Although this is a reply to a post that is over a year old...I thought something should be said just in case someone doesn't know about the "one-touch-start" aka "convenience start" aka "auto start" feature.
The text bolded in the quote above (continuous cranking when starting)...isn't necessarily an issue with the ignition switch...nor the starter on the V8 or V12 engines from the BMW (e38/e39/e52/e53) generation.
These models have a "convenience start" feature that will continue to run until the engine starts. So if you are experiencing this issue...again, its probably not the ignition or the starter...but an issue with the engine whereby something is preventing the correct mixture of fuel/air/spark that would allow the engine to normally start.
This convenience start/auto start feature is explained in the 2nd paragraph taken from the owners manual:
This feature is also mentioned in this EWS chart which reveals when this feature debuted and what engines received it...look in the "one touch start" column:
(SOLD)
Old 04-21-2016, 04:42 PM
Interesting, but I disagree....I had the ignition switched replaced a couple months after I posted, and the issue went away, just like when I replaced the switch previously.
Old 07-07-2016, 01:05 PM
jaytee1972 jaytee1972 is offline
Mein Auto: 2001 530i
Thank you so much for this post, had I not read this post before my daughter had the problem I would have thought she was smoking crack! Fixed it no problem after 3 trips to the part store.
Note to self: Always take the part with you to the store to compare.
Oddly 2 parts were labeled by advanced auto as a match, but the "L-shaped" doo-hickey in the connector was backwards.
Old 08-25-2016, 06:06 AM
Rec0n Rec0n is offline
Mein Auto: E60, 530i Motorsport
Thanks to the OP for creating this thread. My Google search yielded this thread straight away, and much to my shock, I got the radio etc to work again by flipping down the passenger visor and turning on the vanity light.
I will add my symptoms for the sake of the next person who Googles this issue.
  • Radio display off - radio on.......then it turns off again randomly. A flip of the vanity fixes it.
  • Airbag light is on all the time - fades out sometimes when I wiggle the cables on the Ign Sw
  • Clock turns off randomly and pressing the SET button brings it on.
  • Steering wheel controls don't work, incl illumination
  • Mirrors not moving at times
  • Accessory power to my dash-cam cuts out at times
  • Accessory power to mobile BT module cuts out at times and reconnects
  • iPod interface module power drops out at times (GRoM accessory unit)
  • car will not crank - I have to tap the back of the ignition switch with a screwdriver handle to get it going until my switch comes into stock
This will be my second ignition switch in 4 years on mine too. The first time the car just would not crank - never noticed anything else happening.
Thanks again for this great forum that shares all of the odd ball BMW issues so we can all enjoy these great machines!
UPDATE: Replaced the ignition switch today after a wait for parts. All issues now fixed and she starts like it should again. Easy fix for anyone who is worried about tackling this yourself, so give it a go.
2006 530i Motorsport, Titansilber
Old 07-07-2019, 01:23 AM
Pls Pls is offline
Mein Auto:
Okay, first of all, I just replaced my battery and starter. I am wondering if I need to replace my ignition switch, but I have an e90, 2006 325xi and do not know if this diagnosis applies to my model..... Symptoms include:
Instrument cluster turns on and of sporadically during driving, with ABS, airbag, and e brake lights coming on.
Radio turns on and off randomly while driving
Wipers will not work while driving but turn themselves on randomly in the middle of the night! Key out, car off... Scary!
Blinkers work, but display on dash sporadically.
Please help, I feel like my car is going to eat me!
Old 07-07-2019, 05:51 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Did you post in the correct forum also? This is about e39 only....
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 07-07-2019, 08:58 AM
Pls Pls is offline
Mein Auto:
I did not, I could not find any similar threads in the 3 series forums. I was hoping just for some insight from someone with a similar issue.
Old 07-07-2019, 12:29 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
not knowing much about that model, but helped a friend with a similar problem once that did some similar things. turns out it was the "ECT" module (hope thats correct, been quite a while) mounted in the trunk above the battery, by putting manual pressure on the module, parts of the electric would shut off and return. might try posting in the e90 forum as well, maybe someone who can help you better will see your post.
99 528i 5sp sport
be alert...the world needs more lerts
