For those who installed a front lip and removed the bottom deflectors - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 09-04-2019, 09:47 AM
F82ny F82ny is offline
Mein Auto:
Hey guys,
Bought a m4 used and it has a front lip on it. I'm familiar enough with the car to know that it's missing the right and left deflectors underneath the car. Without these on it looks like there's exposed area. How crucial is it for this area to be protected? Pics attached for reference. One is a pic of the deflector that was removed (one per side) and the other is the area that is now exposed.
ID:	863479   Click image for larger version
Old 12-08-2019, 01:39 PM
darkmann darkmann is offline
Driver
Mein Auto: A BMW
Probably not critical but I’d put them back on - at least that area you show will stay “clean” through water splashes.
Old 12-08-2019, 07:42 PM
M2Pilot M2Pilot is offline
Mein Auto: '16 M3,'98 M3, '76 M2
I don't know, but I suspect there may be some aerodynamic advantage to having them and/or they may direct air to where it's needed to promote cooling. Just speculation.
Old 12-10-2019, 10:11 AM
glennbaz glennbaz is offline
Mein Auto: 2016 M4 Convertible
deflectors
I just changed mine out because the rubber was worn. If I remember correctly there is a cooler of some type on each side of the vehicle. I believe leaving them out would cause front inbound air to bypass the cooler somewhat by going under the vehicle verses through the cooler. I may be wrong about air passage ways though. Check it out first to see if I am right.
Glenn
