transmission work at the Forbes' place - Bimmerfest - BMW Forums
Old 07-21-2007, 10:23 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Randy and I did the two service actions on my transmission today. The one for the shift catch pins, and the one for the 5th and reverse gear locking pin bushings. 5 new bushings total, 5 new sealing caps, 3 new springs and 3 new pins. I wish I would have bought a new locking pin for 5th gear; mine is clearly worn unevenly. If you're doing this work, buy new locking pins for reverse and 5th gear. FWIW, the service bulletin says you need the repair kit 23.11.7.542.726, but in reality you need two of them; there's only one bushing per kit and you need two. Also need all the right tools, which I bought (4 drifts and a small slide hammer).
In stock form, all of the shift catch pins slide in the machined bore in the transmission case. I guess it's no wonder that they can develop problems with sticking in the bore; different materials with different expansion rates, and the bore doesn't really get wetted. The two forward ones were both quite dry, the rearmost one was a little wetter. The repair kit comes with 3 bushings (look to be lined with a PTFE mix), 3 new catch pins, 3 new springs, and 3 new sealiing caps.
Everything went without a hitch. Auxiliary parts needed: all exhaust fasteners to remove the midsection, and the gaskets at the header end since they're graphite and mine were pretty much toast (at 31,000 miles). Looking at them, I'm surprised more people don't develop exhaust leaks at this point. Whatever slight binder is in those appears to melt a bit over time. I didn't take pictures, you'll have to take my word for it.
Daniel
2002 M roadster
Old 07-21-2007, 10:28 PM
dwm's Avatar
dwm dwm is offline
out with the old catch pins...
Punch a hole in each sealing cap, screw in the BMW mini slide hammer tool, and take out the sealing caps. 3 of these in the top of the transmission.
Pull the spring and catch pin out. We used the BMW mirror switch removal tool to lift the catch pins out; they're hollow inside.
Old sealing cap, old spring and old catch pin.
Daniel
2002 M roadster
Old 07-21-2007, 10:34 PM
dwm's Avatar
dwm dwm is offline
In with the new...
New lined bushing, new spring, new catch pin.
BMW drift tool and new bushing.
Tap the bushing into place.
Bushing in place.
Put the new catch pin and spring in.
Daniel
2002 M roadster
Old 07-21-2007, 10:39 PM
dwm's Avatar
dwm dwm is offline
In with the new part 2...
Use another BMW drift tool to install the new sealing caps.
We wound up tweaking this drift a tiny bit with the die grinder because it didn't want to come out of the sealing cap without taking the sealing cap with it. Just took a hair off the diameter of the tip, and chamfered the tip.
Put the cap on the drift and tap it into place.
One done (leftmost in the picture), the other two are the same deal.
Daniel
2002 M roadster
Old 07-21-2007, 10:54 PM
dwm's Avatar
dwm dwm is offline
reverse and 5th gear locking pins
I didn't take as many pictures here. This one shows the locking pin for reverse already done (blue cap at top center). It's essentially the same deal as the shift catch pins except there's an internal snap ring holding each cap. Remove the snap ring, punch a hole in the plastic-coated metal sealing cap, and remove it with the slide hammer. The sealing cap is removed for 5th gear in this picture, and the end of the spring is visible. It's the bore beneath the blue sealing cap for the reverse locking pin.
Remove the locking pin (BMW mirror switch removal tool used again here), then carefully remove the old unlined bushing by tapping a small screwdriver or the like between the bushing and the bore.at the bushing's split. One you've got enought of it pried up, you can pull it out with needlenose pliers.
Unlike the old bushing, the new one is lined (presumably a PTFE mix). the 5th gear locking pin was sticking on the old bushing pretty badly. It slides easily in the new bushing.
Use another BMW drift tool to tap the bushing into place. There are different drifts for the 5th and reverse gear bushings. Same diameter but different final depth.
Correct depth is when the large diameter of the correct drift hits the transmission housing.
The one that goes deeper (023) is for the reverse bushing, the shallower one (022 shown below) is for the 5th gear bushing.
Daniel
2002 M roadster
Old 07-21-2007, 10:56 PM
dwm's Avatar
dwm dwm is offline
As usual, many thanks to Randy for his help and the use of his garage and lift. MUCH easier than me doing this at home on jackstands.
And of course, thanks much to Sue and Randy for dinner and a margarita.
Daniel
2002 M roadster
Old 07-21-2007, 11:00 PM
dwm's Avatar
dwm dwm is offline
Oh, not pictured... the 5th drift to tap in the sealing caps for the 5th and reverse locking pins. IMHO you don't really need that one, and the springs are strong enough on those pins that you need to push on the caps while installing the internal snap rings anyway (so need something smaller than the drift, say a 1/4" socket extension).
Daniel
2002 M roadster
Old 07-21-2007, 11:04 PM
dwm's Avatar
dwm dwm is offline
The service bulletin and instructions for the catch pins.
SIB 23 01 02 (881)
repair instructions
Daniel
2002 M roadster
Old 07-21-2007, 11:06 PM
dwm's Avatar
dwm dwm is offline
The SIB and instructions for the reverse and 5th gear locking pin bushings.
SIB 23 01 04 (063)
repair instructions
Daniel
2002 M roadster
Old 07-21-2007, 11:09 PM
dwm's Avatar
dwm dwm is offline
Picture of the BMW mini slide hammer tool.
Daniel
2002 M roadster
Old 07-22-2007, 12:22 AM
Randy Forbes's Avatar
Investigative Tinkerer
You're welcome, as always
At least we finally got that project off the list; now you're ready for a nice long drive...
Randy Forbes
1999///M Rdstr Cosmos Black our first BMW
2001///M Rdstr Steel Gray
2016 X5M Mineral White Metallic/Beige Dinan STG II (716hp/702 Lbs Ft)
Old 07-22-2007, 12:38 AM
felonious monk felonious monk is offline
Ad Grunt
Mein Auto: '01 LSB M Roadster
Interesting to see how long this lasts. I had mine done under warranty. After just 1 year it started to exhibit same symptoms in stop and go on warm days.
Old 07-22-2007, 01:02 AM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
Thanks for the writeup and pictures.
Old 07-22-2007, 01:07 AM
dwm's Avatar
dwm dwm is offline
Yes, I'm relieved since we're headed south and it gave me trouble last year when it got hot. Having to leave stoplights in 3rd gear takes a lot of the fun out of driving this car.
Not ready for the drive yet. Two significant things left on the list, and of course a full detailing.
It feels like I haven't done a lot of mods this year, but looking back, I did get a decent chunk of minor longstanding things done. Very happy with the interior and underhood lighting, which turned out to be more work than I had hoped but I don't expect to ever have to touch it again.
Daniel
2002 M roadster
Old 07-22-2007, 02:25 AM
dwm's Avatar
dwm dwm is offline
Bummer. Hopefully I won't be replacing the bushings annually. Were the bushings installed correctly? It looks to me like it's pretty important that they're oriented correctly (split should be to the side of the transmission, not fore or aft). One of the reasons I decided to not let the dealer do it.
Daniel
2002 M roadster
Old 07-22-2007, 11:12 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
well?
any noticable difference shifting?
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit, 1-touch lane change,
UUC Stage 2 flywheel/M5 clutch,
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler,
Trafficpro, A-pillar gauge kit,
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 07-22-2007, 11:31 AM
JoshS JoshS is offline
Mein Auto: '03 540iT/6, '99 Z3 Coupe
I understand the 5th/reverse lockouts. Those springs case the shifter to move back to center in the left/right axis.
What are the others for? The same in the fore/aft axis?
My race car has the 5th-gear left/right pin sticking when cold, but it's fine when warm, so I haven't bothered to pull the tranny and fix yet. It warms up enough on the 1st lap. But I haven't noticed any other symptoms and until this post, I wasn't aware of the other set of pins. Just curious.
Old 07-22-2007, 11:43 AM
A Clean Windshield
during this project the other items I palnned to replace are the ball/flex/joint connector (whatever its called ) on the end of the shift rod. as well as the (goblaglich) driveshaft flex joint. and shift linkage support front bushings.
Old 07-22-2007, 11:49 AM
sminsc sminsc is offline
Mein Auto:
Great write up and pictures, I need to perform the same fix to my transmission in my '99 2.8. I have been having problems off and on for several months.Your post will be of good help.
Old 07-22-2007, 12:13 PM
dwm's Avatar
dwm dwm is offline
Originally Posted by bob lindquist View Post
well?
Not that I can tell, but I didn't expect any difference in feel and I've only driven it home from Toledo. Might be a wee bit easier going from 4th to 5th.
The problems I've had engaging 1st and 2nd gear have been spotty... most of the time it wasn't an issue, but there were times when it just wouldn't go into 1st or 2nd gear. Presumably because one or more catch pins were stuck in their bore. Makes me wonder what happens when this occurs in an SMG car.
The probability of it being a problem was increased in hot weather. The real test will be the Homecoming trip; it acted up several times last year.
I suspect it's less likely to occur in the S52 cars just by the virtue of having no undercover and hence more cooling of the transmission. No data to back that up. I like running with my undercover because I live on a dirt road.
Daniel
2002 M roadster
Old 07-22-2007, 12:37 PM
dwm's Avatar
dwm dwm is offline
Not the same as the 5th and reverse issue, see the service bulletins. Basically each of the three from-the-top pins can be in one of three detents on the top of the forks. If a pin gets stuck in its bore, you can't move that fork. In my case, the pin for 1st and 2nd gear liked to get stuck while it was in the center detent. If you try to force it, you risk damaging that pin and/or its bore. The pin is furthest out of the bore when its in a detent.
When doing this, I had the thought "This can't last forever", because eventually the bushing lining will wear away. Maybe that's what has happened with felonious' car. But at least now there are bushings that can be replaced. To me, ZF could've made some minor changes to the pins to make this less likely. Alas they didn't. The engineer in me says they should've put more meat in the pin walls (make them stiffer) and then chamfered the outer edges of the open end.
I've yet to contect Jim Rowe to see if he's ever done anything to address this issue.
Daniel
2002 M roadster
Old 07-22-2007, 12:57 PM
Mein Auto:
DWM, Do you have the part numbers for the bmw tools you used, I failed to find them in your post,thanks
Old 07-22-2007, 01:07 PM
Ah, makes sense. The service bulletin wasn't that specific, or at least, it wasn't nearly as well-worded as your reply. Thanks!
Old 07-22-2007, 01:46 PM
dwm's Avatar
dwm dwm is offline
They're in the repair instructions. You don't need 23 0 170 or 00 1 450. For both repairs, you need 23 0 490 (the slide hammer). For the catch pins you need drift 23 3 110 and 23 2 360. For the 5th/reverse locking pin bushings you need drift 23 4 022 and 23 4 023. You don't really need drift 23 4 021, but I bought all three as a set (23 4 020).
Obviously need other tools to get the transmission out. I didn't document that because it's pretty much like removing any RWD transmission. Many torx bolts on the bell housing, disconnect driveshaft from guibo, need a bent screwdriver tool for the 'bitch clip' to get the carrier arm off the transmission, need to remove the slave cylinder from the transmission, need to remove the exhaust midsection, etc. On the S54, you need to remove the intake manifold so you can see the starter from the top and get a little more light underneath. Engine should be supported too, which can either be done from the top via the engine hook or Randy's preferred method when the car's on a lift: a stand from underneath (which is how the 2 dealer's Randy and I have seen do it). Randy has a transmission jack, which makes getting the transmission on and off very easy when the car's on the lift.
I'd say you don't really want to do this in your garage without a lift and transmission jack. It's worth paying a shop to do it if you don't have these things. The dealer if you don't want to pay for tools too. There's one retaining screw on the steel bellhousing gasket that's a PITA to get at even with the car on the lift, and it has to be removed/replaced because that gasket is forward of the flywheel/clutch (can't be taken off with the transmission). The cat and O2 sensor bung make it a pain to get to it. It'd be easy if the heaers were off, but that's more work.
Daniel
2002 M roadster
Old 07-23-2007, 11:28 AM
Mein Auto:
Thanks, Daniel. I appreciate all the info, sounds like I may need to check with the dealer here.
