Z4 Battery - Bimmerfest - BMW Forums
Old 05-01-2019, 01:42 PM
midnightrambler midnightrambler is offline
Z4JOEY
Mein Auto: 2007 Z4 3.0i
Z4 Battery
I'm due for a battery replacement on a 2007 Z4. If I dis-connect & replace with a new battery, will it loose anything that needs to be reprogrammed ? Keys etc. Not worried about the radio or clock, just the important stuff. Also, recommendations for a battery?
Old 05-01-2019, 08:13 PM
dc_wright's Avatar
You'll lose the time setting on the clock and the window positions. Everything else will be good. As to brand, Interstate makes a battery that fits, and Autozone also carries one. I've got the Autozone battery in my car and it's been good for 3 years so far.
Old 05-02-2019, 08:53 AM
jman1975 jman1975 is offline
Mein Auto: ...
+1 for the Autozone battery, running the same brand
the stable:
2003 BMW Z4 3.0i
2008 Hummer H3 Alpha
2015 Mitsubishi Outlander Sport 2.0
Old 05-02-2019, 01:47 PM
rmjames007 rmjames007 is offline
Mein Auto: 2009 135i
Remember at the big box auto stores (they usually offer free installation if you buy their battery)
They will tell you that they cannot change out the battery or that they are not supposed to.
The battery in the E86 is a non-AGM battery so there is nothing special that needs to be done. So be prepared to do it your self or insist if they give you any static
Old 05-02-2019, 11:25 PM
KevinC's Avatar
KevinC KevinC is offline
your average JAMF
Mein Auto: '08 Z4 M Coupé,'16 Golf R
The battery in the M cars is AGM, and still, nothing special is required, nor would it be in this case if the owner wants to switch to an AGM battery. There is no battery registration procedure for any E85/E86. Hook up and go.
'08 Z4 M Coupé LM08602
'19 Golf R
Old 05-03-2019, 12:40 PM
p598738 p598738 is offline
Mein Auto: Z4 2,5 and 3.0
I swapped batteries in my E85 Z4s several times. Always Autozone, never a problem,
Old 05-03-2019, 09:23 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
If they were never a problem, why did you have to swap them so often? Har de har, J/k
Old 05-04-2019, 07:58 AM
Rob2m Rob2m is offline
Mein Auto: Z4
Do the window positions automatically reset? I assume you mean the positions of the windows at rest?
"Today’s ride will remind me forever how good it is to be a motorcyclist, how good it is to be alive and how much we need to live life, rather than watch it pass us by." Green VFR.
Old 05-04-2019, 01:41 PM
ZEEBOY ZEEBOY is offline
The Arkleyologist
Mein Auto: 1997 Z3 Roadster 2.8
Midnight...I put a battery in my wifes z4 seveal years ago...as I recall i put one of those 9volt gizzmos into the cigatette lighter while I swapped the batteries and never had a problem..
Old 05-04-2019, 11:34 PM
Rob, the windows will work fine when you reinstall the battery. However, you will notice the autodip feature isnt working when you open and close the door, so you will need to reset the window limits to get a full seal.
[SIGPIC]
Old 05-05-2019, 04:04 AM
Mein Auto: Z4
Ah, thanks.
Old 05-05-2019, 03:27 PM
KevinC's Avatar
your average JAMF
I just had to hold the buttons through a couple of full up/down cycles, then they were reset for 1-touch operation. Super easy.
'19 Golf R
Old 05-05-2019, 10:20 PM
Courtesy of a BMW tech on another forum, ...with thanks.
Initialization is performed on the power window switch of the relevant door.
Requirements for correct initialization:
• Initialization with engine running
• Convertible top, doors and windows closed
Initialization comprises:
• Erasure of initialization
• Reinitialization
An initialization must be performed:
• In the event of malfunctions, e.g. no one-touch control function, no opening or if available no comfort function is possible
• After the power window drive has been replaced
• After work is carried out on the power window mechanism
• After a power supply interruption, e.g. disconnection of the battery or disconnection of the power supply to the door
• After the door window glass has been removed and installed or replaced
• After adjustment work on the door window glass
• After adjustment work on the convertible top
• After replacement of seals
Erasure of initialization:
• Open door window glass fully
• Operate power window switch in "Open" position four times within 10 seconds
This erases initialization of the power window, anti-trapping protection and toll function are inactive.
Check whether one-touch control (toll) function is inactive, otherwise repeat procedure.
Reinitialization:
Avoid a break between the two steps!
• Operate and hold power window switch in "Close" position (second switch stage)
• Once the upper end position has been reached, hold power window switch in "Close" position for approx. 2 seconds longer
[SIGPIC]
Old 05-07-2019, 11:05 AM
lmacmil lmacmil is offline
Mein Auto: 2006 BMW Z4 3.0si
I'm starting my 5th summer with a Walmart Ever-Start. I disconnected it during the 5 month winter storage (keeping it on a tender is not available is the facility I use) and the car started right up when I hooked it back up last month. I know I lost the radio & clock settings and all the readings on the dash (ave mph, mpg, range, etc.) I expect to get through this summer w/o a problem. I believe the parasitic drain is faster now than it was when new but I don't think that's unusual for a 4 year old battery. I did not by an AGM model.
2006 3.0 Si
Old 05-07-2019, 12:00 PM
I too have had good luck with the Walmart batteries. I have one in my truck and a couple more in the boat. Sulfating, not age is usually the death of a stored battery and Battery Tender can help prevent that.
[SIGPIC]
Similar Threads
BMW revised battery replacement meangreen94z 7 Series - F01 / F02 / F03 / F04 (2008 - 2015) 50 05-18-2018 02:17 PM
2013 e93 m3 battery replacement tips beermeisterkink E90/E91/E92/E93 (2006 - 2013) 11 10-31-2017 04:27 PM
E93 Battery Replacement: Some Suggestions for Installation fun2drive E90/E91/E92/E93 (2006 - 2013) 12 06-27-2017 02:42 PM
2007 530i Battery biscaynemark E60 / E61 (2004 - 2010) 8 11-04-2015 02:43 PM
*BREAKING* NBA Bans LA Clippers Owner Donald Sterling FOR LIFE! TXSTYLE Off-Topic 96 05-04-2014 11:31 PM
